10-04-2016 10:35 AM
Hola a todos,
Estoy teniendo problemas a la hora de sincronizar los grupos y usuarios con LDAP, utilizamos Alfresco 4.2.f.
Cuando reiniciamos alfresco el log nos muestra lo siguiente. Parece que sincroniza pero no me está agregando ningún grupo ni usuario.
Synchronizing users and groups with user registry 'ldap1'
14:27:19,256 INFO [org.alfresco.repo.security.sync.ChainingUserRegistrySynchronizer] Retrieving all groups from user registry 'ldap1'
14:27:19,272 INFO [org.alfresco.repo.security.sync.ChainingUserRegistrySynchronizer] Synchronization,Category=directory,id1=ldap1,id2=1 Group Analysis: Commencing batch of 0 entries
14:27:19,273 INFO [org.alfresco.repo.security.sync.ChainingUserRegistrySynchronizer] Synchronization,Category=directory,id1=ldap1,id2=1 Group Analysis: Completed batch of 0 entries
14:27:19,275 INFO [org.alfresco.repo.security.sync.ChainingUserRegistrySynchronizer] Retrieving all users from user registry 'ldap1'
14:27:19,278 INFO [org.alfresco.repo.security.sync.ChainingUserRegistrySynchronizer] Synchronization,Category=directory,id1=ldap1,id2=6 User Creation and Association: Commencing batch of 0 entries
14:27:19,278 INFO [org.alfresco.repo.security.sync.ChainingUserRegistrySynchronizer] Synchronization,Category=directory,id1=ldap1,id2=6 User Creation and Association: Completed batch of 0 entries
14:27:19,281 INFO [org.alfresco.repo.security.sync.ChainingUserRegistrySynchronizer] Finished synchronizing users and groups with user registry 'ldap1'
14:27:19,281 INFO [org.alfresco.repo.security.sync.ChainingUserRegistrySynchronizer] 0 user(s) and 0 group(s) processed
14:27:19,359 INFO [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Startup of 'Synchronization' subsystem, ID: [Synchronization, default] complete
Lo primero que hago es crear el archivo de configuración en la siguiente ruta.
tomcat/shared/classes/alfresco/extension/subsystems/Authentication/ldap/ldap1/ldap-authentication.properties
### LDAP_1 Config ###
ldap.authentication.allowGuestLogin=false
ldap.authentication.userNameFormat=cn\=%s,ou\=people,dc\=alfresco,dc\=veritas,dc\=sm
ldap.authentication.java.naming.provider.url=ldap://64.664.65.644:389
ldap.authentication.defaultAdministratorUserNames=Administrator,alfresco,admin
ldap.synchronization.java.naming.security.principal=cn=admin,dc=alfresco,dc=veritas,dc=sm
ldap.synchronization.java.naming.security.credentials=admin
ldap.synchronization.groupSearchBase=cn=CIF_C79999999,ou=groups,dc=alfresco,dc=veritas,dc=sm
ldap.synchronization.userSearchBase=cn=CIF_C79999999,ou=groups,dc=alfresco,dc=veritas,dc=sm
Y indicamos en el archivo alfresco-global.properties el archivo creado anteriormente.
### LDAP Config ###
authentication.chain=ldap1:ldap,alfrescoNtlm1:alfrescoNtlm
¿Alguna idea de que se nos puede estar pasando?
Muchas gracias!!
10-04-2016 11:19 AM
Creo que no puedes incluir un CN en los "searchBase".
Deberías crear una "ou" intermedia que se llame, por ejemplo, "Alfresco" y colgar debajo los grupos (CN) que quieras que se sincronicen.
10-17-2016 06:22 AM
Muchas gracias Cesar,
He añadido las lineas que me comentas y ya me sincroniza cada vez que reinicio la máquina.
Una última pregunta. Tengo el problema de que me crea los grupos estableciendo como nombre la propiedad "description" del ldap en vez de la propiedad "cn".
Entiendo que con la propiedad ldap.synchronization.groupIdAttributeName=cn debería bastar para establecer el nombre del grupo, pero me los sigue creando con la propiedad "description" y en los logs no me aparece nada sobre esto. ¿Alguna idea?
Muchas gracias!
10-17-2016 06:51 AM
Hola de nuevo:
Las dos propiedades que lo gestionan en la sincronización en Alfresco por defecto son:
ldap.synchronization.groupDisplayNameAttributeName=description
La prueba rápida es cambiar la segunda de las propiedades a cn, si eso es lo que necesitas.
En cualquier caso tu LDAP o AD puede estar customizado o ser ligeramente diferente a esta configuración por defecto. Para asegurarme en estos casos, aconsejo utilizar un navegador de objetos de LDAP que te permita navegar por la estructura del mismo. Yo uso el Apache Directory Studio y me permite comprobar el usuario de sincronización, probar por anticipado las queries de LDAP y visualizar las propiedades de los objetos, como el nombre correcto de los grupos. Y esto debe ser coherente con las dos propiedades.
Es como el navegador de nodos pero para LDAP. En realidad hay muchas similitudes entre un sistema jerárquico de gestión documental y uno de LDAP.
Saludos.
--C.
10-17-2016 07:13 AM
He añadido la linea que me comentas y funciona como quería. En la documentación de Alfresco LDAP configuration properties | Alfresco Documentation no aparece esa propiedad. Hasta ahora usaba LdapAdmin para la gestión del LDAP, pero probaré el que comentas. Ha sido de gran ayuda.
Saludos.
