Problems installin MySQL with Alfresco
marãƒâ_a
Hi! This is the first time I’m using Alfresco. I have a lot of questions and my English is not very good. I’ve been working with an Alfresco version that works with HSQL. Now I’m trying to change HSQL with MySQL. What I have done is the next:
I have downloaded MySQL Server 5.0.
I have installed it with the typical installation (next, next…).
I’ve installed it as a Windows service and I’ve included MySQL in path.
Then I’ve run mysql -u root –p and it’s worked with no errors.
The problem is the next:
“Navigate to the 'C:\alfresco' folder and run 'db_setup.bat'.  This creates a MySQL database named 'alfresco' with a user account and password of 'alfresco'.  If db_setup fails, this may be because the MySQL service is not running or that the mysql command cannot be found.  Either correct this or setup the Alfresco database and user manually by loading the 'db_setup.sql' file into MySQL, for example, 'mysql -u root -p <db_setup.sql'â€
11 REPLIES 11
marãƒâ_a
Hi!
I’ve solved my problem. It was because my PC Name was too long and then, Alfresco could’t add “_aâ€
mikeh
Glad you got the problem fixed - thanks for posting your solution.
Mike
