Problems connecting to a CMIS AtomPub Endpoint
dhiogocorrea
I'm new using Alfresco and CMIS, and I'm having some problems. I tried and searched a lot and couldn't fix it. I'm using Alfresco Community 3.2r and DotCmis 0.6. I'm using it in the port 8082.
I'm trying to run this code on Visual Studio 2008:
<blockcode>
private ISession Alfresco_Authentication()
            Dictionary<string, string> parameters = new Dictionary<string, string>();
            parameters[DotCMIS.SessionParameter.BindingType] = BindingType.AtomPub;
            parameters[DotCMIS.SessionParameter.AtomPubUrl] = "http://localhost:8082/alfresco/service/api/cmis";
            parameters[DotCMIS.SessionParameter.User] = "admin";
            parameters[DotCMIS.SessionParameter.Password] = "admin";
            SessionFactory factory = SessionFactory.NewInstance();
            IList<IRepository> repos = factory.GetRepositories(parameters);
            ISession session = repos.ElementAt(0).CreateSession();
            return session;
</blockcode>
I get the exception "<b>ArgumentOutOfRangeException was unhandled</b>" in the line: ISession session = repos.ElementAt(0).CreateSession();
Its seens like there is no repositories at all (repos.Count is zero after the GetRepositories stuff).
I also tried to change the AtomPubUrl to:
"http://localhost:8082/alfresco/service/cmis" - Getting the CmisObjectNotFoundException - Not Found
"http://localhost:8082/alfresco/cmis" - Getting the CmisObjectNotFoundException - Parsing exception!
Some other curious things:
-I tried to use the WebServices Binding Type, but inside "http://localhost:8082/alfresco/cmis", I don't have the AclService available.
-The url ""http://localhost:8082/alfresco/service/cmis" doesn't connect, i get the error message:
<blockcode>
The Web Script /alfresco/s/cmis has responded with a status of 404 - Not Found.
404 Description:   Requested resource is not available.
Message:   08040020 Script url /cmis does not map to a Web Script.
Exception:   org.alfresco.web.scripts.WebScriptException - 08040020 Script url /cmis does not map to a Web Script.
   org.alfresco.web.scripts.AbstractRuntime.executeScript(AbstractRuntime.java:129)
   org.alfresco.web.scripts.servlet.WebScriptServlet.service(WebScriptServlet.java:122)
   javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
   org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
   org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
   org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
   org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
   org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
   org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
   org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
   org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:286)
   org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:845)
   org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:583)
   org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447)
   java.lang.Thread.run(Thread.java:722)
</blockcode>
Please help me. It's driving me crazy!
Thanks!
10 REPLIES 10
