Problem with SDK examples
sergio
Hi all! I am new to this forum and to Alfresco, so many aspects about the architecture are not so clear….
I tried to run some examples (Window platform) provided with Alfresco SDK 1.4, but some problems occurred.
- After importing the example projects into Ecplise many dependencies have to be updated manually;
- the application example "FirstFoundationClient" doesn't work properly raising the following exception:
- Loading XML bean definitions from class path resource [alfresco/application-context.xml]
- Loading XML bean definitions from class path resource [alfresco/core-services-context.xml]
- MLog clients using log4j logging.
- JDK 1.4+ collections available
- Commons Collections 3.x available
- Loading XML bean definitions from class path resource [alfresco/public-services-context.xml]
- Loading XML bean definitions from class path resource [alfresco/public-services-security-context.xml]
- Loading XML bean definitions from class path resource [alfresco/cache-context.xml]
- Loading XML bean definitions from class path resource [alfresco/model-specific-services-context.xml]
- Loading XML bean definitions from class path resource [alfresco/action-services-context.xml]
- Loading XML bean definitions from class path resource [alfresco/rule-services-context.xml]
- Loading XML bean definitions from class path resource [alfresco/node-services-context.xml]
- Loading XML bean definitions from class path resource [alfresco/scheduled-jobs-context.xml]
- Loading XML bean definitions from class path resource [alfresco/network-protocol-context.xml]
- Loading XML bean definitions from class path resource [alfresco/content-services-context.xml]
Exception in thread "main" org.springframework.beans.factory.BeanDefinitionStoreException: Error registering bean with name 'openOfficeConnection' defined in class path resource [alfresco/content-services-context.xml]: Class that bean class [net.sf.jooreports.openoffice.connection.SocketOpenOfficeConnection] depends on not found; nested exception is java.lang.NoClassDefFoundError: com/sun/star/lang/XEventListener
   at java.lang.ClassLoader.defineClass1(Native Method)
   at java.lang.ClassLoader.defineClass(ClassLoader.java:620)
   at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:124)
   at java.net.URLClassLoader.defineClass(URLClassLoader.java:260)
   at java.net.URLClassLoader.access$100(URLClassLoader.java:56)
   at java.net.URLClassLoader$1.run(URLClassLoader.java:195)
   at java.net.URLClassLoader.findClass(URLClassLoader.java:188)
   at java.lang.ClassLoader.loadClass(ClassLoader.java:306)
   at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:268)
   at java.lang.ClassLoader.loadClass(ClassLoader.java:251)
   at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:319)
   at java.lang.Class.forName0(Native Method)
   at java.lang.Class.forName(Class.java:242)
   at org.springframework.util.ClassUtils.forName(ClassUtils.java:108)
   at org.springframework.beans.factory.support.BeanDefinitionReaderUtils.createBeanDefinition(BeanDefinitionReaderUtils.java:65)
   at org.springframework.beans.factory.xml.DefaultXmlBeanDefinitionParser.parseBeanDefinitionElement(DefaultXmlBeanDefinitionParser.java:426)
   at org.springframework.beans.factory.xml.DefaultXmlBeanDefinitionParser.parseBeanDefinitionElement(DefaultXmlBeanDefinitionParser.java:392)
   at org.springframework.beans.factory.xml.DefaultXmlBeanDefinitionParser.parseBeanDefinitions(DefaultXmlBeanDefinitionParser.java:307)
   at org.springframework.beans.factory.xml.DefaultXmlBeanDefinitionParser.registerBeanDefinitions(DefaultXmlBeanDefinitionParser.java:191)
   at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.registerBeanDefinitions(XmlBeanDefinitionReader.java:295)
   at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.doLoadBeanDefinitions(XmlBeanDefinitionReader.java:223)
   at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.loadBeanDefinitions(XmlBeanDefinitionReader.java:173)
   at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.loadBeanDefinitions(XmlBeanDefinitionReader.java:148)
   at org.springframework.beans.factory.support.AbstractBeanDefinitionReader.loadBeanDefinitions(AbstractBeanDefinitionReader.java:126)
   at org.springframework.beans.factory.support.AbstractBeanDefinitionReader.loadBeanDefinitions(AbstractBeanDefinitionReader.java:142)
   at org.springframework.beans.factory.xml.DefaultXmlBeanDefinitionParser.importBeanDefinitionResource(DefaultXmlBeanDefinitionParser.java:325)
   at org.springframework.beans.factory.xml.DefaultXmlBeanDefinitionParser.parseBeanDefinitions(DefaultXmlBeanDefinitionParser.java:298)
   at org.springframework.context.support.AbstractXmlApplicationContext.loadBeanDefinitions(AbstractXmlApplicationContext.java:113)
   at org.springframework.context.support.AbstractXmlApplicationContext.loadBeanDefinitions(AbstractXmlApplicationContext.java:81)
   at org.springframework.context.support.AbstractRefreshableApplicationContext.refreshBeanFactory(AbstractRefreshableApplicationContext.java:89)
   at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:269)
   at org.springframework.context.support.ClassPathXmlApplicationContext.<init>(ClassPathXmlApplicationContext.java:87)
   at org.springframework.context.support.ClassPathXmlApplicationContext.<init>(ClassPathXmlApplicationContext.java:72)
   at org.alfresco.util.ApplicationContextHelper.getApplicationContext(ApplicationContextHelper.java:40)
   at org.alfresco.sample.FirstFoundationClient.main(FirstFoundationClient.java:62)
Could it be a problem of configuration or other?
Many thanks to everyone.
Sergio
ribz33
look if you add openoffice jars from lib\server\dependencies\openoffice in Alfrescoebedded project
Smiley Happy
davidc
Which version of 1.4 are you using?
The latest 1.4 (RC1) fixed the dependencies.
