12-18-2006 05:34 AM
<config>
<actions>
<!– Launch Test Javascript Dialog –>
<action id="test_js">
<label>Test Javascript</label>
<image>/images/icons/add.gif</image>
<script>/Company Home/Data Dictionary/backup.js</script>
</action>
<!– Add action to more actions menu for each space –>
<action-group id="document_browse">
<action idref="test_js" />
</action-group>
</actions>
</config> org.alfresco.error.AlfrescoRuntimeException: Error during command servlet processing: Unable to resolve item Path: /Company Home/Data Dictionary/backup.js
at org.alfresco.web.app.servlet.CommandServlet.service(CommandServlet.java:176)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:802)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:252)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:868)
at org.apache.coyote.http11.Http11BaseProtocol$Http11ConnectionHandler.processConnection(Http11BaseProtocol.java:663)
Caused by: java.lang.IllegalArgumentException: Unable to resolve item Path: /Company Home/Data Dictionary/backup.js
at org.alfresco.web.app.servlet.BaseServlet.resolveNamePath(BaseServlet.java:315)
at org.alfresco.web.app.servlet.command.ScriptCommandProcessor.validateArguments(ScriptCommandProcessor.java:72)
at org.alfresco.web.app.servlet.CommandServlet.service(CommandServlet.java:128)
… 15 more 05-23-2007 01:30 PM
<!– Adding a custom menu item for adding "Pending approval" aspect after being rejected –>
   <config>
      <actions>
         <action id="return_to_PendingApproval">
            <label>Return to "Pending Approval" state</label>
            <script>/Company Home/Data Dictionary/Scripts/applyPendingApprovalAspect.js</script>
            <params>
               <param name="id">#{actionContext.id}</param>
            </params>
         </action>
      <!– Add action to Actions Menu for Document Details screen–>
         <action-group id="doc_details_actions">
            <action idref="return_to_PendingApproval" />
         </action-group>
      <!– Add action to Actions Menu for a document in the Browse screen–>
         <action-group id="document_browse_menu">
         </action-group>
      </actions>
   </config>
var doc_node = search.findNode("workspace://SpacesStore/"+args["id"]);
if (doc_node.isDocument){
   doc_node.removeAspect("dsm:docStatus_Rejected");
   doc_node.addAspect("dsm:docStatus_PendingApproval");
19:24:15,890 ERROR [org.apache.catalina.session.ManagerBase] IOException al cargar sesiones persistidas: java.io.WriteAbortedException: writing aborted; java.io.NotSerializableException: org.alfresco.web.bean.repository.QNameNodeMap
at java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1303)
at java.io.ObjectInputStream.defaultReadFields(ObjectInputStream.java:1912)
at java.io.ObjectInputStream.readSerialData(ObjectInputStream.java:1836)
at java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStream.java:1713)
at java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1299)
at java.io.ObjectInputStream.readObject(ObjectInputStream.java:339)
at org.apache.catalina.session.StandardSession.readObject(StandardSession.java:1386)
doc_node.addAspect("cm:Templatable");
10-17-2007 11:04 AM
org.alfresco.error.AlfrescoRuntimeException: Error during command servlet processing: Failed to execute script 'workspace://SpacesStore/c7e271cc-77e3-11dc-a556-858e0f82a842': Failed to execute script 'workspace://SpacesStore/c7e271cc-77e3-11dc-a556-858e0f82a842': ReferenceError: "space" is not defined. (AlfrescoScript#2)
caused by:
org.alfresco.service.cmr.repository.ScriptException: Failed to execute script 'workspace://SpacesStore/c7e271cc-77e3-11dc-a556-858e0f82a842': Failed to execute script 'workspace://SpacesStore/c7e271cc-77e3-11dc-a556-858e0f82a842': ReferenceError: "space" is not defined. (AlfrescoScript#2)
caused by:
org.alfresco.service.cmr.repository.ScriptException: Failed to execute script 'workspace://SpacesStore/c7e271cc-77e3-11dc-a556-858e0f82a842': ReferenceError: "space" is not defined. (AlfrescoScript#2)
caused by:
org.alfresco.error.AlfrescoRuntimeException: ReferenceError: "space" is not defined. (AlfrescoScript#2)
caused by:
org.mozilla.javascript.EcmaError: ReferenceError: "space" is not defined. (AlfrescoScript#2)
10-23-2007 07:27 AM
07-08-2010 03:59 PM
07-20-2010 02:47 AM
Another question: Is it possible to create an action only for a single user?
Yes, you can use an evaluator (see the <evaluator> tags for an action) and compare the current username with the user target for the action, which is available using the code:
org.alfresco.web.app.Application.getCurrentUser()
Kevin
08-02-2010 06:54 AM
