Problems executing SDK JCRSamples
rcortesr
When I execute SimpleExample.java it appears to me the following error:
31-oct-2006 9:55:28 net.sf.joott.uno.UnoConnection connect
INFO: connecting using "socket,host=localhost,port=8100,tcpNoDelay=1"…
31-oct-2006 9:55:30 net.sf.joott.uno.UnoConnection connect
INFO: connected
INFO: connected
- Loading model from alfresco/model/jcrModel.xml
- Registered model jcr:jcrmodel
- Registered namespace 'http://www.jcp.org/jcr/1.0' (prefix 'jcr')
- Registered namespace 'http://www.jcp.org/jcr/nt/1.0' (prefix 'nt')
- Registered namespace 'http://www.jcp.org/jcr/mix/1.0' (prefix 'mix')
- Registered namespace 'http://www.jcp.org/jcr/sv/1.0' (prefix 'sv')
- Registered namespace 'http://www.w3.org/XML/1998/namespace' (prefix 'xml')
- Loading XML bean definitions from class path resource [org/springframework/jdbc/support/sql-error-codes.xml]
- SQLErrorCodes loaded: [DB2, HSQL, MS-SQL, MySQL, Oracle, Informix, PostgreSQL, Sybase]
- Checking for patches to apply …
- No patches were required.
java.lang.UnsatisfiedLinkError: no Win32NetBIOS in java.library.path
   at java.lang.ClassLoader.loadLibrary(Unknown Source)
   at java.lang.Runtime.loadLibrary0(Unknown Source)
   at java.lang.System.loadLibrary(Unknown Source)
   at org.alfresco.filesys.netbios.win32.Win32NetBIOS.<clinit>(Win32NetBIOS.java:711)
   at org.alfresco.filesys.server.config.ServerConfiguration.getLocalServerName(ServerConfiguration.java:2263)
   at org.alfresco.filesys.server.config.ServerConfiguration.processCIFSServerConfig(ServerConfiguration.java:610)
   at org.alfresco.filesys.server.config.ServerConfiguration.init(ServerConfiguration.java:479)
   at org.alfresco.filesys.server.config.ServerConfiguration.onApplicationEvent(ServerConfiguration.java:420)
   at org.springframework.context.event.SimpleApplicationEventMulticaster.multicastEvent(SimpleApplicationEventMulticaster.java:45)
   at org.springframework.context.support.AbstractApplicationContext.publishEvent(AbstractApplicationContext.java:225)
   at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:323)
   at org.springframework.context.support.ClassPathXmlApplicationContext.<init>(ClassPathXmlApplicationContext.java:87)- Error accessing Win32 NetBIOS, check DLL is on the path
- Starting server FTP …
- Alfresco JVM - v1.5.0_09-b03; maximum heap size 63,563MB
- Alfresco JVM - WARNING - maximum heap size 63,563MB is less than recommended 512MB
- Alfresco started (Community Network): Current version 1.3.0 schema 14 - Installed version 1.3.0 schema 14
- FTP Socket error
java.net.BindException: Address already in use: JVM_Bind
   at java.net.PlainSocketImpl.socketBind(Native Method)
   at java.net.PlainSocketImpl.bind(Unknown Source)
   at java.net.ServerSocket.bind(Unknown Source)
   at java.net.ServerSocket.<init>(Unknown Source)
   at org.alfresco.filesys.ftp.FTPNetworkServer.run(FTPNetworkServer.java:381)
   at org.springframework.context.support.ClassPathXmlApplicationContext.<init>(ClassPathXmlApplicationContext.java:72)
   at org.springframework.context.support.ClassPathXmlApplicationContext.<init>(ClassPathXmlApplicationContext.java:63)
   at org.alfresco.sample.jcr.Main.main(Main.java:27)
Exception in thread "main" javax.jcr.LoginException: Alfresco Repository failed to authenticate credentials: Bad credentials presented: Bad credentials presented
   at org.alfresco.jcr.repository.RepositoryImpl.login(RepositoryImpl.java:215)
   at org.alfresco.jcr.repository.RepositoryImpl.login(RepositoryImpl.java:240)
   at org.alfresco.sample.jcr.Main.main(Main.java:35)
Caused by: org.alfresco.repo.security.authentication.AuthenticationException: Bad credentials presented
   at org.alfresco.repo.security.authentication.AuthenticationComponentImpl.authenticate(AuthenticationComponentImpl.java:69)
   at org.alfresco.repo.security.authentication.AuthenticationServiceImpl.authenticate(AuthenticationServiceImpl.java:104)
   at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:335)
   at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:181)
   at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:148)
   at org.springframework.aop.support.DelegatingIntroductionInterceptor.invoke(DelegatingIntroductionInterceptor.java:116)
   at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:170)
   at org.alfresco.repo.security.permissions.impl.ExceptionTranslatorMethodInterceptor.invoke(ExceptionTranslatorMethodInterceptor.java:40)
   at org.springframework.transaction.interceptor.TransactionInterceptor.invoke(TransactionInterceptor.java:96)
   at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:176)
   at $Proxy22.authenticate(Unknown Source)
   at org.alfresco.jcr.repository.RepositoryImpl.login(RepositoryImpl.java:210)
   … 2 more
Caused by: net.sf.acegisecurity.BadCredentialsException: Bad credentials presented
   at net.sf.acegisecurity.providers.dao.DaoAuthenticationProvider.getUserFromBackend(DaoAuthenticationProvider.java:393)
   at net.sf.acegisecurity.providers.dao.DaoAuthenticationProvider.authenticate(DaoAuthenticationProvider.java:225)
   at net.sf.acegisecurity.providers.ProviderManager.doAuthentication(ProviderManager.java:159)
   at net.sf.acegisecurity.AbstractAuthenticationManager.authenticate(AbstractAuthenticationManager.java:49)
   at org.alfresco.repo.security.authentication.AuthenticationComponentImpl.authenticate(AuthenticationComponentImpl.java:63)
   … 21 more
   … 21 more
12 REPLIES 12
marcusm
commons-pool-1.3.jar exists in the path.
I supose that this isn't the problem.
Thanks.
Probably a bit late now, but do you have two copies of commons-pool-1.3.jar in the classpath, thus cancelling each other out?
dado
and i found that for some reason the build path for the project "SDK AlfrescoEmbedded" was incomplete.  For this project, I had to
Build Path -> Configure Build Path -> Add Jars -> expand "SDK AlfrescoEmbedded" and "dependencies" folders -> and add commons-dbcp-1.2.1.jar & commons-pool-1.3.jar
I also found a half dozen other jars in the SDK AlfrescoEmbedded project folder yet not added tot he build path.  I added these as well.
ctrl
or just add the alfresco/bin to your system path.
J.
