I'm new in the forum and with Alfresco. I've got a problem with links.
I've created some links to a document. When I delete the document, its links are not deleted but I can't see them, probably because they don't find the nodeRef associated.
Then I re-upload the document with the same name and I try to recreate the links and Alfresco says to me that a node with this name already exists. So I delete them using Javascript Console, and try again to create links.
Now Alfresco sends me this stack trace:
 org.postgresql.util.PSQLException: ERROR: duplicate key value violates unique constraint "parent_node_id"
  Detail: Key (parent_node_id, type_qname_id, child_node_name_crc, child_node_name)=(1193, 35, 918653046, test.txt.url) already exists.
   at org.postgresql.core.v3.QueryExecutorImpl.receiveErrorResponse(QueryExecutorImpl.java:2102)
   at org.postgresql.core.v3.QueryExecutorImpl.processResults(QueryExecutorImpl.java:1835)
   at org.postgresql.core.v3.QueryExecutorImpl.execute(QueryExecutorImpl.java:257)
   at org.postgresql.jdbc2.AbstractJdbc2Statement.execute(AbstractJdbc2Statement.java:500)
   at org.postgresql.jdbc2.AbstractJdbc2Statement.executeWithFlags(AbstractJdbc2Statement.java:388)
   at org.postgresql.jdbc2.AbstractJdbc2Statement.execute(AbstractJdbc2Statement.java:381)
   at org.apache.commons.dbcp.DelegatingPreparedStatement.execute(DelegatingPreparedStatement.java:172)
   at org.apache.ibatis.executor.statement.PreparedStatementHandler.update(PreparedStatementHandler.java:22)
   at org.apache.ibatis.executor.statement.RoutingStatementHandler.update(RoutingStatementHandler.java:51)
   at org.apache.ibatis.executor.SimpleExecutor.doUpdate(SimpleExecutor.java:29)
   at org.apache.ibatis.executor.BaseExecutor.update(BaseExecutor.java:87)
   at org.apache.ibatis.executor.CachingExecutor.update(CachingExecutor.java:46)
   at org.apache.ibatis.session.defaults.DefaultSqlSession.update(DefaultSqlSession.java:118)
   at org.apache.ibatis.session.defaults.DefaultSqlSession.insert(DefaultSqlSession.java:107)
   at sun.reflect.GeneratedMethodAccessor393.invoke(Unknown Source)
   at java.lang.reflect.Method.invoke(Method.java:606)
   at org.mybatis.spring.SqlSessionTemplate$SqlSessionInterceptor.invoke(SqlSessionTemplate.java:338)
