Problem with JBPMSpringActionHandler
bcoulson
All
I am attempting to connect to my Java class from within an advanced worfklow step. I have defined my process definition as follows.
<process-definition  xmlns="urn:jbpm.org:jpdl-3.1"  name="scwf:publishDocument">
<swimlane name="initiator"/>
   <start-state name="Start">
      <task name="scwf:assignWorkflow" swimlane="initiator"/>
      <transition to="AnalystTask" name="toAnalyst"></transition>
   </start-state>
   <task-node name="AnalystTask">
      <task name="scwf:createDocument" swimlane="initiator">
         <event type="task-create">
            <script>
               if (bpm_workflowDueDate != void) taskInstance.dueDate = bpm_workflowDueDate;
                  if (bpm_workflowPriority != void) taskInstance.priority = bpm_workflowPriority;
            </script>
         </event>
      </task>
      <transition to="TeamLeadTask" name="toTeamLead">
           <action class="gov.dhs.ipds.alfresco.AlfrescoHelper" config-type="bean" name="reviewChanges"/>
      </transition>
   </task-node>
   <task-node name="TeamLeadTask">
      <task name="scwf:reviewDocument" swimlane="initiator">
            <script>
            </script>
         </event>
      </task>
      <transition to="End" name="toProduction">
      </transition>
   </task-node>
   <end-state name="End"></end-state>
</process-definition>
And my Java code is as follows
package gov.dhs.ipds.alfresco;
import org.alfresco.repo.workflow.jbpm.JBPMSpringActionHandler;
import org.springframework.beans.factory.BeanFactory;
import org.jbpm.graph.exe.ExecutionContext;
public class AlfrescoHelper extends  JBPMSpringActionHandler {
   private static final long serialVersionUID = 1000L;
   public void execute(ExecutionContext ctx) throws Exception {
      System.out.println("Inside AlfrescoHelp.execute()");
   public AlfrescoHelper() {
      System.out.println("Inside AlfrescoHelper()");
   @Override
   protected void initialiseHandler(BeanFactory factory) {
      System.out.println("Inside AlfrescoHelper.initialiseHandler()");
When I attempt to execute the workflow task that instantiates the Java action class, I get the following exception(s) in my logfile.
09:06:44,209  ERROR [web.context.ContextLoader] Context initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'gov.dhs.ipds.alfresco.AlfrescoHelper' defined in file [C:\Alfresco\tomcat\shared\classes\alfresco\extension\someco-model-context.xml]: Instantiation of bean failed; nested exception is org.springframework.beans.BeanInstantiationException: Could not instantiate bean class [gov.dhs.ipds.alfresco.AlfrescoHelper]: Constructor threw exception; nested exception is java.lang.NullPointerException
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.instantiateBean(AbstractAutowireCapableBeanFactory.java:946)
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:890)
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:479)
   at org.springframework.web.context.ContextLoader.createWebApplicationContext(ContextLoader.java:261)
   at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:192)
   at org.apache.catalina.startup.HostConfig.deployDescriptor(HostConfig.java:637)
   at org.apache.catalina.startup.HostConfig.deployDescriptors(HostConfig.java:563)
   at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:498)
Caused by: org.springframework.beans.BeanInstantiationException: Could not instantiate bean class [gov.dhs.ipds.alfresco.AlfrescoHelper]: Constructor threw exception; nested exception is java.lang.NullPointerException
   at org.springframework.beans.BeanUtils.instantiateClass(BeanUtils.java:141)
   at org.springframework.beans.factory.support.SimpleInstantiationStrategy.instantiate(SimpleInstantiationStrategy.java:72)
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.instantiateBean(AbstractAutowireCapableBeanFactory.java:938)
   … 38 more
   at org.springmodules.workflow.jbpm31.JbpmFactoryLocator.useBeanFactory(JbpmFactoryLocator.java:162)
   at org.alfresco.repo.workflow.jbpm.JBPMSpringActionHandler.<init>(JBPMSpringActionHandler.java:46)
   at gov.dhs.ipds.alfresco.AlfrescoHelper.<init>(AlfrescoHelper.java:15)
   at org.springframework.beans.BeanUtils.instantiateClass(BeanUtils.java:126)
   … 40 more
I cannot see what I am doing wrong nor have I been able to find any information in the forums here or on Spring or jBpm to determine what I am doing wrong. I have not added a Spring bean for my Java class. When I do add a bean for it, I get the same exception above so I just get it sooner rather than later - basically at instantiation time.
Any help would be greatly appreciated.
39 REPLIES 39
bcoulson
Here is my log file. I did not see any reference to default beanFactory.  Due to the amount of logging, the file is quite large so I have not included the entire file here. If you need me to, I can do so.
11:31:23,228 DEBUG [org.springframework.beans.factory.support.DefaultListableBeanFactory] Returning cached instance of singleton bean 'localAuthenticationService'
11:31:23,228 DEBUG [org.springframework.orm.hibernate3.HibernateTransactionManager] Found thread-bound Session [org.hibernate.impl.SessionImpl@1926cb6] for Hibernate transaction
11:31:23,228 DEBUG [org.springframework.orm.hibernate3.HibernateTransactionManager] Participating in existing transaction
11:31:23,228 DEBUG [org.springframework.orm.hibernate3.HibernateTransactionManager] Suspending current transaction
11:31:23,228 DEBUG [org.springframework.orm.hibernate3.HibernateTransactionManager] Resuming suspended transaction after completion of inner transaction
11:31:23,244 DEBUG [org.springframework.orm.hibernate3.HibernateTemplate] Found thread-bound Session for HibernateTemplate
11:31:23,244 DEBUG [org.springframework.orm.hibernate3.HibernateTemplate] Not closing pre-bound Hibernate Session after HibernateTemplate
11:31:23,275 DEBUG [org.springframework.orm.hibernate3.HibernateTemplate] Not closing pre-bound Hibernate Session after HibernateTemplate
11:31:23,275 DEBUG [org.springframework.orm.hibernate3.HibernateTemplate] Found thread-bound Session for HibernateTemplate
11:31:23,681 ERROR [org.jbpm.instantiation.FieldInstantiator] couldn't instantiate type 'gov.dhs.ipds.alfresco.AlfrescoHelper' with the default constructor
11:31:23,681 ERROR [org.jbpm.instantiation.Delegation] couldn't instantiate delegation class 'gov.dhs.ipds.alfresco.AlfrescoHelper'
org.jbpm.JbpmException: java.lang.NullPointerException
   at org.jbpm.instantiation.FieldInstantiator.newInstance(FieldInstantiator.java:110)
   at org.jbpm.instantiation.FieldInstantiator.instantiate(FieldInstantiator.java:52)
   at org.jbpm.instantiation.Delegation.instantiate(Delegation.java:168)
   at org.jbpm.instantiation.Delegation.getInstance(Delegation.java:126)
   at org.hibernate.proxy.pojo.cglib.CGLIBLazyInitializer.invoke(CGLIBLazyInitializer.java:157)
   at org.jbpm.instantiation.Delegation$$EnhancerByCGLIB$$401c6f28.getInstance(<generated>)
   at org.jbpm.graph.def.Action.execute(Action.java:128)
   at org.jbpm.graph.def.GraphElement.executeAction(GraphElement.java:284)
   at org.jbpm.graph.def.GraphElement.executeActions(GraphElement.java:241)
   at org.jbpm.graph.def.GraphElement.fireAndPropagateEvent(GraphElement.java:213)
   at org.jbpm.graph.def.GraphElement.fireEvent(GraphElement.java:196)
   at org.jbpm.graph.def.Transition.take(Transition.java:152)
   at org.jbpm.graph.def.Node.leave(Node.java:479)
   at org.jbpm.graph.node.TaskNode.leave(TaskNode.java:213)
   at org.jbpm.graph.node.TaskNode$$EnhancerByCGLIB$$7dd6a48c.leave(<generated>)
   at org.jbpm.graph.exe.Token.signal(Token.java:223)
   at org.jbpm.graph.exe.Token.signal(Token.java:188)
   at org.jbpm.graph.exe.Token$$EnhancerByCGLIB$$b45438ca.signal(<generated>)
   at org.jbpm.taskmgmt.exe.TaskInstance.end(TaskInstance.java:495)
   at org.alfresco.repo.workflow.jbpm.WorkflowTaskInstance.end(WorkflowTaskInstance.java:135)
   at org.jbpm.taskmgmt.exe.TaskInstance.end(TaskInstance.java:436)
   at org.alfresco.repo.workflow.jbpm.JBPMEngine$26.doInJbpm(JBPMEngine.java:1833)
   at org.springframework.orm.hibernate3.HibernateTemplate.doExecute(HibernateTemplate.java:406)
   at org.springframework.orm.hibernate3.HibernateTemplate.execute(HibernateTemplate.java:339)
   at org.alfresco.repo.workflow.jbpm.JBPMEngine.endTask(JBPMEngine.java:1798)
   at org.alfresco.repo.workflow.WorkflowServiceImpl.endTask(WorkflowServiceImpl.java:648)
   at org.alfresco.repo.workflow.TaskUpdater.transition(TaskUpdater.java:133)
   at org.alfresco.repo.forms.processor.workflow.TaskFormPersister.persist(TaskFormPersister.java:175)
   at org.alfresco.repo.forms.processor.workflow.TaskFormPersister.persist(TaskFormPersister.java:45)
   at org.alfresco.repo.forms.processor.workflow.AbstractWorkflowFormProcessor.internalPersist(AbstractWorkflowFormProcessor.java:74)
   at org.alfresco.repo.forms.processor.FilteredFormProcessor.persist(FilteredFormProcessor.java:131)
   at org.alfresco.repo.forms.FormServiceImpl.saveForm(FormServiceImpl.java:138)
   at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:307)
   at org.alfresco.repo.security.permissions.impl.AlwaysProceedMethodInterceptor.invoke(AlwaysProceedMethodInterceptor.java:34)
   at org.alfresco.repo.security.permissions.impl.ExceptionTranslatorMethodInterceptor.invoke(ExceptionTranslatorMethodInterceptor.java:44)
   at org.alfresco.repo.audit.AuditMethodInterceptor.proceed(AuditMethodInterceptor.java:167)
   at org.alfresco.repo.audit.AuditMethodInterceptor.invoke(AuditMethodInterceptor.java:137)
   at org.springframework.transaction.interceptor.TransactionInterceptor.invoke(TransactionInterceptor.java:107)
   at $Proxy120.saveForm(Unknown Source)
   at org.alfresco.repo.forms.script.ScriptFormService.saveForm(ScriptFormService.java:152)
   at org.mozilla.javascript.NativeJavaMethod.call(NativeJavaMethod.java:243)
   at org.mozilla.javascript.Interpreter.interpretLoop(Interpreter.java:3237)
   at org.mozilla.javascript.Interpreter.interpret(Interpreter.java:2394)
   at org.mozilla.javascript.InterpretedFunction.call(InterpretedFunction.java:162)
   at org.mozilla.javascript.InterpretedFunction.exec(InterpretedFunction.java:173)
   at org.alfresco.repo.jscript.RhinoScriptProcessor.executeScriptImpl(RhinoScriptProcessor.java:472)
   at org.alfresco.repo.jscript.RhinoScriptProcessor.execute(RhinoScriptProcessor.java:190)
   at org.alfresco.repo.processor.ScriptServiceImpl.executeScript(ScriptServiceImpl.java:282)
   at org.alfresco.repo.web.scripts.RepositoryScriptProcessor.executeScript(RepositoryScriptProcessor.java:102)
   at org.springframework.extensions.webscripts.AbstractWebScript.executeScript(AbstractWebScript.java:981)
   at org.springframework.extensions.webscripts.DeclarativeWebScript.execute(DeclarativeWebScript.java:86)
   at org.alfresco.repo.web.scripts.RepositoryContainer$2.execute(RepositoryContainer.java:383)
   at org.alfresco.repo.transaction.RetryingTransactionHelper.doInTransaction(RetryingTransactionHelper.java:381)
   at org.alfresco.repo.web.scripts.RepositoryContainer.transactionedExecute(RepositoryContainer.java:436)
   at org.alfresco.repo.web.scripts.RepositoryContainer.transactionedExecuteAs(RepositoryContainer.java:466)
   at org.alfresco.repo.web.scripts.RepositoryContainer.executeScript(RepositoryContainer.java:304)
   at org.springframework.extensions.webscripts.AbstractRuntime.executeScript(AbstractRuntime.java:333)
   at org.springframework.extensions.webscripts.AbstractRuntime.executeScript(AbstractRuntime.java:189)
   at org.alfresco.web.app.servlet.GlobalLocalizationFilter.doFilter(GlobalLocalizationFilter.java:58)
   at org.apache.coyote.http11.Http11AprProcessor.process(Http11AprProcessor.java:859)
   at org.apache.coyote.http11.Http11AprProtocol$Http11ConnectionHandler.process(Http11AprProtocol.java:579)
   at org.apache.tomcat.util.net.AprEndpoint$Worker.run(AprEndpoint.java:1555)
   at gov.dhs.ipds.alfresco.AlfrescoHelper.<init>(AlfrescoHelper.java:7)
   at java.lang.Class.newInstance0(Class.java:355)
   at java.lang.Class.newInstance(Class.java:308)
   at org.jbpm.instantiation.FieldInstantiator.newInstance(FieldInstantiator.java:107)
   … 108 more
What should I have debug level logging turned on for? I have it turned on for quite a few components, including Spring framework. Here is my log4j.properties file.
# Set root logger level to error
log4j.rootLogger=error, Console, File
###### Console appender definition #######
# All outputs currently set to be a ConsoleAppender.
log4j.appender.Console=org.apache.log4j.ConsoleAppender
log4j.appender.Console.layout=org.apache.log4j.PatternLayout
# use log4j NDC to replace %x with tenant domain / username
log4j.appender.Console.layout.ConversionPattern=%d{ABSOLUTE} %x %-5p [%c{3}] %m%n
#log4j.appender.Console.layout.ConversionPattern=%d{ABSOLUTE} %-5p [%c] %m%n
###### File appender definition #######
log4j.appender.File=org.apache.log4j.DailyRollingFileAppender
log4j.appender.File.File=c:/alfresco/alfresco.log
log4j.appender.File.Append=true
log4j.appender.File.DatePattern='.'yyyy-MM-dd
log4j.appender.File.layout=org.apache.log4j.PatternLayout
log4j.appender.File.layout.ConversionPattern=%d{ABSOLUTE} %-5p [%c] %m%n
###### Hibernate specific appender definition #######
#log4j.appender.file=org.apache.log4j.FileAppender
#log4j.appender.file.File=hibernate.log
#log4j.appender.file.layout=org.apache.log4j.PatternLayout
#log4j.appender.file.layout.ConversionPattern=%d{ABSOLUTE} %5p %c{1}:%L - %m%n
###### Log level overrides #######
# Commented-in loggers will be exposed as JMX MBeans (refer to org.alfresco.repo.admin.Log4JHierarchyInit)
# Hence, generally useful loggers should be listed with at least ERROR level to allow simple runtime
# control of the level via a suitable JMX Console. Also, any other loggers can be added transiently via
# Log4j addLoggerMBean as long as the logger exists and has been loaded.
# Hibernate
log4j.logger.org.hibernate=error
log4j.logger.org.hibernate.util.JDBCExceptionReporter=fatal
log4j.logger.org.hibernate.event.def.AbstractFlushingEventListener=fatal
log4j.logger.org.hibernate.type=warn
log4j.logger.org.hibernate.cfg.SettingsFactory=warn
# Spring
#log4j.logger.org.springframework=warn
log4j.logger.org.springframework=debug
# Turn off Spring remoting warnings that should really be info or debug.
log4j.logger.org.springframework.remoting.support=error
log4j.logger.org.springframework.util=error
# Axis/WSS4J
log4j.logger.org.apache.axis=info
log4j.logger.org.apache.ws=info
# CXF
log4j.logger.org.apache.cxf=error
# MyFaces
log4j.logger.org.apache.myfaces.util.DebugUtils=info
log4j.logger.org.apache.myfaces.el.VariableResolverImpl=error
log4j.logger.org.apache.myfaces.application.jsp.JspViewHandlerImpl=error
log4j.logger.org.apache.myfaces.taglib=error
# OpenOfficeConnection
log4j.logger.net.sf.jooreports.openoffice.connection=fatal
# log prepared statement cache activity ###
log4j.logger.org.hibernate.ps.PreparedStatementCache=info
# Alfresco
log4j.logger.org.alfresco=error
log4j.logger.org.alfresco.repo.admin=info
log4j.logger.org.alfresco.repo.cache.TransactionalCache=warn
log4j.logger.org.alfresco.repo.model.filefolder=info
log4j.logger.org.alfresco.repo.tenant=info
log4j.logger.org.alfresco.repo.avm=info
log4j.logger.org.alfresco.config=info
log4j.logger.org.alfresco.config.JndiObjectFactoryBean=warn
log4j.logger.org.alfresco.config.JBossEnabledWebApplicationContext=warn
log4j.logger.org.alfresco.repo.management.subsystems=info
log4j.logger.org.alfresco.repo.management.subsystems.ChildApplicationContextFactory$ChildApplicationContext=warn
log4j.logger.org.alfresco.repo.security.sync=info
log4j.logger.org.alfresco.repo.security.person=info
log4j.logger.org.alfresco.sample=info
log4j.logger.org.alfresco.web=info
#log4j.logger.org.alfresco.web.app.AlfrescoNavigationHandler=debug
#log4j.logger.org.alfresco.web.ui.repo.component.UIActions=debug
#log4j.logger.org.alfresco.web.ui.repo.tag.PageTag=debug
#log4j.logger.org.alfresco.web.bean.clipboard=debug
log4j.logger.org.alfresco.repo.webservice=info
log4j.logger.org.alfresco.service.descriptor.DescriptorService=info
#log4j.logger.org.alfresco.web.page=debug
log4j.logger.org.alfresco.repo.importer.ImporterBootstrap=error
#log4j.logger.org.alfresco.repo.importer.ImporterBootstrap=info
log4j.logger.org.alfresco.web.ui.common.Utils=error
#log4j.logger.org.alfresco.web.ui.common.Utils=info
log4j.logger.org.alfresco.repo.admin.patch.PatchExecuter=info
log4j.logger.org.alfresco.repo.domain.patch.ibatis.PatchDAOImpl=info
# Specific patches
log4j.logger.org.alfresco.repo.admin.patch.impl.DeploymentMigrationPatch=info
log4j.logger.org.alfresco.repo.version.VersionMigrator=info
log4j.logger.org.alfresco.repo.admin.patch.impl.ResetWCMToGroupBasedPermissionsPatch=info
log4j.logger.org.alfresco.repo.module.ModuleServiceImpl=info
log4j.logger.org.alfresco.repo.domain.schema.SchemaBootstrap=info
log4j.logger.org.alfresco.repo.admin.ConfigurationChecker=info
log4j.logger.org.alfresco.repo.node.index.AbstractReindexComponent=warn
log4j.logger.org.alfresco.repo.node.index.IndexTransactionTracker=warn
log4j.logger.org.alfresco.repo.node.index.FullIndexRecoveryComponent=info
log4j.logger.org.alfresco.repo.node.index.AVMFullIndexRecoveryComponent=info
log4j.logger.org.alfresco.util.OpenOfficeConnectionTester=info
log4j.logger.org.alfresco.repo.node.db.hibernate.HibernateNodeDaoServiceImpl=warn
log4j.logger.org.alfresco.repo.domain.hibernate.DirtySessionMethodInterceptor=warn
log4j.logger.org.alfresco.repo.transaction.RetryingTransactionHelper=warn
log4j.logger.org.alfresco.util.transaction.SpringAwareUserTransaction.trace=warn
log4j.logger.org.alfresco.repo.jgroups.AlfrescoJGroupsChannelFactory=info
log4j.logger.org.alfresco.enterprise.repo.cache.jgroups.JGroupsKeepAliveHeartbeatReceiver=info
log4j.logger.org.alfresco.repo.version.Version2ServiceImpl=warn
#log4j.logger.org.alfresco.web.app.DebugPhaseListener=debug
#log4j.logger.org.alfresco.repo.cache.EhCacheTracerJob=debug
log4j.logger.org.alfresco.repo.workflow=debug
#log4j.logger.org.alfresco.repo.workflow=error
#log4j.logger.org.alfresco.repo.workflow=info
# CIFS server debugging
log4j.logger.org.alfresco.smb.protocol=error
#log4j.logger.org.alfresco.smb.protocol.auth=debug
#log4j.logger.org.alfresco.acegi=debug
# FTP server debugging
log4j.logger.org.alfresco.ftp.protocol=error
#log4j.logger.org.alfresco.ftp.server=debug
# WebDAV debugging
#log4j.logger.org.alfresco.webdav.protocol=debug
log4j.logger.org.alfresco.webdav.protocol=error
# NTLM servlet filters
#log4j.logger.org.alfresco.web.app.servlet.NTLMAuthenticationFilter=debug
#log4j.logger.org.alfresco.repo.webdav.auth.NTLMAuthenticationFilter=debug
# Kerberos servlet filters
#log4j.logger.org.alfresco.web.app.servlet.KerberosAuthenticationFilter=debug
#log4j.logger.org.alfresco.repo.webdav.auth.KerberosAuthenticationFilter=debug
# File servers
log4j.logger.org.alfresco.fileserver=warn
# Repo filesystem debug logging
#log4j.logger.org.alfresco.filesys.repo.ContentDiskDriver=debug
# AVM filesystem debug logging
#log4j.logger.org.alfresco.filesys.avm.AVMDiskDriver=debug
# Integrity message threshold - if 'failOnViolation' is off, then WARNINGS are generated
log4j.logger.org.alfresco.repo.node.integrity=ERROR
# Indexer debugging
log4j.logger.org.alfresco.repo.search.Indexer=error
#log4j.logger.org.alfresco.repo.search.Indexer=debug
log4j.logger.org.alfresco.repo.search.impl.lucene.index=error
#log4j.logger.org.alfresco.repo.search.impl.lucene.index=DEBUG
# Audit debugging
# log4j.logger.org.alfresco.repo.audit=DEBUG
# log4j.logger.org.alfresco.repo.audit.model=DEBUG
# Forms debugging
# log4j.logger.org.alfresco.web.forms=debug
# log4j.logger.org.chiba.xml.xforms=debug
log4j.logger.org.alfresco.web.forms.xforms.XFormsBean=error
log4j.logger.org.alfresco.web.forms.XSLTRenderingEngine=error
# Property sheet and modelling debugging
# change to error to hide the warnings about missing properties and associations
log4j.logger.alfresco.missingProperties=warn
log4j.logger.org.alfresco.web.ui.repo.component.property.UIChildAssociation=warn
log4j.logger.org.alfresco.web.ui.repo.component.property.UIAssociation=warn
#log4j.logger.org.alfresco.web.ui.repo.component.property=debug
# Dictionary/Model debugging
log4j.logger.org.alfresco.repo.dictionary=warn
log4j.logger.org.alfresco.repo.dictionary.types.period=warn
# Virtualization Server Registry
log4j.logger.org.alfresco.mbeans.VirtServerRegistry=error
# Spring context runtime property setter
log4j.logger.org.alfresco.util.RuntimeSystemPropertiesSetter=info
# Debugging options for clustering
log4j.logger.org.alfresco.repo.content.ReplicatingContentStore=error
log4j.logger.org.alfresco.repo.content.replication=error
#log4j.logger.org.alfresco.repo.deploy.DeploymentServiceImpl=debug
# Activity service
log4j.logger.org.alfresco.repo.activities=info
# User usage tracking
log4j.logger.org.alfresco.repo.usage=info
# Sharepoint
log4j.logger.org.alfresco.module.vti=info
# Forms Engine
log4j.logger.org.alfresco.repo.forms=info
log4j.logger.org.alfresco.web.config.forms=info
log4j.logger.org.alfresco.web.scripts.forms=info
# CMIS
log4j.logger.org.alfresco.cmis=error
log4j.logger.org.alfresco.cmis.dictionary=warn
# IMAP
log4j.logger.org.alfresco.repo.imap=info
# JBPM
# Note: non-fatal errors (eg. logged during job execution) should be handled by Alfresco's retrying transaction handler
log4j.logger.org.jbpm.graph.def.GraphElement=fatal
#log4j.logger.org.alfresco.repo.googledocs=debug
###### Scripting #######
# Web Framework
#log4j.logger.org.springframework.extensions.webscripts=error
#log4j.logger.org.springframework.extensions.webscripts.ScriptLogger=error
#log4j.logger.org.springframework.extensions.webscripts.ScriptDebugger=off
log4j.logger.org.springframework.extensions.webscripts=debug
log4j.logger.org.springframework.extensions.webscripts.ScriptLogger=debug
log4j.logger.org.springframework.extensions.webscripts.ScriptDebugger=on
# Repository
log4j.logger.org.alfresco.repo.web.scripts=info
log4j.logger.org.alfresco.repo.web.scripts.BaseWebScriptTest=info
log4j.logger.org.alfresco.repo.web.scripts.AlfrescoRhinoScriptDebugger=on
log4j.logger.org.alfresco.repo.jscript=debug
log4j.logger.org.alfresco.repo.jscript.ScriptLogger=debug
log4j.logger.org.alfresco.repo.cmis.rest.CMISTest=info
log4j.logger.org.alfresco.repo.avm.actions=info
# Freemarker
# Note the freemarker.runtime logger is used to log non-fatal errors that are handled by Alfresco's retrying transaction handler
log4j.logger.freemarker.runtime=
# Temporary check in.
log4j.logger.org.alfresco.repo.avm.AVMSyncServiceImpl=info
log4j.logger.org.alfresco.repo.avm.AVMServiceLocalTest=debug
mcook
It needs to be enabled for JbpmFactoryLocator.class.
Also can you repost your processdefinition.xml?
bcoulson
Ok
I still am not seeing anything in my logfile - can you please confirm that I have the correct entry. Here is the entry I added to my log4j.properties
log4j.logger.org.springmodules.workflow.jbpm31.JbpmFactoryLocator=debug
here is my processdefinition.xml file
   </start-state>
            <script>
            </script>
         </event>
      </task>
           <action class="gov.dhs.ipds.alfresco.AlfrescoHelper" name="reviewChanges"/>
      </transition>
   </task-node>
            <script>
            </script>
         </event>
      </task>
      </transition>
   </task-node>
bcoulson
Ok - my alfresco.log file is a beast but I do see default BeanFactory and have extracted that line. Here it is.
12:22:02,259 DEBUG [org.springmodules.workflow.jbpm31.JbpmFactoryLocator] default beanFactoryReference=org.springframework.beans.factory.support.DefaultListableBeanFactory@1e22632: defining beans [internalEHCacheManager,propertyValueSharedCache,propertyValueCache,contentDataSharedCache,contentDataCache,immutableEntitySharedCache,immutableEntityCache,node.rootNodesSharedCache,node.rootNodesCache,node.nodesSharedCache,node.nodesCache,node.aspectsSharedCache,node.aspectsCache,node.propertiesSharedCache,node.propertiesCache,node.parentAssocsSharedCache,node.parentAssocsCache,nodeRulesSharedCache,nodeRulesCache,userToAuthoritySharedCache,userToAuthorityCache,authoritySharedCache,authorityLookupCache,permissionsAccessSharedCache,permissionsAccessCache,readersSharedCache,readersCache,nodeOwnerSharedCache,nodeOwnerCache,personSharedCache,personCache,ticketsCache,avmStoreSharedCache,avmStoreCache,avmEntitySharedCache,avmEntityCache,avmVersionRootEntitySharedCache,avmVersionRootEntityCache,avmNodeSharedCache,avmNodeCache,avmNodeAspectsSharedCache,avmNodeAspectsCache,webServicesQuerySessionSharedCache,webServicesQuerySessionCache,aclSharedCache,aclCache,aclEntitySharedCache,aclEntityCache,authorityEntitySharedCache,authorityEntityCache,permissionEntitySharedCache,permissionEntityCache,resourceBundleBaseNamesSharedCache,resourceBundleBaseNamesCache,loadedResourceBundlesSharedCache,loadedResourceBundlesCache,messagesSharedCache,messagesCache,compiledModelsSharedCache,compiledModelsCache,prefixesSharedCache,prefixesCache,webScriptsRegistrySharedCache,webScriptsRegistryCache,routingContentStoreSharedCache,routingContentStoreCache,executingActionsCache,tenantService,hostConfigurableSocketFactory,baseServiceExporter,runtimeProperties,legacyConfigPostProcessor,global-properties,common-placeholder-configurer,repository-properties,shared-properties,clusterPropertySetter,alfrescoMBeanServer,registry,jmxUrlPattern,jmxUrl,serverConnector,propertyBackedBeanRegistry,abstractPropertyBackedBean,exporter,VirtServerRegistry,log4JHierarchyInit,RepoServerMgmt,defaultDataSource,dataSource,transactionService,retryingTransactionHelper,web.retryingTransactionHelper,retryingWriteTxnAdvice,retryingReadTxnAdvice,checkTxnAdvice,resourceBundles,messageService,indexerComponent,searchService,admSearchService,versionSearchService,indexerAndSearcherFactory,categoryService,indexThreadPoolExecutor,lucene.fts.alfresco,abstractLuceneIndexerAndSearcherFactory,admLuceneIndexerAndSearcherFactory,adm.luceneQueryEngineImpl,admLuceneUnIndexedIndexerAndSearcherFactory,avmLuceneIndexerAndSearcherFactory,avm.luceneQueryEngineImpl,luceneCategoryService,lockService,versionService,versionNodeService,serialVersionLabelPolicy,registerContentWithVersionService,registerMLContainerWithVersionService,versionMigrator,versionableAspect,cm:constraintRegistry,namespaceDAO,dictionaryDAO,dictionaryService,namespaceService,dictionaryModelBootstrap,dictionaryBootstrap,extension.dictionaryBootstrap,copyService,checkOutCheckInService,workingCopyAspect,discussableAspect,LuceneFullTextSearchIndexer,luceneFullTextSearchIndexer,luceneIndexBackupComponent,queryRegisterComponent,multilingualDocumentAspect,emptyTranslationAspect,mlContainerType,referenceableAspect,temporaryAspect,configurableService,registryService,serverDescriptorDAO,currentRepoDescriptorDAO,installedRepoDescriptorDAO,jobLockService,sysAdminParams,applicationEventMulticaster,permissionsModelDAO,permissionService,permissionServiceImpl,ownerDynamicAuthority,lockOwnerDynamicAuthority,permissionModelBootstrap,roleVoter,groupVoter,aclEntryVoter,accessDecisionManager,afterAcl,afterInvocationManager,NamespaceService_security,DictionaryService_security,NodeService_security,FileFolderService_security,ContentService_security,MimetypeService_security,SearchService_security,CategoryService_security,CopyService_security,LockService_security,VersionService_security,MultilingualContentService_security,EditionService_security,CheckoutCheckinService_security,RuleService_security,ImporterService_security,ActionService_security,PermissionService_security,AuthorityService_security,AuthenticationService_security,OwnableService_security,PersonService_security,TemplateService_security,ScriptService_security,WorkflowService_security,AuditService_security,RepoAdminService_security,ContentUsageService_security,PublicServiceAccessService_security,ServiceRegistry,exceptionTranslator,DescriptorService,AuditMethodInterceptor,NodeService,NodeService_transaction,ContentService,ContentService_transaction,SearchService,ADMSearchService,SearchService_transaction,CategoryService,CategoryService_transaction,CopyService,CopyService_transaction,LockService,LockService_transaction,VersionService,VersionService_transaction,CheckoutCheckinService,CheckoutCheckinService_transaction,RuleService,RuleService_transaction,ImporterService,ImporterService_transaction,ExporterService,ExporterService_transaction,ActionService,ActionService_transaction,PermissionService,PermissionService_transaction,AuthorityService,AuthorityService_transaction,OwnableService,OwnableService_transaction,PersonService,PersonService_transaction,ContentUsageService,ContenUsageService_transaction,AuthenticationService,AuthenticationService_transaction,TemplateService,TemplateService_transaction,ScriptService,ScriptService_transaction,FileFolderService,FileFolderService_transaction,crossRepositoryCopyService,crossRepositoryCopyServiceWriteTxnAdvisor,CrossRepositoryCopyService,avmLockingAwareService,AVMLockingAwareService,indexingAVMLockingAwareService,avmService,avmServiceMT,avmServiceBase,checkTxnAdvisor,avmServiceReadTxnAdvisor,avmServiceWriteTxnAdvisor,AVMService,indexingAVMService,avmSnapShotTriggeredIndexingMethodInterceptor,avmSyncService,avmSyncServiceReadTxnAdvisor,avmSyncServiceWriteTxnAdvisor,AVMSyncService,attributeServiceReadTxnAdvisor,attributeServiceWriteTxnAdvisor,AttributeService,avmLockingServiceReadTxnAdvisor,avmLockingServiceWriteTxnAdvisor,AVMLockingService,WorkflowService,WorkflowService_transaction,AuditService,AuditService_transaction,MultilingualContentService,MultilingualContentService_transaction,EditionService,EditionService_transaction,ConfigurableService,ConfigurableService_transaction,RegistryService,RegistryService_transaction,ModuleService,ModuleService_transaction,RepoAdminService,RepoAdminService_transaction,ScheduledPersistedActionService,ScheduledPersistedActionService_transaction,ScheduledPersistedActionService_security,PublicServiceAccessService,PublicServiceAccessService_transaction,publicServiceAccessService,fileFolderService,mlTranslationInterceptor,mlContentInterceptor,tempFileMarkerInterceptor,multilingualContentService,editionService,ImapService,defaultAsyncThreadPool,deploymentAsyncThreadPool,baseActionFilter,defaultAsynchronousActionExecutionQueue,deploymentAsynchronousActionExecutionQueue,actionService,actionTrackingService,actionTrackingServiceScript,scheduledPersistedActionService,actionsAspect,actionResourceBundles,action-constraint,ac-compare-operations,ac-content-properties,ac-mimetypes,ac-types,ac-aspects,ac-properties,ac-email-templates,ac-scripts,action-condition-evaluator,no-condition,compare-property-value,compare-date-property,compare-integer-property,compare-text-property,compare-mime-type,in-category,is-subtype,has-aspect,has-tag,has-version-history,composite-condition,action-executer,composite-action,create-version,add-features,remove-features,specialise-type,link-category,simple-workflow,transform,transform-image,copy,copy-to-web-project,move,check-in,check-out,mail,mailService,set-property-value,extract-metadata,import,export,repository-export,script,counter,execute-all-rules,simple-avm-submit,start-avm-workflow,simple-avm-promote,avm-revert-store,avm-revert-list,avm-revert-to-version,avm-undo-list,avm-deploy-website,count-children,link-rules,unlink-rules,reorder-rules,accept-simpleworkflow,reject-simpleworkflow,baseTemplateActionDefintion,ruleService,rulesAspect,ruleResourceBundles,rule-type-base,inbound,update,outbound,rule-trigger-base,on-create-node-trigger,on-update-node-trigger,on-property-update-trigger,on-create-child-association-trigger,on-delete-child-association-trigger,on-delete-node-trigger,on-create-association-trigger,on-delete-association-trigger,on-content-update-trigger,on-content-create-trigger,on-content-restore-trigger,mlPropertyInterceptor,nodeRefPropertyInterceptor,multiTNodeServiceInterceptor,nodeService,mlAwareNodeService,mtAwareNodeService,storeArchiveMap,nodeArchiveService,avmNodeService,integrityChecker,incompleteNodeTagger,nodeIndexer,nodeCleanupRegistry,nodeCleanupBase,nodeCleanup.deletedNodeCleanup,dbNodeService,nodeAuditor,resourceFinder,schedulerResources,schedulerProperties,schedulerFactory,cifsAuthenticatorBase,ftpAuthenticatorBase,fileServerConfigurationBase,contentDiskDriver,nodeMonitorFactory,cifsHelper,avmDiskDriver,fileContentStore,deletedContentStore,deletedContentBackupListener,deletedContentBackupListeners,contentStoreCleaner,eagerContentStoreCleaner,baseContentService,contentService,charset.finder,mimetypeConfigService,mimetypeService,contentFilterLanguagesConfigService,contentFilterLanguagesService,metadataExtracterRegistry,baseMetadataExtracter,extracter.worker.OpenOffice,extracter.TikaAuto,extracter.PDFBox,extracter.Poi,extracter.Office,extracter.Mail,extracter.Html,extracter.MP3,extracter.OpenDocument,extracter.DWG,extracter.RFC822,extracter.OpenOffice,contentTransformerRegistry,baseContentTransformer,failover.transformer.PdfRenderer.PdfToImage,failover.transformer.PdfBox.PdfToImage,transformer.StringExtracter,transformer.BinaryPassThrough,transformer.PdfBox,transformer.PdfToImage,transformer.complex.PDF.Image,transformer.complex.OpenOffice.Image,transformer.PdfBox.TextToPdf,transformer.complex.Text.Image,transformer.TikaAuto,transformer.Poi,transformer.Office,transformer.OOXML,transformer.TextMining,transformer.HtmlParser,transformer.MediaWikiParser,transformer.worker.OpenOffice,transformer.OpenOffice,transformer.complex.OpenOffice.PdfBox,transformer.OutlookMsg,transformer.RFC822,transformer.worker.ImageMagick,transformer.ImageMagick,transformer.Archive,tenantAdminService,controlDAO,controlDAO.org.hibernate.dialect.Dialect,controlDAO.org.hibernate.dialect.PostgreSQLDialect,postDAO,feedDAO,feedControlDAO,patchDAO,appliedPatchDAO,qnameDAO,nodeDAO,lockDAO,mimetypeDAO,encodingDAO,localeDAO,contentDataDAO,propertyValueDAO,auditDAO,newAvmStoreDAO,newAvmNodeDAO,newAvmNodeLinksDAO,newAvmVersionRootDAO,avmLockDAO,permissionsDaoComponent,avmPermissionsDaoComponent,admPermissionsDaoComponent,admNodeACLDAO,avmNodeACLDAO,aclCrudDAO,aclDAO,usageDAO,hibernateConfigProperties,cacheStrategiesPlaceholderConfigurer,sessionFactory,dialect,sessionFactoryBase,transactionManager,dialectResourceLoader,activitiesDataSource,activitiesDataSource_autoCommit,activitiesSqlMapClient,alfrescoSqlMapClient,repoSqlMapClientTemplate,locksSqlMapClientTemplate,contentSqlMapClientTemplate,propertyValueSqlMapClientTemplate,auditSqlMapClientTemplate,avmSqlMapClientTemplate,activityPostService,activityService,feedCleaner,postCleaner,postLookup,baseFeedGenerator,feedGenerator,feedTaskProcessor,ownableService,templateService,baseTemplateProcessor,freeMarkerProcessor,xsltProcessor,baseTemplateImplementation,avmExtension,sessionTemplateExtension,classificationTemplateExtension,workflowTemplateExtension,peopleTemplateExtension,siteTemplateExtension,hasAspectTemplateExtension,hasPermissionTemplateExtension,messageTemplateExtension,dateCompareTemplateExtension,incrementDateTemplateExtension,xmlDateTemplateExtension,cropContentTemplateExtension,shortQNameTemplateExtension,scriptService,javaScriptProcessor,baseJavaScriptExtension,loggerScript,utilsScript,testScript,actionsScript,imapScript,searchScript,classificationScript,peopleScript,sessionScript,scriptBehaviour,avmScript,crossCopyScript,workflowScript,presenceScript,activitiesScript,indexTrackerThreadPoolExecutor,indexRecoveryComponentBase,indexRecoveryComponent,avmIndexRecoveryComponent,admIndexTrackerComponent,admIndexTrackerTrigger,avmIndexTrackerComponent,avmIndexTrackerTrigger,missingFullTextReindexComponent,missingFullTextReindexTrigger,authorityService,authorityDAO,authorityServiceScript,authenticationManager,authenticatedAuthenticationPassthroughProvider,Authentication,authenticationDao,SmbSessionListener,CifsAuthenticator,FtpAuthenticator,passwordEncoder,authenticationService,AuthenticationComponent,authenticationComponentBase,authenticationComponent,userRegistrySynchronizer,authenticationContext,userNameMatcher,personService,personServicePermissionsManager,homeFolderManager,baseHomeFolderProvider,companyHomeFolderProvider,guestHomeFolderProviderPermissionsManager,guestHomeFolderProvider,bootstrapHomeFolderProvider,defaultOnCreatePermissionsManager,defaultOnReferencePermissionsManager,personalHomeFolderProvider,userHomesHomeFolderProvider,ticketComponent,nameBasedUserNameGenerator,userNameGenerator,passwordGenerator,authenticationUtil,usageService,usageServiceImpl,contentUsageImpl,usageQuotaProtector,policyBehaviourQueue,policyTransactionHandlerFactory,policyBehaviourFilter,unboundPolicyBehaviourFilter,policyComponent,policyRegistration,dictionaryModelType,viewParser,importerComponent,importerComponentWithBehaviour,exporterComponent,repositoryExporterComponent,systemExporterImporter,systemInfoImporter,storeImporter,storeImporterViews,storeImporterTransactionHelper,userStoreImporter,systemStoreImporter,spacesArchiveStoreImporter,spacesStoreImporter,versionStoreImporter,version2StoreImporter,systemInfoBootstrap-base,userBootstrap-base,systemBootstrap-base,versionBootstrap-base,version2Bootstrap-base,spacesArchiveBootstrap-base,spacesBootstrap-base,shutdownBackstop,schemaBootstrap,jgroupsChannelFactory,avmBootstrap,dictionaryRepositoryBootstrap,systemInfoBootstrap,userBootstrap,systemBootstrap,versionBootstrap,version2Bootstrap,spacesArchiveBootstrap,spacesModelsBootstrap,spacesBootstrap,siteAVMBootstrap,workflowBootstrap,multiTenantBootstrap,thirdparty,OOoDirect,indexRecoveryBootstrap,avmIndexRecoveryBootstrap,descriptorComponent,configurationChecker,patchExecuter,moduleStarter,sysAdmin,fileServers,fileServerConfiguration,imap,OutboundSMTP,InboundSMTP,googledocs,schedulerStarter,userUsageTrackingComponent,Synchronization,workflowScheduler,Audit,repositoryHelper,scheduledPersistedActionServiceBootstrap,startupLog,interpreterBase,repoAdminService,repoAdminInterpreter,repoAdminInterpreterHelp,customModelsRepositoryLocation,customMessagesRepositoryLocation,workflowDeployer,workflowServiceImpl,workflowPackageImpl,workflowInterpreter,workflowInterpreterHelp,start-workflow,bpm_engineRegistry,bpm_engine,jbpm_configuration,jbpm_template,jbpm_engine,workflowPatchDeployer,customWorkflowDefsRepositoryLocation,workflowDefinitionType,avmNodeDAO,avmStoreDAO,versionRootDAO,childEntryDAO,avmStorePropertyDAO,versionLayeredNodeEntryDAO,avmDAOs,lookupCache,rawServices,orphanReaper,createStoreTxnListener,purgeStoreTxnListener,createVersionTxnListener,purgeVersionTxnListener,avmRepository,avmRemote,AVMSubmitTransactionListener,excludeRegexMatcher,excludeExtensionMatcher,globalPathExcluder,avmExpiredContentProcessor,avmLockingService,WebProjectService,WebProjectService_transaction,WebProjectService_security,webProjectService,AssetService,AssetService_transaction,AssetService_security,assetService,mlPropertyInterceptorLockingAware,avmLockingAwareNodeService,mlAwareLockingAwareNodeService,SandboxService,SandboxService_transaction,SandboxService_security,sandboxService,sandboxFactory,webProjectsScript,WCMPreviewURIService,PreviewURIService_transaction,PreviewURIService_security,previewURIService,previewURIServiceRegistry,basePreviewURIServiceProvider,virtServerPreviewURIService,nullPreviewURIService,wcm-submit,wcm-revert-snapshot,wcm-undo,wcmServicesResourceBundles,auditService,auditComponent,publicServiceIdentifier,auditModel.extractorRegistry,auditModel.extractor.simpleValue,auditModel.extractor.nullValue,auditModel.extractor.nodeName,auditModel.extractor.nodeType,auditModel.generatorRegistry,auditModel.generator.time,auditModel.generator.user,auditModel.generator.personFullName,attributeService,deploymentTestTransformer,deploymentEncryptor,deploymentCompressor,rmiFSRAdapter,encryptedRMIFSRAdapter,compressEncryptedRMIFSRAdapter,springHttpFSRAdapter,deploymentService,deploymentServiceReadTxnAdvisor,deploymentServiceWriteTxnAdvisor,DeploymentService,siteService_dictionaryBootstrap,siteService_permissionBootstrap,SiteService,SiteService_transaction,SiteService_security,siteServiceResourceBundles,siteRoleComparator,siteService,siteServiceScript,TaggingService,TaggingService_transaction,TaggingService_security,taggingService,update-tagscope,refresh-tagscope,scriptTaggingService,invitationService,InvitationService_security,InvitationService_transaction,InvitationService,invitationResourceBundles,invitationServiceScript,PatchService,PatchService_transaction,patchComponent,basePatch,patch.sample.01,patch.sample.02,bootstrapSpacesMessageSource,patch.savedSearchesFolder,patch.savedSearchesPermission,patch.updatePermissionData,patch.guestUser,patch.fixNodeSerializableValues,patch.updateGuestPermission,patch.guestPersonPermission,patch.spacesRootPermission,patch.categoryRootPermission,patch.contentPermission,patch.updateForumsIcons,patch.emailTemplatesFolder,patch.emailTemplatesContent,patch.descriptorUpdate,patch.scriptsFolder,patch.topLevelGroupParentChildAssociationTypePatch,patch.actionRuleDecouplingPatch,patch.systemWorkflowFolderPatch,patch.rssTemplatesFolderPatch,patch.uifacetsTemplatesPatch,patch.guestPersonPermission2,patch.schemaUpdateScript-V1.4-1,patch.uniqueChildName,patch.schemaUpdateScript-V1.4-2,patch.InvalidNameEnding,patch.systemDescriptorContent,patch.versionHistoryPerformance,patch.multilingualBootstrap,patch.LinkNodeFileExtension,patch.systemRegistryBootstrap,patch.userAndPersonUserNamesAsIdentifiers,patch.contentFormFolderType,patch.db-V2.1-JBPMData,patch.db-V2.1-NotNullColumns,patch.groupNamesAsIdentifiers,patch.invalidUserPersonAndGroup,patch.AVMGuidPatch,patch.webscripts,patch.webscriptsExtension,patch.AVMLayeredSnapshot,patch.groupMembersAsIdentifiers,patch.redeploySubmitProcess,patch.ReadmeTemplate,patch.webScriptsReadme,patch.db-V2.1-JBPMProcessKey,patch.db-V2.1-VersionColumns2,patch.db-V1.4-TxnCommitTimeIndex,patch.db-V2.0-ContentUrls,patch.webscripts2,patch.customModels,patch.customMessages,patch.customWebClientExtension,patch.redeploySubmitProcess2,patch.db-V2.1-RemoveWcmSubmittedAspect,patch.webscripts3,patch.customWorkflowDefs,patch.avmStoreAsIdentifier,patch.avmFormPropertyIdentifier,patch.formsFolder,patch.tagRootCategory,patch.db-V3.4-UsageTables,patch.deploymentMigration,patch.redeploySubmitProcess3,patch.db-V2.2-ACL-From-2.1-A,patch.db-V2.2-ACL,patch.updateAvmPermissionData,patch.db-V2.2-CleanNodeStatuses,patch.db-V2.2-0-CreateMissingTables,patch.db-V2.2-2-MoveQNames,patch.db-V2.2-Upgrade-From-2.1,patch.db-V2.2-Upgrade-From-2.2SP1,patch.avmWebProjectInheritPermissions02,patch.updateDmPermissions,patch.db-V3.0-0-CreateActivitiesExtras,patch.db-V3.0-ActivityTables,patch.createSiteStore,patch.sitesFolder,patch.sitePermissionRefactorPatch,patch.migrateVersionStore,patch.inviteEmailTemplate,patch.calendarNamespaceUri,patch.db-V2.1-AuditPathIndex,patch.spacesStoreGuestPermission,patch.redeploySubmitProcess4,patch.redeploySubmitProcess5,patch.deploySubmitDirectProcess,patch.resetWCMToGroupBasedPermissionsPatch,patch.wcmPostPermissionSnapshotPatch3,patch.moveWCMToGroupBasedPermissionsPatch,patch.wcmPostPermissionSnapshotPatch2,patch.redeploySubmitProcess6,patch.redeploySubmitProcess7,patch.db-V2.2-Person-3,patch.webSiteAddModerated,patch.invitationMigration,patch.db-V3.2-Remove-AVM-Issuer,patch.mtShareExistingTenants,patch.redeployInvitationProcess,patch.db-V3.2-LockTables,patch.zonedAuthorities,patch.authorityMigration,patch.authorityDefaultZonesPatch,patch.db-V3.2-ContentTables,patch.db-V3.2-Modify-AVM-MimeType,patch.db-V3.2-Upgrade-JBPM,patch.imapFolders,patch.db-V3.2-PropertyValueTables,patch.db-V3.2-AuditTables,patch.db-V3.1-Allow-IPv6,patch.personUsagePatch,patch.db-V3.2-Child-Assoc-QName-CRC,patch.fixNameCrcValues-2,patch.redeployNominatedInvitationProcessWithPropsForShare,patch.db-V3.2-ContentTables2,patch.db-V3.3-Remove-VersionCount,patch.rendition.rendering_actions,patch.thumbnailsAssocQName,patch.emailInviteAndNotifyTemplatesFolder,patch.transferServiceFolder,patch.convertContentUrls,patch.fixAuthoritiesCrcValues,patch.updateMimetypes1,patch.db-V3.3-modify-index-permission_id,patch.db-V3.2-AddFKIndexes,patch.db-V3.3-Fix-Repo-Seqs,patch.db-V3.3-Fix-AVM-Seqs,patch.db-V3.4-property-unique-ctx-value,patch.db-V3.4-child-assoc-indexes,patch.db-V3.3-JBPM-Extra,patch.db-V3.3-Node-Prop-Serializable,patch.migrateAttrTenants,patch.migrateAttrAVMLocks,patch.migrateAttrPropBackedBeans,patch.migrateAttrChainingURS,patch.migrateAttrDelete,patch.replication.replication_actions,patch.transfer.targetrulefolder,patch.transfer.targetrule,patch.actions.scheduledfolder,patch.updateMimetypes2,patch.db-V3.2-AddFKIndexes-2,patch.eliminateDuplicates,ftsIndexerTrigger,tempFileCleanerTrigger,contentStoreCleanerJobDetail,contentStoreCleanerTrigger,contentUrlConverterJobDetail,contentUrlConverterTrigger,nodeServiceCleanupJobDetail,nodeServiceCleanupTrigger,indexBackupJobDetail,indexBackupTrigger,ehCacheTracerJob,avmOrphanReaperJob,avmExpiredContentTrigger,userUsageCollapseJob,feedCleanerJobDetail,feedCleanerTrigger,feedGeneratorJobDetail,feedGeneratorTrigger,postLookupJobDetail,postLookupTrigger,postCleanerJobDetail,postCleanerTrigger,migrateVersionStoreJobDetail,migrateVersionStoreTrigger,versionStoreMigrationCleanupJob,taggingStartupJobDetail,taggingStartupTrigger,JCR.Repository,JCR.DictionaryBootstrap,avmRemoteTransport,avmRemoteService,avmSyncServiceTransport,avmSyncServiceTransportRMI,rmiAuthenticationService,repoRemoteService,RepoRemoteService,repoRemoteTransport,repoRemoteTransportRMI,actionServiceTransport,actionServiceTransportRMI,officeResourceBundles,portletsResourceBundles,BlogIntegrationService,BlogIntegrationService_transaction,BlogIntegrationService_security,blogIntegrationService,baseBlogIntegrationImplmentation,wordPressBlogIntegration,typePadBlogIntegration,blog-post,RatingService,RatingService_transaction,RatingService_security,ratingService,ratingSchemeRegistry,baseRatingScheme,likesRatingScheme,fiveStarRatingScheme,ratingServiceScript,RenditionService,RenditionService_transaction,RenditionService_security,renditionService,perform-rendition,renditionDefinitionPersister,renditionLocationResolver,renderingActionResourceBundles,baseRenderingAction,baseTemplateRenderingAction,reformat,imageRenderingEngine,freemarkerRenderingEngine,htmlRenderingEngine,compositeRenderingEngine,xsltRenderingEngine,xsltFunctions,renditionedAspect,renditionServiceScript,Replication,replicationParams,ReplicationService,ReplicationService_transaction,ReplicationService_security,replicationService,replicationDefinitionPersister,replicationActionExecutor,replicationServiceScript,ThumbnailService,ThumbnailService_transaction,ThumbnailService_security,thumbnailService,thumbnailRenditionConvertor,thumbnailRegistry,create-thumbnail,update-thumbnail,thumbnailServiceScript,createThumbnailActionFilter,PreferenceService,PreferenceService_transaction,PreferenceService_security,preferenceService,preferenceServiceScript,transformer.worker.Pdf2swf,transformer.Pdf2swf,transformer.complex.OpenOffice.Pdf2swf,transformer.complex.Text.Pdf2swf,transformer.complex.Archive.Pdf2swf,formResourceBundles,FormService,FormService_transaction,FormService_security,formService,formProcessorRegistry,nodeFilterRegistry,typeFilterRegistry,baseFormProcessor,nodeFormProcessor,typeFormProcessor,baseFormFilter,formServiceScript,fieldProcessorRegistry,baseFieldProcessor,qnameFieldProcessor,propertyFieldProcessor,associationFieldProcessor,encodingFieldProcessor,mimetypeFieldProcessor,sizeFieldProcessor,defaultFieldProcessor,workflowFormProcessor,taskFormProcessor,workflowFilterRegistry,taskFilterRegistry,packageItemsFieldProcessor,transitionsFieldProcessor,messageFieldProcessor,taskOwnerFieldProcessor,CMISMapping,CMISService,CMISDictionaryService,CMIS.DictionaryBootstrap,CMISQueryService,CMISRenditionService,CMISChangeLogService,CMISChangeLogDataExtractor,CMISAccessControlService,lucene.sql.cmis.strict,lucene.sql.alfresco,adm.luceneQueryEngine,adm.luceneQueryEngineSecurity,period.none,period.immediately,period.days,period.weeks,period.months,period.quarters,period.years,period.end.of.month,period.end.of.quarter,period.end.of.year,period.end.of.financial.month,period.end.of.financial.quarter,period.end.of.financial.year,period.cron,period.xml.duration,transferService,transferService2,transferTransmitter,transferReporter,transferManifestNodeFactory,alienProcessor,transferReceiver,transferProgressMonitor,commit-transfer,transferManifestProcessorFactory,transferNodeResolverFactory,transferServiceResourceBundles,TransferService_security,TransferService_transaction,TransferService,TransferService2,TransferReceiver_security,TransferReceiver_transaction,TransferReceiver,transfer-async,transferServiceScript,NodeCrawlerFactory,userBootstrap-mt,systemBootstrap-mt,versionBootstrap-mt,version2Bootstrap-mt,spacesArchiveBootstrap-mt,spacesBootstrap-mt,baseMultiTAdminService,moduleService,module.baseComponent,cxf,org.apache.cxf.bus.spring.BusApplicationListener,org.apache.cxf.bus.spring.BusWiringBeanFactoryPostProcessor,org.apache.cxf.bus.spring.Jsr250BeanPostProcessor,org.apache.cxf.bus.spring.BusExtensionPostProcessor,org.apache.cxf.resource.ResourceManager,org.apache.cxf.configuration.Configurer,org.apache.cxf.binding.BindingFactoryManager,org.apache.cxf.transport.DestinationFactoryManager,org.apache.cxf.transport.ConduitInitiatorManager,org.apache.cxf.wsdl.WSDLManager,org.apache.cxf.phase.PhaseManager,org.apache.cxf.workqueue.WorkQueueManager,org.apache.cxf.buslifecycle.BusLifeCycleManager,org.apache.cxf.endpoint.ServerRegistry,org.apache.cxf.endpoint.ServerLifeCycleManager,org.apache.cxf.endpoint.ClientLifeCycleManager,org.apache.cxf.transports.http.QueryHandlerRegistry,org.apache.cxf.endpoint.EndpointResolverRegistry,org.apache.cxf.headers.HeaderManager,org.apache.cxf.catalog.OASISCatalogManager,org.apache.cxf.endpoint.ServiceContractResolverRegistry,org.apache.cxf.binding.soap.SoapBindingFactory,org.apache.cxf.binding.soap.SoapTransportFactory,org.apache.cxf.binding.soap.customEditorConfigurer,org.apache.cxf.jaxrs.JAXRSBindingFactory,org.apache.cxf.transport.servlet.ServletTransportFactory,lotusWSPlaceholderConfigurer,org.apache.cxf.jaxws.EndpointImpl—1950028618,org.apache.cxf.jaxws.EndpointImpl–570561460,org.apache.cxf.jaxws.EndpointImpl–545181252,lotusContentServiceImpl,lotusDocumentServiceImpl,lotusLibraryServiceImpl,quickrPathHelper,quickrDocumentHelper,quickrPermissionHelper,atomBasedFeedService,lotusAtomBasedFeedServiceImpl,atomFeedProvider,atomEntryProvider,atomServiceProvider,atomErrorProvider,atomNodeRefProvider,quickrAuthenticationInterceptor,quickrServerConnector,quickrServlet,quickrServer,vtiResourceBundles,vtiProperties,vtiServer,vtiServerConnector,vtiFilter,vtiRequestDispatcher,vtiInfAction,vtiBinAction,vtiDownloadContentAction,vtiResourceAction,vtiPropfindAction,vtiLockAction,vtiPropPatchAction,vtiUnlockAction,vtiIfHeaderAction,vtiBrowserAction,vtiSoapAction,abstractVtiMethod,server_version_method,open_service_method,url_to_web_url_method,FileOpen_dialog,SaveForm_dialog,list_documents_method,getDocsMetaInfo_method,get_document_method,checkout_document_method,uncheckout_document_method,remove_documents_method,put_document_method,create_url-directories_method,create_url-directory_method,move_document_method,checkin_document_method,webUrlFromPageUrlEndpoint,checkOutFile,checkInFile,undoCheckOutFile,getDwsMetaDataEndpoint,getDwsDataEndpoint,createDwsEndpoint,getVersionsEndpoint,restoreVersionEndpoint,deleteVersionEndpoint,deleteAllVersionsEndpoint,getUserLoginFromEmailEndpoint,addUserCollectionToRoleEndpoint,createFolderEndpoint,deleteFolderEndpoint,deleteDwsEndpoint,renameDwsEndpoint,removeDwsUserEndpoint,updateDwsDataEndpoint,getMeetingWorkspacesEndpoint,getMeetingsInformationEndpoint,createWorkspaceEndpoint,addMeetingFromICalEndpoint,updateMeetingFromICalEndpoint,removeMeetingEndpoint,deleteWorkspaceEndpoint,webscript.org.alfresco.vti.vti-server.get,versionsServiceHandler,dwsServiceHandler,userGroupServiceHandler,meetingServiceHandler,checkOutCheckInServiceHandler,vtiHandlerTarget,vtiDocumentHelper,vtiPathHelper,handlerExceptionAdvice,handlerExceptionPointcutAdvisor,vtiHandler,shareUtils,vtiAuthenticationHandler,org_alfresco_module_dod5015_dictionaryBootstrap,org_alfresco_module_dod5015_customModelsRepositoryLocation,org_alfresco_module_dod5015_dictionaryRepositoryBootstrap,org_alfresco_module_dod5015_userRolesExtractor,org_alfresco_module_dod5015_namePathExtractor,org_alfresco_module_dod5015_nodeRefPathExtractor,org_alfresco_module_dod5015_identifierExtractor,org_alfresco_module_dod5015_permissionBootstrap,org_alfresco_module_dod5015_bootstrapData,recordComponentIdentifierAspect,rmEntryVoter,afterRm,RecordsManagementServiceRegistry,org_alfresco_module_dod5015_dispositionSelectionStrategy,recordCopyBehaviours,recordsManagementService,RecordsManagementService,RecordsManagementService_transaction,RecordsManagementService_security,recordsManagementSecurityService,RecordsManagementSecurityService,RecordsManagementSecurityService_transaction,RecordsManagementSecurityService_security,recordsManagementActionService,RecordsManagementActionService,RecordsManagementActionService_transaction,RecordsManagementActionService_security,recordsManagementEventService,RecordsManagementEventService,RecordsManagementEventService_transaction,RecordsManagementEventService_security,recordsManagementAdminService,RecordsManagementAdminService,RecordsManagementAdminService_transaction,RecordsManagementAdminService_security,recordsManagementAuditService,RecordsManagementAuditService,RecordsManagementAuditService_transaction,RecordsManagementAuditService_security,customEmailMappingService,CustomEmailMappingService_transaction,CustomEmailMappingService_security,CustomEmailMappingService,recordsManagementNotificationService,RecordsManagementNotificationService,RecordsManagementNotificationService_transaction,RecordsManagementNotificationService_security,caveatConfigService,rmListOfValuesContraintInit,CaveatConfigService_security,CaveatConfigService_transaction,CaveatConfigService,recordsManagementSearchBehaviour,DispositionPeriodProperties,rmBaseCapability,rmAccessAuditCapability,rmAddModifyEventDatesCapability,rmApproveRecordsScheduledForCutoffCapability,rmAttachRulesToMetadataPropertiesCapability,rmAuthorizeAllTransfersCapability,rmAuthorizeNominatedTransfersCapability,rmChangeOrDeleteReferencesCapability,rmCloseFoldersCapability,rmCreateAndAssociateSelectionListsCapability,rmCreateModifyDestroyClassificationGuidesCapability,rmCreateModifyDestroyEventsCapability,rmCreateModifyDestroyFileplanMetadataCapability,rmCreateModifyDestroyFileplanTypesCapability,rmCreateModifyDestroyFoldersCapability,rmCreateModifyDestroyRecordTypesCapability,rmCreateModifyDestroyReferenceTypesCapability,rmCreateModifyDestroyRolesCapability,rmCreateModifyDestroyTimeframesCapability,rmCreateModifyDestroyUsersAndGroupsCapability,rmCreateModifyRecordsInCuttoffFoldersCapability,rmCycleVitalRecordsCapability,rmDeclareAuditAsRecordCapability,rmDeclareRecordsCapability,rmDeclareRecordsInClosedFoldersCapability,rmDeleteAuditCapability,rmDeleteLinksCapability,rmDeleteRecordsCapability,rmDestroyRecordsCapability,rmDestroyRecordsScheduledForDestructionCapability,rmDisplayRightsReportCapability,rmEditDeclaredRecordMetadataCapability,rmEditNonRecordMetadataCapability,rmEditRecordMetadataCapability,rmEditSelectionListsCapability,rmEnableDisableAuditByTypesCapability,rmExportAuditCapability,rmExtendRetentionPeriodOrFreezeCapability,rmFileRecordsCapability,rmMakeOptionalPropertiesMandatoryCapability,rmManageAccessControlsCapability,rmManageAccessRightsCapability,rmManuallyChangeDispositionDatesCapability,rmMapClassificationGuideMetadataCapability,rmMapEmailMetadataCapability,rmMoveRecordsCapability,rmPasswordControlCapability,rmPlanningReviewCyclesCapability,rmReOpenFoldersCapability,rmSelectAuditMetadataCapability,rmTriggerAnEventCapability,rmUndeclareRecordsCapability,rmUnfreezeCapability,rmUpdateClassificationDatesCapability,rmUpdateExemptionCategoriesCapability,rmUpdateTriggerDatesCapability,rmUpdateVitalRecordCycleInformationCapability,rmUpgradeDowngradeAndDeclassifyRecordsCapability,rmViewRecordsCapability,rmViewUpdateReasonsForFreezeCapability,rmCreate,rmDelete,rmUpdate,rmUpdateProperties,rmDeclare,rmWriteContent,rmActionResourceBundles,rmAction,rmProxyAction,actionSecurity,actionProxy,file_proxy,file_security,file,cutoff_proxy,cutoff_security,cutoff,unCutoff_proxy,unCutoff_security,unCutoff,destroy_proxy,destroy_security,destroy,retain_proxy,retain_security,retain,openRecordFolder_proxy,openRecordFolder_security,openRecordFolder,closeRecordFolder_proxy,closeRecordFolder_security,closeRecordFolder,reviewed_proxy,reviewed_security,reviewed,setupRecordFolder_proxy,setupRecordFolder_security,setupRecordFolder,declareRecord_proxy,declareRecord_security,declareRecord,undeclareRecord_proxy,undeclareRecord_security,undeclareRecord,freeze_proxy,freeze_security,freeze,unfreeze_proxy,unfreeze_security,unfreeze,relinquishHold_proxy,relinquishHold,editHoldReason_proxy,editHoldReason_security,editHoldReason,editReviewAsOfDate_proxy,editReviewAsOfDate_security,editReviewAsOfDate,editDispositionActionAsOfDate_proxy,editDispositionActionAsOfDate_security,editDispositionActionAsOfDate,broadcastVitalRecordDefinition_proxy,broadcastVitalRecordDefinition_security,broadcastVitalRecordDefinition,broadcastDispositionActionDefinitionUpdate_proxy,broadcastDispositionActionDefinitionUpdate_security,broadcastDispositionActionDefinitionUpdate,completeEvent_proxy,completeEvent_security,completeEvent,undoEvent_proxy,undoEvent_security,undoEvent,transfer_proxy,transfer_security,transfer,transferComplete_proxy,transferComplete,accession_proxy,accession_security,accession,accessionComplete_proxy,accessionComplete,splitEmail,splitEmail_proxy,applyScannedRecord_proxy,applyScannedRecord,applyPdfRecord_proxy,applyPdfRecord,applyDigitalPhotographRecord_proxy,applyDigitalPhotographRecord,applyWebRecord_proxy,applyWebRecord,scriptRecordsManagementService,rmEventResourceBundles,rmEventType,rmEventType.simple,rmEventType.superseded,rmEventType.obsolete,rmEventType.crossReferencedRecordTransfered,scheduledNotifyOfRecordsDueForReviewJobDetail,scheduledNotifyOfRecordsDueForReviewJobTrigger,scheduledDispositionLifecyceleJobDetail,scheduledDispositionLifecyceleJobTrigger,RecordsManagementBootstrap,rmConfigServiceScript,rmNodeFormFilter,rmTypeFormFilter,webscript.org.alfresco.rma.rmaction.post,rmBaseWebscript,webscript.org.alfresco.rma.dodcustomtypes.get,webscript.org.alfresco.rma.custompropdefinitions.get,webscript.org.alfresco.rma.custompropdefinition.put,webscript.org.alfresco.rma.custompropdefinition.post,webscript.org.alfresco.rma.custompropdefinition.delete,webscript.org.alfresco.rma.customrefdefinitions.get,webscript.org.alfresco.rma.customrefdefinition.put,webscript.org.alfresco.rma.customrefdefinition.post,webscript.org.alfresco.rma.customrefs.get,webscript.org.alfresco.rma.customref.post,webscript.org.alfresco.rma.customref.delete,webscript.org.alfresco.rma.dispositionschedule.get,webscript.org.alfresco.rma.dispositionactiondefinitions.post,webscript.org.alfresco.rma.dispositionactiondefinition.put,webscript.org.alfresco.rma.dispositionactiondefinition.delete,webscript.org.alfresco.rma.dispositionlifecycle.get,webscript.org.alfresco.rma.listofvalues.get,webscript.org.alfresco.rma.rmauditlog.get,webscript.org.alfresco.rma.rmauditlog.post,webscript.org.alfresco.rma.rmauditlog.put,webscript.org.alfresco.rma.rmauditlog.delete,webscript.org.alfresco.rma.export.post,webscript.org.alfresco.rma.import.post,rmBaseTransferWebscript,webscript.org.alfresco.rma.transfer.get,webscript.org.alfresco.rma.transferreport.get,webscript.org.alfresco.rma.transferreport.post,webscript.org.alfresco.rma.admin.rmrole.rmroles.get,webscript.org.alfresco.rma.admin.rmrole.rmroles.post,webscript.org.alfresco.rma.admin.rmrole.rmrole.get,webscript.org.alfresco.rma.admin.rmrole.rmrole.put,webscript.org.alfresco.rma.admin.rmrole.rmrole.delete,webscript.org.alfresco.rma.admin.rmevent.rmeventtypes.get,webscript.org.alfresco.rma.admin.rmevent.rmevents.get,webscript.org.alfresco.rma.admin.rmevent.rmevents.post,webscript.org.alfresco.rma.admin.rmevent.rmevent.get,webscript.org.alfresco.rma.admin.rmevent.rmevent.put,webscript.org.alfresco.rma.admin.rmevent.rmevent.delete,webscript.org.alfresco.rma.admin.emailmap.get,webscript.org.alfresco.rma.admin.emailmap.post,webscript.org.alfresco.rma.admin.emailmap.put,webscript.org.alfresco.rma.rmconstraints.get,webscript.org.alfresco.rma.userrightsreport.get,webscript.org.alfresco.rma.bootstraptestdata.get,webscript.org.alfresco.rma.applydodcertmodelfixes.get,webscript.org.alfresco.rma.applyfixmob1573.get,wcmquickstartmodule_contextParserService,wcmquickstartmodule_contextParser,wcmquickstartmodule_sectionIdContextParser,wcmquickstartmodule_pdfRenditionPathContextParser,wcmquickstartmodule_siteIdContextParser,wcmquickstartmodule_websiteOwnerContextParser,wcmquickstartmodule_sectionPathContextParser,wcmquickstartmodule_dictionaryBootstrap,wcmquickstartmodule_sectionType,wqsmodule_sectionTypesToIgnore,wqsmodule_sectionAssetCollections,wqsmodule_sectionHierarchyProcessor,wcmquickstartmodule_webassetCollectionFolderType,wcmquickstartmodule_webassetCollectionType,wcmquickstartmodule_webassetAspect,wcmquickstartmodule_imageType,wcmquickstartmodule_tagscopeAspect,wcmquickstartmodule_taggableAspect,wcmquickstartmodule_visitorFeedback,wcmquickstartmodule_visitorFeedbackSummary,wcmquickstartmodule_article,wcmquickstartmodule_website,webscript.org.alfresco.module.wcmquickstart.assetcollection.get,webscript.org.alfresco.module.wcmquickstart.asset.get,webscript.org.alfresco.module.wcmquickstart.asset.post,webscript.org.alfresco.module.wcmquickstart.assetsearch.get,wqsmodule_assetSerializerFactory,webscript.org.alfresco.module.wcmquickstart.websiteinfo.get,webscript.org.alfresco.module.wcmquickstart.fixwebassets1.get,webscript.org.alfresco.module.wcmquickstart.fixwebassets2.get,webscript.org.alfresco.module.wcmquickstart.loadwebsitedata.get,wqsmodule_siteImportFileLocations,webscript.org.alfresco.module.wcmquickstart.updatewebsiterenditions.get,webscript.org.alfresco.module.wcmquickstart.webassetpreviewer.get,wcmquickstartmodule_renditionHelper,wqsmodule_renditionDefinitions,wcmquickstartmodule_renditionBootstrap,org_alfresco_module_wcmquickstart_processReceivedFeedbackTrigger,feedbackProcessor,feedbackProcessorHandler,commentFeedbackProcessorHandler,contactFeedbackProcessorHandler,org_alfresco_module_wcmquickstart_processAssetAvailabilityTrigger,org_alfresco_module_wcmquickstart_processPublishingQueues,org_alfresco_module_wcmquickstart_dynamicQueryRefreshProcess,org_alfresco_module_wcmquickstart_transferService,org_alfresco_module_wcmquickstart_transferTransmitter,org_alfresco_module_wcmquickstart_transferManifestNodeFactory,org_alfresco_module_wcmquickstart_nodeRefMapper,org_alfresco_module_wcmquickstart_publishingService,wqsmodule_publishingCrawlerConfigurer,org.alfresco.module.org_alfresco_module_wcmquickstart.publish.PublishBootstrap#0,workflowDeployer$child#0,webqs_publish,webqs_publishTree,org_alfresco_module_wcmquickstart_configBootstrap,org_alfresco_module_wcmquickstart_propertyBootstrap,org_alfresco_module_wcmquickstart_siteHelper,wqsmodule_defaultWebsiteLocales,org_alfresco_module_wcmquickstart_collectionHelper,web.configsource,web.config,webscripts.abdera,webscripts.formatregistry,webscripts.formatmap,webscripts.adaptorset,webscripts.adaptors,webscripts.formats,webscripts.formats.IE,webscripts.resources,webscripts.classpathstore,webscripts.remotestore,webscripts.store,webscripts.store.alfresco,webscripts.searchpath,webscripts.abstractcontainer,webscripts.web.templateregistry,webscripts.web.scriptregistry,webscripts.container,webscripts.templateprocessor.freemarker,webscripts.scriptprocessor.javascript,webscripts.script.remote,webscripts.connector.provider,webscripts.index,webscripts.registry,connector.service,credential.vault.provider,credential.vault.provider.xml,webscript,webscriptdesc,webscript.default,scriptDebugger,webscriptHandlerMappings,urlPathHelper,handlerMappings,endpointController,resourceController,webscriptViewResolver,webscript.org.springframework.extensions.webscripts.index.get,webscript.org.springframework.extensions.webscripts.indexall.get,webscript.org.springframework.extensions.webscripts.indexfamily.get,webscript.org.springframework.extensions.webscripts.indexlifecycle.get,webscript.org.springframework.extensions.webscripts.indexuri.get,webscript.org.springframework.extensions.webscripts.indexpackage.get,webscript.org.springframework.extensions.webscripts.indexpackagedoc.get,webscript.org.springframework.extensions.webscripts.index.post,webscript.org.springframework.extensions.webscripts.scriptdescription.get,webscript.org.springframework.extensions.webscripts.scriptdump.get,webscript.org.springframework.extensions.webscripts.scriptinstall.post,webscript.org.springframework.extensions.webscripts.jsdebugger.get,webscript.org.springframework.extensions.webscripts.jsdebugger.post,webClientConfigSource,repoUrlConfigSource,globalConfigSharedCache,globalConfigCache,webClientConfigService,webClientConfigAdminInterpreter,webClientConfigAdminInterpreterHelp,dataDictionary,FormsService,Schema2XFormsProperties,webscripts.authenticator.webclient,webscripts.authenticator.jsr168.webclient,RemoteUserMapper,AuthenticationFilter,defaultAuthenticationFilter,GlobalAuthenticationFilter,WebscriptAuthenticationFilter,WebDavAuthenticationFilter,SharepointAuthenticationHandler,extension.workflowBootstrap,patch.wcmFolders,wcm_deployment_receiver,patch.wcmDeployed,sqlMapClient,webscripts.configsource,webscripts.config,webscript.org.alfresco.repository.metadata.bulkmetadata.post,webscripts.repostore,webscripts.store.repo.extension,webscripts.store.repo,webscripts.store.client.extension,webscripts.store.client,webscripts.repo.imageresolver,webscripts.repo.registry.templateprocessor,webscripts.repo.registry.scriptprocessor,webscripts.repo.templateprocessor.factory,webscripts.repo.templateprocessor,webscripts.repo.scriptprocessor.factory,webscripts.repo.scriptprocessor,org.springframework.extensions.webscripts.TemplateProcessorRegistrar#0,org.springframework.extensions.webscripts.ScriptProcessorRegistrar#0,webscripts.index.prototype,webscripts.registry.prototype,webscripts.js.paging,webscripts.authenticator.basic,webscripts.authenticator.jsr168,webscripts.authenticator.facebook,facebook.service,webscripts.cmis.atom.extension,webscripts.cmis.adaptors,webscripts.cmis.formats,CMISReferenceFactory,webscripts.js.cmis,webscript.org.alfresco.cmis.test.post,webscript.org.alfresco.cmis.content.get,webscript.org.alfresco.cmis.content.put,webscript.org.alfresco.cmis.content.delete,webscript.org.alfresco.cmis.queries.post,webscript.org.alfresco.cmis.query.get,webscript.org.alfresco.jsdebugger.get,webscript.org.alfresco.jsdebugger.post,webscript.org.alfresco.repository.login.get,webscript.org.alfresco.repository.login.post,webscript.org.alfresco.repository.loginticket.get,webscript.org.alfresco.repository.loginticket.delete,webscript.org.alfresco.repository.search.searchengines.get,webscript.org.alfresco.repository.search.keywordsearch.get,webscript.org.alfresco.repository.search.personsearch.get,webscript.org.alfresco.repository.search.searchproxy.get,webscript.org.alfresco.repository.content.stream,webscript.org.alfresco.repository.store.content.put,webscript.org.alfresco.repository.store.remoteavm.get,webscript.org.alfresco.repository.store.remoteavm.post,webscript.org.alfresco.repository.store.remoteavm.delete,webscript.org.alfresco.webframework.avmstore.get,webscript.org.alfresco.webframework.avmstore.post,webscript.org.alfresco.webframework.avmstore.delete,webscript.org.alfresco.repository.touch.get,webscript.org.alfresco.repository.authentication.get,webscript.org.alfresco.repository.content.mimetypes.get,webscript.org.alfresco.repository.rendition.patchthumbnailsasrenditions.get,webscript.org.alfresco.repository.activities.feed.userfeed.get,webscript.org.alfresco.repository.activities.feed.userfeed-admin.get,webscript.org.alfresco.repository.activities.feed.sitefeed.get,webscript.org.alfresco.repository.activities.templates.get,webscript.org.alfresco.repository.activities.template.get,templates.classpathstore,activity.template.store.client.extension,activity.template.store.client,activity.template.searchpath,webscript.org.alfresco.repository.invite.invite.get,webscript.org.alfresco.repository.invite.inviteresponse.put,webscript.org.alfresco.repository.invite.invites.get,webscript.org.alfresco.repository.invite.invite-by-ticket.get,webscript.org.alfresco.repository.person.changepassword.post,rhinoScriptDebugger,webscript.org.alfresco.repository.admin.jmxdump.get,webscript.dictionary,webscript.org.alfresco.repository.dictionary.classes.get,webscript.org.alfresco.repository.dictionary.class.get,webscript.org.alfresco.repository.dictionary.subclasses.get,webscript.org.alfresco.repository.dictionary.property.get,webscript.org.alfresco.repository.dictionary.properties.get,webscript.org.alfresco.repository.dictionary.association.get,webscript.org.alfresco.repository.dictionary.associations.get,webscript.org.alfresco.repository.imap.imap-enabled.get,commentServiceScript,abstractRuleWebScript,webscript.org.alfresco.repository.rule.ruletypes.get,webscript.org.alfresco.repository.rule.actiondefinitions.get,webscript.org.alfresco.repository.rule.actionconditiondefinitions.get,webscript.org.alfresco.repository.rule.rule.delete,webscript.org.alfresco.repository.rule.rule.get,webscript.org.alfresco.repository.rule.rule.post,webscript.org.alfresco.repository.rule.rule.put,webscript.org.alfresco.repository.rule.rules.get,webscript.org.alfresco.repository.rule.inheritedrules.get,webscript.org.alfresco.repository.rule.ruleset.get,webscript.org.alfresco.repository.rule.actionConstraints.get,webscript.org.alfresco.repository.rule.actionConstraint.get,webscript.org.alfresco.repository.rule.actionQueue.post,webscript.org.alfresco.repository.transfer.transfer.post,abstractRatingWebScript,webscript.org.alfresco.repository.rating.ratings.get,webscript.org.alfresco.repository.rating.rating.post,webscript.org.alfresco.repository.rating.rating.delete,webscript.org.alfresco.repository.rating.ratingdefinitions.get,abstractWorkflowWebScript,webscript.org.alfresco.repository.workflow.task-instances.get,webscript.org.alfresco.repository.workflow.task-instance.get,webscript.org.alfresco.repository.workflow.task-instance.put,webscript.org.alfresco.repository.workflow.workflow-definitions.get,webscript.org.alfresco.repository.workflow.workflow-instance.get,webscript.org.alfresco.repository.workflow.workflow-instances.get,webscript.org.alfresco.repository.workflow.workflow-instances-for-node.get,webscript.org.alfresco.repository.workflow.workflow-instance.delete,abstractAuditWebScript,webscript.org.alfresco.repository.audit.control.get,webscript.org.alfresco.repository.audit.control.post,webscript.org.alfresco.repository.audit.clear.post,webscript.org.alfresco.repository.audit.query.get,abstractReplicationWebScript,webscript.org.alfresco.repository.replication.replication-definitions.get,webscript.org.alfresco.repository.replication.replication-definitions.post,webscript.org.alfresco.repository.replication.replication-definition.get,webscript.org.alfresco.repository.replication.replication-definition.put,webscript.org.alfresco.repository.replication.replication-definition.delete,abstractActionWebScript,abstractExecuteActionWebScript,webscript.org.alfresco.repository.action.running-action.get,webscript.org.alfresco.repository.action.running-action.delete,webscript.org.alfresco.repository.action.running-actions.get,webscript.org.alfresco.repository.action.running-replication-actions.get,webscript.org.alfresco.repository.action.running-actions.post,webscript.org.alfresco.repository.action.running-replication-actions.post,org.apache.cxf.jaxws.EndpointImpl—1994145354,org.apache.cxf.jaxws.EndpointImpl–436825742,org.apache.cxf.jaxws.EndpointImpl—139464023,org.apache.cxf.jaxws.EndpointImpl–945107716,org.apache.cxf.jaxws.EndpointImpl–1084369008,org.apache.cxf.jaxws.EndpointImpl–155696398,org.apache.cxf.jaxws.EndpointImpl—1547514348,org.apache.cxf.jaxws.EndpointImpl—1596623668,org.apache.cxf.jaxws.EndpointImpl—1360867549,dmServicesProxyCreator,dmTransactionWrappingInterceptor,exceptionPointcutAdvisor,propertiesUtils,dmRepositoryService,dmNavigationService,dmObjectService,dmMultiFilingService,dmVersioningService,dmDiscoveryService,dmRelationshipService,dmPolicyService,dmAclService,dmAbstractService,fileTypeIconRetriever,saajInInterceptor,saajOutInterceptor,wss4jInInterceptor,wss4jOutInterceptor,wss4jOutInterceptorWithMTOM,authenticationTokenCallback,authenticationInterceptor,authenticationClearInterceptor,ticketCallbackHandler,CMLUtil,authenticationWebService,repositoryWebService,dictionaryWebService,contentWebService,authoringWebService,classificationWebService,actionWebService,accessControlWebService,administrationWebService]; root of factory hierarchy
12:22:02,259 DEBUG [org.springmodules.workflow.jbpm31.JbpmFactoryLocator] adding key=jbpm_configuration w/ reference=org.springframework.beans.factory.support.DefaultListableBeanFactory@1e22632: defining beans [internalEHCacheManager,propertyValueSharedCache,propertyValueCache,contentDataSharedCache,contentDataCache,immutableEntitySharedCache,immutableEntityCache,node.rootNodesSharedCache,node.rootNodesCache,node.nodesSharedCache,node.nodesCache,node.aspectsSharedCache,node.aspectsCache,node.propertiesSharedCache,node.propertiesCache,node.parentAssocsSharedCache,node.parentAssocsCache,nodeRulesSharedCache,nodeRulesCache,userToAuthoritySharedCache,userToAuthorityCache,authoritySharedCache,authorityLookupCache,permissionsAccessSharedCache,permissionsAccessCache,readersSharedCache,readersCache,nodeOwnerSharedCache,nodeOwnerCache,personSharedCache,personCache,ticketsCache,avmStoreSharedCache,avmStoreCache,avmEntitySharedCache,avmEntityCache,avmVersionRootEntitySharedCache,avmVersionRootEntityCache,avmNodeSharedCache,avmNodeCache,avmNodeAspectsSharedCache,avmNodeAspectsCache,webServicesQuerySessionSharedCache,webServicesQuerySessionCache,aclSharedCache,aclCache,aclEntitySharedCache,aclEntityCache,authorityEntitySharedCache,authorityEntityCache,permissionEntitySharedCache,permissionEntityCache,resourceBundleBaseNamesSharedCache,resourceBundleBaseNamesCache,loadedResourceBundlesSharedCache,loadedResourceBundlesCache,messagesSharedCache,messagesCache,compiledModelsSharedCache,compiledModelsCache,prefixesSharedCache,prefixesCache,webScriptsRegistrySharedCache,webScriptsRegistryCache,routingContentStoreSharedCache,routingContentStoreCache,executingActionsCache,tenantService,hostConfigurableSocketFactory,baseServiceExporter,runtimeProperties,legacyConfigPostProcessor,global-properties,common-placeholder-configurer,repository-properties,shared-properties,clusterPropertySetter,alfrescoMBeanServer,registry,jmxUrlPattern,jmxUrl,serverConnector,propertyBackedBeanRegistry,abstractPropertyBackedBean,exporter,VirtServerRegistry,log4JHierarchyInit,RepoServerMgmt,defaultDataSource,dataSource,transactionService,retryingTransactionHelper,web.retryingTransactionHelper,retryingWriteTxnAdvice,retryingReadTxnAdvice,checkTxnAdvice,resourceBundles,messageService,indexerComponent,searchService,admSearchService,versionSearchService,indexerAndSearcherFactory,categoryService,indexThreadPoolExecutor,lucene.fts.alfresco,abstractLuceneIndexerAndSearcherFactory,admLuceneIndexerAndSearcherFactory,adm.luceneQueryEngineImpl,admLuceneUnIndexedIndexerAndSearcherFactory,avmLuceneIndexerAndSearcherFactory,avm.luceneQueryEngineImpl,luceneCategoryService,lockService,versionService,versionNodeService,serialVersionLabelPolicy,registerContentWithVersionService,registerMLContainerWithVersionService,versionMigrator,versionableAspect,cm:constraintRegistry,namespaceDAO,dictionaryDAO,dictionaryService,namespaceService,dictionaryModelBootstrap,dictionaryBootstrap,extension.dictionaryBootstrap,copyService,checkOutCheckInService,workingCopyAspect,discussableAspect,LuceneFullTextSearchIndexer,luceneFullTextSearchIndexer,luceneIndexBackupComponent,queryRegisterComponent,multilingualDocumentAspect,emptyTranslationAspect,mlContainerType,referenceableAspect,temporaryAspect,configurableService,registryService,serverDescriptorDAO,currentRepoDescriptorDAO,installedRepoDescriptorDAO,jobLockService,sysAdminParams,applicationEventMulticaster,permissionsModelDAO,permissionService,permissionServiceImpl,ownerDynamicAuthority,lockOwnerDynamicAuthority,permissionModelBootstrap,roleVoter,groupVoter,aclEntryVoter,accessDecisionManager,afterAcl,afterInvocationManager,NamespaceService_security,DictionaryService_security,NodeService_security,FileFolderService_security,ContentService_security,MimetypeService_security,SearchService_security,CategoryService_security,CopyService_security,LockService_security,VersionService_security,MultilingualContentService_security,EditionService_security,CheckoutCheckinService_security,RuleService_security,ImporterService_security,ActionService_security,PermissionService_security,AuthorityService_security,AuthenticationService_security,OwnableService_security,PersonService_security,TemplateService_security,ScriptService_security,WorkflowService_security,AuditService_security,RepoAdminService_security,ContentUsageService_security,PublicServiceAccessService_security,ServiceRegistry,exceptionTranslator,DescriptorService,AuditMethodInterceptor,NodeService,NodeService_transaction,ContentService,ContentService_transaction,SearchService,ADMSearchService,SearchService_transaction,CategoryService,CategoryService_transaction,CopyService,CopyService_transaction,LockService,LockService_transaction,VersionService,VersionService_transaction,CheckoutCheckinService,CheckoutCheckinService_transaction,RuleService,RuleService_transaction,ImporterService,ImporterService_transaction,ExporterService,ExporterService_transaction,ActionService,ActionService_transaction,PermissionService,PermissionService_transaction,AuthorityService,AuthorityService_transaction,OwnableService,OwnableService_transaction,PersonService,PersonService_transaction,ContentUsageService,ContenUsageService_transaction,AuthenticationService,AuthenticationService_transaction,TemplateService,TemplateService_transaction,ScriptService,ScriptService_transaction,FileFolderService,FileFolderService_transaction,crossRepositoryCopyService,crossRepositoryCopyServiceWriteTxnAdvisor,CrossRepositoryCopyService,avmLockingAwareService,AVMLockingAwareService,indexingAVMLockingAwareService,avmService,avmServiceMT,avmServiceBase,checkTxnAdvisor,avmServiceReadTxnAdvisor,avmServiceWriteTxnAdvisor,AVMService,indexingAVMService,avmSnapShotTriggeredIndexingMethodInterceptor,avmSyncService,avmSyncServiceReadTxnAdvisor,avmSyncServiceWriteTxnAdvisor,AVMSyncService,attributeServiceReadTxnAdvisor,attributeServiceWriteTxnAdvisor,AttributeService,avmLockingServiceReadTxnAdvisor,avmLockingServiceWriteTxnAdvisor,AVMLockingService,WorkflowService,WorkflowService_transaction,AuditService,AuditService_transaction,MultilingualContentService,MultilingualContentService_transaction,EditionService,EditionService_transaction,ConfigurableService,ConfigurableService_transaction,RegistryService,RegistryService_transaction,ModuleService,ModuleService_transaction,RepoAdminService,RepoAdminService_transaction,ScheduledPersistedActionService,ScheduledPersistedActionService_transaction,ScheduledPersistedActionService_security,PublicServiceAccessService,PublicServiceAccessService_transaction,publicServiceAccessService,fileFolderService,mlTranslationInterceptor,mlContentInterceptor,tempFileMarkerInterceptor,multilingualContentService,editionService,ImapService,defaultAsyncThreadPool,deploymentAsyncThreadPool,baseActionFilter,defaultAsynchronousActionExecutionQueue,deploymentAsynchronousActionExecutionQueue,actionService,actionTrackingService,actionTrackingServiceScript,scheduledPersistedActionService,actionsAspect,actionResourceBundles,action-constraint,ac-compare-operations,ac-content-properties,ac-mimetypes,ac-types,ac-aspects,ac-properties,ac-email-templates,ac-scripts,action-condition-evaluator,no-condition,compare-property-value,compare-date-property,compare-integer-property,compare-text-property,compare-mime-type,in-category,is-subtype,has-aspect,has-tag,has-version-history,composite-condition,action-executer,composite-action,create-version,add-features,remove-features,specialise-type,link-category,simple-workflow,transform,transform-image,copy,copy-to-web-project,move,check-in,check-out,mail,mailService,set-property-value,extract-metadata,import,export,repository-export,script,counter,execute-all-rules,simple-avm-submit,start-avm-workflow,simple-avm-promote,avm-revert-store,avm-revert-list,avm-revert-to-version,avm-undo-list,avm-deploy-website,count-children,link-rules,unlink-rules,reorder-rules,accept-simpleworkflow,reject-simpleworkflow,baseTemplateActionDefintion,ruleService,rulesAspect,ruleResourceBundles,rule-type-base,inbound,update,outbound,rule-trigger-base,on-create-node-trigger,on-update-node-trigger,on-property-update-trigger,on-create-child-association-trigger,on-delete-child-association-trigger,on-delete-node-trigger,on-create-association-trigger,on-delete-association-trigger,on-content-update-trigger,on-content-create-trigger,on-content-restore-trigger,mlPropertyInterceptor,nodeRefPropertyInterceptor,multiTNodeServiceInterceptor,nodeService,mlAwareNodeService,mtAwareNodeService,storeArchiveMap,nodeArchiveService,avmNodeService,integrityChecker,incompleteNodeTagger,nodeIndexer,nodeCleanupRegistry,nodeCleanupBase,nodeCleanup.deletedNodeCleanup,dbNodeService,nodeAuditor,resourceFinder,schedulerResources,schedulerProperties,schedulerFactory,cifsAuthenticatorBase,ftpAuthenticatorBase,fileServerConfigurationBase,contentDiskDriver,nodeMonitorFactory,cifsHelper,avmDiskDriver,fileContentStore,deletedContentStore,deletedContentBackupListener,deletedContentBackupListeners,contentStoreCleaner,eagerContentStoreCleaner,baseContentService,contentService,charset.finder,mimetypeConfigService,mimetypeService,contentFilterLanguagesConfigService,contentFilterLanguagesService,metadataExtracterRegistry,baseMetadataExtracter,extracter.worker.OpenOffice,extracter.TikaAuto,extracter.PDFBox,extracter.Poi,extracter.Office,extracter.Mail,extracter.Html,extracter.MP3,extracter.OpenDocument,extracter.DWG,extracter.RFC822,extracter.OpenOffice,contentTransformerRegistry,baseContentTransformer,failover.transformer.PdfRenderer.PdfToImage,failover.transformer.PdfBox.PdfToImage,transformer.StringExtracter,transformer.BinaryPassThrough,transformer.PdfBox,transformer.PdfToImage,transformer.complex.PDF.Image,transformer.complex.OpenOffice.Image,transformer.PdfBox.TextToPdf,transformer.complex.Text.Image,transformer.TikaAuto,transformer.Poi,transformer.Office,transformer.OOXML,transformer.TextMining,transformer.HtmlParser,transformer.MediaWikiParser,transformer.worker.OpenOffice,transformer.OpenOffice,transformer.complex.OpenOffice.PdfBox,transformer.OutlookMsg,transformer.RFC822,transformer.worker.ImageMagick,transformer.ImageMagick,transformer.Archive,tenantAdminService,controlDAO,controlDAO.org.hibernate.dialect.Dialect,controlDAO.org.hibernate.dialect.PostgreSQLDialect,postDAO,feedDAO,feedControlDAO,patchDAO,appliedPatchDAO,qnameDAO,nodeDAO,lockDAO,mimetypeDAO,encodingDAO,localeDAO,contentDataDAO,propertyValueDAO,auditDAO,newAvmStoreDAO,newAvmNodeDAO,newAvmNodeLinksDAO,newAvmVersionRootDAO,avmLockDAO,permissionsDaoComponent,avmPermissionsDaoComponent,admPermissionsDaoComponent,admNodeACLDAO,avmNodeACLDAO,aclCrudDAO,aclDAO,usageDAO,hibernateConfigProperties,cacheStrategiesPlaceholderConfigurer,sessionFactory,dialect,sessionFactoryBase,transactionManager,dialectResourceLoader,activitiesDataSource,activitiesDataSource_autoCommit,activitiesSqlMapClient,alfrescoSqlMapClient,repoSqlMapClientTemplate,locksSqlMapClientTemplate,contentSqlMapClientTemplate,propertyValueSqlMapClientTemplate,auditSqlMapClientTemplate,avmSqlMapClientTemplate,activityPostService,activityService,feedCleaner,postCleaner,postLookup,baseFeedGenerator,feedGenerator,feedTaskProcessor,ownableService,templateService,baseTemplateProcessor,freeMarkerProcessor,xsltProcessor,baseTemplateImplementation,avmExtension,sessionTemplateExtension,classificationTemplateExtension,workflowTemplateExtension,peopleTemplateExtension,siteTemplateExtension,hasAspectTemplateExtension,hasPermissionTemplateExtension,messageTemplateExtension,dateCompareTemplateExtension,incrementDateTemplateExtension,xmlDateTemplateExtension,cropContentTemplateExtension,shortQNameTemplateExtension,scriptService,javaScriptProcessor,baseJavaScriptExtension,loggerScript,utilsScript,testScript,actionsScript,imapScript,searchScript,classificationScript,peopleScript,sessionScript,scriptBehaviour,avmScript,crossCopyScript,workflowScript,presenceScript,activitiesScript,indexTrackerThreadPoolExecutor,indexRecoveryComponentBase,indexRecoveryComponent,avmIndexRecoveryComponent,admIndexTrackerComponent,admIndexTrackerTrigger,avmIndexTrackerComponent,avmIndexTrackerTrigger,missingFullTextReindexComponent,missingFullTextReindexTrigger,authorityService,authorityDAO,authorityServiceScript,authenticationManager,authenticatedAuthenticationPassthroughProvider,Authentication,authenticationDao,SmbSessionListener,CifsAuthenticator,FtpAuthenticator,passwordEncoder,authenticationService,AuthenticationComponent,authenticationComponentBase,authenticationComponent,userRegistrySynchronizer,authenticationContext,userNameMatcher,personService,personServicePermissionsManager,homeFolderManager,baseHomeFolderProvider,companyHomeFolderProvider,guestHomeFolderProviderPermissionsManager,guestHomeFolderProvider,bootstrapHomeFolderProvider,defaultOnCreatePermissionsManager,defaultOnReferencePermissionsManager,personalHomeFolderProvider,userHomesHomeFolderProvider,ticketComponent,nameBasedUserNameGenerator,userNameGenerator,passwordGenerator,authenticationUtil,usageService,usageServiceImpl,contentUsageImpl,usageQuotaProtector,policyBehaviourQueue,policyTransactionHandlerFactory,policyBehaviourFilter,unboundPolicyBehaviourFilter,policyComponent,policyRegistration,dictionaryModelType,viewParser,importerComponent,importerComponentWithBehaviour,exporterComponent,repositoryExporterComponent,systemExporterImporter,systemInfoImporter,storeImporter,storeImporterViews,storeImporterTransactionHelper,userStoreImporter,systemStoreImporter,spacesArchiveStoreImporter,spacesStoreImporter,versionStoreImporter,version2StoreImporter,systemInfoBootstrap-base,userBootstrap-base,systemBootstrap-base,versionBootstrap-base,version2Bootstrap-base,spacesArchiveBootstrap-base,spacesBootstrap-base,shutdownBackstop,schemaBootstrap,jgroupsChannelFactory,avmBootstrap,dictionaryRepositoryBootstrap,systemInfoBootstrap,userBootstrap,systemBootstrap,versionBootstrap,version2Bootstrap,spacesArchiveBootstrap,spacesModelsBootstrap,spacesBootstrap,siteAVMBootstrap,workflowBootstrap,multiTenantBootstrap,thirdparty,OOoDirect,indexRecoveryBootstrap,avmIndexRecoveryBootstrap,descriptorComponent,configurationChecker,patchExecuter,moduleStarter,sysAdmin,fileServers,fileServerConfiguration,imap,OutboundSMTP,InboundSMTP,googledocs,schedulerStarter,userUsageTrackingComponent,Synchronization,workflowScheduler,Audit,repositoryHelper,scheduledPersistedActionServiceBootstrap,startupLog,interpreterBase,repoAdminService,repoAdminInterpreter,repoAdminInterpreterHelp,customModelsRepositoryLocation,customMessagesRepositoryLocation,workflowDeployer,workflowServiceImpl,workflowPackageImpl,workflowInterpreter,workflowInterpreterHelp,start-workflow,bpm_engineRegistry,bpm_engine,jbpm_configuration,jbpm_template,jbpm_engine,workflowPatchDeployer,customWorkflowDefsRepositoryLocation,workflowDefinitionType,avmNodeDAO,avmStoreDAO,versionRootDAO,childEntryDAO,avmStorePropertyDAO,versionLayeredNodeEntryDAO,avmDAOs,lookupCache,rawServices,orphanReaper,createStoreTxnListener,purgeStoreTxnListener,createVersionTxnListener,purgeVersionTxnListener,avmRepository,avmRemote,AVMSubmitTransactionListener,excludeRegexMatcher,excludeExtensionMatcher,globalPathExcluder,avmExpiredContentProcessor,avmLockingService,WebProjectService,WebProjectService_transaction,WebProjectService_security,webProjectService,AssetService,AssetService_transaction,AssetService_security,assetService,mlPropertyInterceptorLockingAware,avmLockingAwareNodeService,mlAwareLockingAwareNodeService,SandboxService,SandboxService_transaction,SandboxService_security,sandboxService,sandboxFactory,webProjectsScript,WCMPreviewURIService,PreviewURIService_transaction,PreviewURIService_security,previewURIService,previewURIServiceRegistry,basePreviewURIServiceProvider,virtServerPreviewURIService,nullPreviewURIService,wcm-submit,wcm-revert-snapshot,wcm-undo,wcmServicesResourceBundles,auditService,auditComponent,publicServiceIdentifier,auditModel.extractorRegistry,auditModel.extractor.simpleValue,auditModel.extractor.nullValue,auditModel.extractor.nodeName,auditModel.extractor.nodeType,auditModel.generatorRegistry,auditModel.generator.time,auditModel.generator.user,auditModel.generator.personFullName,attributeService,deploymentTestTransformer,deploymentEncryptor,deploymentCompressor,rmiFSRAdapter,encryptedRMIFSRAdapter,compressEncryptedRMIFSRAdapter,springHttpFSRAdapter,deploymentService,deploymentServiceReadTxnAdvisor,deploymentServiceWriteTxnAdvisor,DeploymentService,siteService_dictionaryBootstrap,siteService_permissionBootstrap,SiteService,SiteService_transaction,SiteService_security,siteServiceResourceBundles,siteRoleComparator,siteService,siteServiceScript,TaggingService,TaggingService_transaction,TaggingService_security,taggingService,update-tagscope,refresh-tagscope,scriptTaggingService,invitationService,InvitationService_security,InvitationService_transaction,InvitationService,invitationResourceBundles,invitationServiceScript,PatchService,PatchService_transaction,patchComponent,basePatch,patch.sample.01,patch.sample.02,bootstrapSpacesMessageSource,patch.savedSearchesFolder,patch.savedSearchesPermission,patch.updatePermissionData,patch.guestUser,patch.fixNodeSerializableValues,patch.updateGuestPermission,patch.guestPersonPermission,patch.spacesRootPermission,patch.categoryRootPermission,patch.contentPermission,patch.updateForumsIcons,patch.emailTemplatesFolder,patch.emailTemplatesContent,patch.descriptorUpdate,patch.scriptsFolder,patch.topLevelGroupParentChildAssociationTypePatch,patch.actionRuleDecouplingPatch,patch.systemWorkflowFolderPatch,patch.rssTemplatesFolderPatch,patch.uifacetsTemplatesPatch,patch.guestPersonPermission2,patch.schemaUpdateScript-V1.4-1,patch.uniqueChildName,patch.schemaUpdateScript-V1.4-2,patch.InvalidNameEnding,patch.systemDescriptorContent,patch.versionHistoryPerformance,patch.multilingualBootstrap,patch.LinkNodeFileExtension,patch.systemRegistryBootstrap,patch.userAndPersonUserNamesAsIdentifiers,patch.contentFormFolderType,patch.db-V2.1-JBPMData,patch.db-V2.1-NotNullColumns,patch.groupNamesAsIdentifiers,patch.invalidUserPersonAndGroup,patch.AVMGuidPatch,patch.webscripts,patch.webscriptsExtension,patch.AVMLayeredSnapshot,patch.groupMembersAsIdentifiers,patch.redeploySubmitProcess,patch.ReadmeTemplate,patch.webScriptsReadme,patch.db-V2.1-JBPMProcessKey,patch.db-V2.1-VersionColumns2,patch.db-V1.4-TxnCommitTimeIndex,patch.db-V2.0-ContentUrls,patch.webscripts2,patch.customModels,patch.customMessages,patch.customWebClientExtension,patch.redeploySubmitProcess2,patch.db-V2.1-RemoveWcmSubmittedAspect,patch.webscripts3,patch.customWorkflowDefs,patch.avmStoreAsIdentifier,patch.avmFormPropertyIdentifier,patch.formsFolder,patch.tagRootCategory,patch.db-V3.4-UsageTables,patch.deploymentMigration,patch.redeploySubmitProcess3,patch.db-V2.2-ACL-From-2.1-A,patch.db-V2.2-ACL,patch.updateAvmPermissionData,patch.db-V2.2-CleanNodeStatuses,patch.db-V2.2-0-CreateMissingTables,patch.db-V2.2-2-MoveQNames,patch.db-V2.2-Upgrade-From-2.1,patch.db-V2.2-Upgrade-From-2.2SP1,patch.avmWebProjectInheritPermissions02,patch.updateDmPermissions,patch.db-V3.0-0-CreateActivitiesExtras,patch.db-V3.0-ActivityTables,patch.createSiteStore,patch.sitesFolder,patch.sitePermissionRefactorPatch,patch.migrateVersionStore,patch.inviteEmailTemplate,patch.calendarNamespaceUri,patch.db-V2.1-AuditPathIndex,patch.spacesStoreGuestPermission,patch.redeploySubmitProcess4,patch.redeploySubmitProcess5,patch.deploySubmitDirectProcess,patch.resetWCMToGroupBasedPermissionsPatch,patch.wcmPostPermissionSnapshotPatch3,patch.moveWCMToGroupBasedPermissionsPatch,patch.wcmPostPermissionSnapshotPatch2,patch.redeploySubmitProcess6,patch.redeploySubmitProcess7,patch.db-V2.2-Person-3,patch.webSiteAddModerated,patch.invitationMigration,patch.db-V3.2-Remove-AVM-Issuer,patch.mtShareExistingTenants,patch.redeployInvitationProcess,patch.db-V3.2-LockTables,patch.zonedAuthorities,patch.authorityMigration,patch.authorityDefaultZonesPatch,patch.db-V3.2-ContentTables,patch.db-V3.2-Modify-AVM-MimeType,patch.db-V3.2-Upgrade-JBPM,patch.imapFolders,patch.db-V3.2-PropertyValueTables,patch.db-V3.2-AuditTables,patch.db-V3.1-Allow-IPv6,patch.personUsagePatch,patch.db-V3.2-Child-Assoc-QName-CRC,patch.fixNameCrcValues-2,patch.redeployNominatedInvitationProcessWithPropsForShare,patch.db-V3.2-ContentTables2,patch.db-V3.3-Remove-VersionCount,patch.rendition.rendering_actions,patch.thumbnailsAssocQName,patch.emailInviteAndNotifyTemplatesFolder,patch.transferServiceFolder,patch.convertContentUrls,patch.fixAuthoritiesCrcValues,patch.updateMimetypes1,patch.db-V3.3-modify-index-permission_id,patch.db-V3.2-AddFKIndexes,patch.db-V3.3-Fix-Repo-Seqs,patch.db-V3.3-Fix-AVM-Seqs,patch.db-V3.4-property-unique-ctx-value,patch.db-V3.4-child-assoc-indexes,patch.db-V3.3-JBPM-Extra,patch.db-V3.3-Node-Prop-Serializable,patch.migrateAttrTenants,patch.migrateAttrAVMLocks,patch.migrateAttrPropBackedBeans,patch.migrateAttrChainingURS,patch.migrateAttrDelete,patch.replication.replication_actions,patch.transfer.targetrulefolder,patch.transfer.targetrule,patch.actions.scheduledfolder,patch.updateMimetypes2,patch.db-V3.2-AddFKIndexes-2,patch.eliminateDuplicates,ftsIndexerTrigger,tempFileCleanerTrigger,contentStoreCleanerJobDetail,contentStoreCleanerTrigger,contentUrlConverterJobDetail,contentUrlConverterTrigger,nodeServiceCleanupJobDetail,nodeServiceCleanupTrigger,indexBackupJobDetail,indexBackupTrigger,ehCacheTracerJob,avmOrphanReaperJob,avmExpiredContentTrigger,userUsageCollapseJob,feedCleanerJobDetail,feedCleanerTrigger,feedGeneratorJobDetail,feedGeneratorTrigger,postLookupJobDetail,postLookupTrigger,postCleanerJobDetail,postCleanerTrigger,migrateVersionStoreJobDetail,migrateVersionStoreTrigger,versionStoreMigrationCleanupJob,taggingStartupJobDetail,taggingStartupTrigger,JCR.Repository,JCR.DictionaryBootstrap,avmRemoteTransport,avmRemoteService,avmSyncServiceTransport,avmSyncServiceTransportRMI,rmiAuthenticationService,repoRemoteService,RepoRemoteService,repoRemoteTransport,repoRemoteTransportRMI,actionServiceTransport,actionServiceTransportRMI,officeResourceBundles,portletsResourceBundles,BlogIntegrationService,BlogIntegrationService_transaction,BlogIntegrationService_security,blogIntegrationService,baseBlogIntegrationImplmentation,wordPressBlogIntegration,typePadBlogIntegration,blog-post,RatingService,RatingService_transaction,RatingService_security,ratingService,ratingSchemeRegistry,baseRatingScheme,likesRatingScheme,fiveStarRatingScheme,ratingServiceScript,RenditionService,RenditionService_transaction,RenditionService_security,renditionService,perform-rendition,renditionDefinitionPersister,renditionLocationResolver,renderingActionResourceBundles,baseRenderingAction,baseTemplateRenderingAction,reformat,imageRenderingEngine,freemarkerRenderingEngine,htmlRenderingEngine,compositeRenderingEngine,xsltRenderingEngine,xsltFunctions,renditionedAspect,renditionServiceScript,Replication,replicationParams,ReplicationService,ReplicationService_transaction,ReplicationService_security,replicationService,replicationDefinitionPersister,replicationActionExecutor,replicationServiceScript,ThumbnailService,ThumbnailService_transaction,ThumbnailService_security,thumbnailService,thumbnailRenditionConvertor,thumbnailRegistry,create-thumbnail,update-thumbnail,thumbnailServiceScript,createThumbnailActionFilter,PreferenceService,PreferenceService_transaction,PreferenceService_security,preferenceService,preferenceServiceScript,transformer.worker.Pdf2swf,transformer.Pdf2swf,transformer.complex.OpenOffice.Pdf2swf,transformer.complex.Text.Pdf2swf,transformer.complex.Archive.Pdf2swf,formResourceBundles,FormService,FormService_transaction,FormService_security,formService,formProcessorRegistry,nodeFilterRegistry,typeFilterRegistry,baseFormProcessor,nodeFormProcessor,typeFormProcessor,baseFormFilter,formServiceScript,fieldProcessorRegistry,baseFieldProcessor,qnameFieldProcessor,propertyFieldProcessor,associationFieldProcessor,encodingFieldProcessor,mimetypeFieldProcessor,sizeFieldProcessor,defaultFieldProcessor,workflowFormProcessor,taskFormProcessor,workflowFilterRegistry,taskFilterRegistry,packageItemsFieldProcessor,transitionsFieldProcessor,messageFieldProcessor,taskOwnerFieldProcessor,CMISMapping,CMISService,CMISDictionaryService,CMIS.DictionaryBootstrap,CMISQueryService,CMISRenditionService,CMISChangeLogService,CMISChangeLogDataExtractor,CMISAccessControlService,lucene.sql.cmis.strict,lucene.sql.alfresco,adm.luceneQueryEngine,adm.luceneQueryEngineSecurity,period.none,period.immediately,period.days,period.weeks,period.months,period.quarters,period.years,period.end.of.month,period.end.of.quarter,period.end.of.year,period.end.of.financial.month,period.end.of.financial.quarter,period.end.of.financial.year,period.cron,period.xml.duration,transferService,transferService2,transferTransmitter,transferReporter,transferManifestNodeFactory,alienProcessor,transferReceiver,transferProgressMonitor,commit-transfer,transferManifestProcessorFactory,transferNodeResolverFactory,transferServiceResourceBundles,TransferService_security,TransferService_transaction,TransferService,TransferService2,TransferReceiver_security,TransferReceiver_transaction,TransferReceiver,transfer-async,transferServiceScript,NodeCrawlerFactory,userBootstrap-mt,systemBootstrap-mt,versionBootstrap-mt,version2Bootstrap-mt,spacesArchiveBootstrap-mt,spacesBootstrap-mt,baseMultiTAdminService,moduleService,module.baseComponent,cxf,org.apache.cxf.bus.spring.BusApplicationListener,org.apache.cxf.bus.spring.BusWiringBeanFactoryPostProcessor,org.apache.cxf.bus.spring.Jsr250BeanPostProcessor,org.apache.cxf.bus.spring.BusExtensionPostProcessor,org.apache.cxf.resource.ResourceManager,org.apache.cxf.configuration.Configurer,org.apache.cxf.binding.BindingFactoryManager,org.apache.cxf.transport.DestinationFactoryManager,org.apache.cxf.transport.ConduitInitiatorManager,org.apache.cxf.wsdl.WSDLManager,org.apache.cxf.phase.PhaseManager,org.apache.cxf.workqueue.WorkQueueManager,org.apache.cxf.buslifecycle.BusLifeCycleManager,org.apache.cxf.endpoint.ServerRegistry,org.apache.cxf.endpoint.ServerLifeCycleManager,org.apache.cxf.endpoint.ClientLifeCycleManager,org.apache.cxf.transports.http.QueryHandlerRegistry,org.apache.cxf.endpoint.EndpointResolverRegistry,org.apache.cxf.headers.HeaderManager,org.apache.cxf.catalog.OASISCatalogManager,org.apache.cxf.endpoint.ServiceContractResolverRegistry,org.apache.cxf.binding.soap.SoapBindingFactory,org.apache.cxf.binding.soap.SoapTransportFactory,org.apache.cxf.binding.soap.customEditorConfigurer,org.apache.cxf.jaxrs.JAXRSBindingFactory,org.apache.cxf.transport.servlet.ServletTransportFactory,lotusWSPlaceholderConfigurer,org.apache.cxf.jaxws.EndpointImpl—1950028618,org.apache.cxf.jaxws.EndpointImpl–570561460,org.apache.cxf.jaxws.EndpointImpl–545181252,lotusContentServiceImpl,lotusDocumentServiceImpl,lotusLibraryServiceImpl,quickrPathHelper,quickrDocumentHelper,quickrPermissionHelper,atomBasedFeedService,lotusAtomBasedFeedServiceImpl,atomFeedProvider,atomEntryProvider,atomServiceProvider,atomErrorProvider,atomNodeRefProvider,quickrAuthenticationInterceptor,quickrServerConnector,quickrServlet,quickrServer,vtiResourceBundles,vtiProperties,vtiServer,vtiServerConnector,vtiFilter,vtiRequestDispatcher,vtiInfAction,vtiBinAction,vtiDownloadContentAction,vtiResourceAction,vtiPropfindAction,vtiLockAction,vtiPropPatchAction,vtiUnlockAction,vtiIfHeaderAction,vtiBrowserAction,vtiSoapAction,abstractVtiMethod,server_version_method,open_service_method,url_to_web_url_method,FileOpen_dialog,SaveForm_dialog,list_documents_method,getDocsMetaInfo_method,get_document_method,checkout_document_method,uncheckout_document_method,remove_documents_method,put_document_method,create_url-directories_method,create_url-directory_method,move_document_method,checkin_document_method,webUrlFromPageUrlEndpoint,checkOutFile,checkInFile,undoCheckOutFile,getDwsMetaDataEndpoint,getDwsDataEndpoint,createDwsEndpoint,getVersionsEndpoint,restoreVersionEndpoint,deleteVersionEndpoint,deleteAllVersionsEndpoint,getUserLoginFromEmailEndpoint,addUserCollectionToRoleEndpoint,createFolderEndpoint,deleteFolderEndpoint,deleteDwsEndpoint,renameDwsEndpoint,removeDwsUserEndpoint,updateDwsDataEndpoint,getMeetingWorkspacesEndpoint,getMeetingsInformationEndpoint,createWorkspaceEndpoint,addMeetingFromICalEndpoint,updateMeetingFromICalEndpoint,removeMeetingEndpoint,deleteWorkspaceEndpoint,webscript.org.alfresco.vti.vti-server.get,versionsServiceHandler,dwsServiceHandler,userGroupServiceHandler,meetingServiceHandler,checkOutCheckInServiceHandler,vtiHandlerTarget,vtiDocumentHelper,vtiPathHelper,handlerExceptionAdvice,handlerExceptionPointcutAdvisor,vtiHandler,shareUtils,vtiAuthenticationHandler,org_alfresco_module_dod5015_dictionaryBootstrap,org_alfresco_module_dod5015_customModelsRepositoryLocation,org_alfresco_module_dod5015_dictionaryRepositoryBootstrap,org_alfresco_module_dod5015_userRolesExtractor,org_alfresco_module_dod5015_namePathExtractor,org_alfresco_module_dod5015_nodeRefPathExtractor,org_alfresco_module_dod5015_identifierExtractor,org_alfresco_module_dod5015_permissionBootstrap,org_alfresco_module_dod5015_bootstrapData,recordComponentIdentifierAspect,rmEntryVoter,afterRm,RecordsManagementServiceRegistry,org_alfresco_module_dod5015_dispositionSelectionStrategy,recordCopyBehaviours,recordsManagementService,RecordsManagementService,RecordsManagementService_transaction,RecordsManagementService_security,recordsManagementSecurityService,RecordsManagementSecurityService,RecordsManagementSecurityService_transaction,RecordsManagementSecurityService_security,recordsManagementActionService,RecordsManagementActionService,RecordsManagementActionService_transaction,RecordsManagementActionService_security,recordsManagementEventService,RecordsManagementEventService,RecordsManagementEventService_transaction,RecordsManagementEventService_security,recordsManagementAdminService,RecordsManagementAdminService,RecordsManagementAdminService_transaction,RecordsManagementAdminService_security,recordsManagementAuditService,RecordsManagementAuditService,RecordsManagementAuditService_transaction,RecordsManagementAuditService_security,customEmailMappingService,CustomEmailMappingService_transaction,CustomEmailMappingService_security,CustomEmailMappingService,recordsManagementNotificationService,RecordsManagementNotificationService,RecordsManagementNotificationService_transaction,RecordsManagementNotificationService_security,caveatConfigService,rmListOfValuesContraintInit,CaveatConfigService_security,CaveatConfigService_transaction,CaveatConfigService,recordsManagementSearchBehaviour,DispositionPeriodProperties,rmBaseCapability,rmAccessAuditCapability,rmAddModifyEventDatesCapability,rmApproveRecordsScheduledForCutoffCapability,rmAttachRulesToMetadataPropertiesCapability,rmAuthorizeAllTransfersCapability,rmAuthorizeNominatedTransfersCapability,rmChangeOrDeleteReferencesCapability,rmCloseFoldersCapability,rmCreateAndAssociateSelectionListsCapability,rmCreateModifyDestroyClassificationGuidesCapability,rmCreateModifyDestroyEventsCapability,rmCreateModifyDestroyFileplanMetadataCapability,rmCreateModifyDestroyFileplanTypesCapability,rmCreateModifyDestroyFoldersCapability,rmCreateModifyDestroyRecordTypesCapability,rmCreateModifyDestroyReferenceTypesCapability,rmCreateModifyDestroyRolesCapability,rmCreateModifyDestroyTimeframesCapability,rmCreateModifyDestroyUsersAndGroupsCapability,rmCreateModifyRecordsInCuttoffFoldersCapability,rmCycleVitalRecordsCapability,rmDeclareAuditAsRecordCapability,rmDeclareRecordsCapability,rmDeclareRecordsInClosedFoldersCapability,rmDeleteAuditCapability,rmDeleteLinksCapability,rmDeleteRecordsCapability,rmDestroyRecordsCapability,rmDestroyRecordsScheduledForDestructionCapability,rmDisplayRightsReportCapability,rmEditDeclaredRecordMetadataCapability,rmEditNonRecordMetadataCapability,rmEditRecordMetadataCapability,rmEditSelectionListsCapability,rmEnableDisableAuditByTypesCapability,rmExportAuditCapability,rmExtendRetentionPeriodOrFreezeCapability,rmFileRecordsCapability,rmMakeOptionalPropertiesMandatoryCapability,rmManageAccessControlsCapability,rmManageAccessRightsCapability,rmManuallyChangeDispositionDatesCapability,rmMapClassificationGuideMetadataCapability,rmMapEmailMetadataCapability,rmMoveRecordsCapability,rmPasswordControlCapability,rmPlanningReviewCyclesCapability,rmReOpenFoldersCapability,rmSelectAuditMetadataCapability,rmTriggerAnEventCapability,rmUndeclareRecordsCapability,rmUnfreezeCapability,rmUpdateClassificationDatesCapability,rmUpdateExemptionCategoriesCapability,rmUpdateTriggerDatesCapability,rmUpdateVitalRecordCycleInformationCapability,rmUpgradeDowngradeAndDeclassifyRecordsCapability,rmViewRecordsCapability,rmViewUpdateReasonsForFreezeCapability,rmCreate,rmDelete,rmUpdate,rmUpdateProperties,rmDeclare,rmWriteContent,rmActionResourceBundles,rmAction,rmProxyAction,actionSecurity,actionProxy,file_proxy,file_security,file,cutoff_proxy,cutoff_security,cutoff,unCutoff_proxy,unCutoff_security,unCutoff,destroy_proxy,destroy_security,destroy,retain_proxy,retain_security,retain,openRecordFolder_proxy,openRecordFolder_security,openRecordFolder,closeRecordFolder_proxy,closeRecordFolder_security,closeRecordFolder,reviewed_proxy,reviewed_security,reviewed,setupRecordFolder_proxy,setupRecordFolder_security,setupRecordFolder,declareRecord_proxy,declareRecord_security,declareRecord,undeclareRecord_proxy,undeclareRecord_security,undeclareRecord,freeze_proxy,freeze_security,freeze,unfreeze_proxy,unfreeze_security,unfreeze,relinquishHold_proxy,relinquishHold,editHoldReason_proxy,editHoldReason_security,editHoldReason,editReviewAsOfDate_proxy,editReviewAsOfDate_security,editReviewAsOfDate,editDispositionActionAsOfDate_proxy,editDispositionActionAsOfDate_security,editDispositionActionAsOfDate,broadcastVitalRecordDefinition_proxy,broadcastVitalRecordDefinition_security,broadcastVitalRecordDefinition,broadcastDispositionActionDefinitionUpdate_proxy,broadcastDispositionActionDefinitionUpdate_security,broadcastDispositionActionDefinitionUpdate,completeEvent_proxy,completeEvent_security,completeEvent,undoEvent_proxy,undoEvent_security,undoEvent,transfer_proxy,transfer_security,transfer,transferComplete_proxy,transferComplete,accession_proxy,accession_security,accession,accessionComplete_proxy,accessionComplete,splitEmail,splitEmail_proxy,applyScannedRecord_proxy,applyScannedRecord,applyPdfRecord_proxy,applyPdfRecord,applyDigitalPhotographRecord_proxy,applyDigitalPhotographRecord,applyWebRecord_proxy,applyWebRecord,scriptRecordsManagementService,rmEventResourceBundles,rmEventType,rmEventType.simple,rmEventType.superseded,rmEventType.obsolete,rmEventType.crossReferencedRecordTransfered,scheduledNotifyOfRecordsDueForReviewJobDetail,scheduledNotifyOfRecordsDueForReviewJobTrigger,scheduledDispositionLifecyceleJobDetail,scheduledDispositionLifecyceleJobTrigger,RecordsManagementBootstrap,rmConfigServiceScript,rmNodeFormFilter,rmTypeFormFilter,webscript.org.alfresco.rma.rmaction.post,rmBaseWebscript,webscript.org.alfresco.rma.dodcustomtypes.get,webscript.org.alfresco.rma.custompropdefinitions.get,webscript.org.alfresco.rma.custompropdefinition.put,webscript.org.alfresco.rma.custompropdefinition.post,webscript.org.alfresco.rma.custompropdefinition.delete,webscript.org.alfresco.rma.customrefdefinitions.get,webscript.org.alfresco.rma.customrefdefinition.put,webscript.org.alfresco.rma.customrefdefinition.post,webscript.org.alfresco.rma.customrefs.get,webscript.org.alfresco.rma.customref.post,webscript.org.alfresco.rma.customref.delete,webscript.org.alfresco.rma.dispositionschedule.get,webscript.org.alfresco.rma.dispositionactiondefinitions.post,webscript.org.alfresco.rma.dispositionactiondefinition.put,webscript.org.alfresco.rma.dispositionactiondefinition.delete,webscript.org.alfresco.rma.dispositionlifecycle.get,webscript.org.alfresco.rma.listofvalues.get,webscript.org.alfresco.rma.rmauditlog.get,webscript.org.alfresco.rma.rmauditlog.post,webscript.org.alfresco.rma.rmauditlog.put,webscript.org.alfresco.rma.rmauditlog.delete,webscript.org.alfresco.rma.export.post,webscript.org.alfresco.rma.import.post,rmBaseTransferWebscript,webscript.org.alfresco.rma.transfer.get,webscript.org.alfresco.rma.transferreport.get,webscript.org.alfresco.rma.transferreport.post,webscript.org.alfresco.rma.admin.rmrole.rmroles.get,webscript.org.alfresco.rma.admin.rmrole.rmroles.post,webscript.org.alfresco.rma.admin.rmrole.rmrole.get,webscript.org.alfresco.rma.admin.rmrole.rmrole.put,webscript.org.alfresco.rma.admin.rmrole.rmrole.delete,webscript.org.alfresco.rma.admin.rmevent.rmeventtypes.get,webscript.org.alfresco.rma.admin.rmevent.rmevents.get,webscript.org.alfresco.rma.admin.rmevent.rmevents.post,webscript.org.alfresco.rma.admin.rmevent.rmevent.get,webscript.org.alfresco.rma.admin.rmevent.rmevent.put,webscript.org.alfresco.rma.admin.rmevent.rmevent.delete,webscript.org.alfresco.rma.admin.emailmap.get,webscript.org.alfresco.rma.admin.emailmap.post,webscript.org.alfresco.rma.admin.emailmap.put,webscript.org.alfresco.rma.rmconstraints.get,webscript.org.alfresco.rma.userrightsreport.get,webscript.org.alfresco.rma.bootstraptestdata.get,webscript.org.alfresco.rma.applydodcertmodelfixes.get,webscript.org.alfresco.rma.applyfixmob1573.get,wcmquickstartmodule_contextParserService,wcmquickstartmodule_contextParser,wcmquickstartmodule_sectionIdContextParser,wcmquickstartmodule_pdfRenditionPathContextParser,wcmquickstartmodule_siteIdContextParser,wcmquickstartmodule_websiteOwnerContextParser,wcmquickstartmodule_sectionPathContextParser,wcmquickstartmodule_dictionaryBootstrap,wcmquickstartmodule_sectionType,wqsmodule_sectionTypesToIgnore,wqsmodule_sectionAssetCollections,wqsmodule_sectionHierarchyProcessor,wcmquickstartmodule_webassetCollectionFolderType,wcmquickstartmodule_webassetCollectionType,wcmquickstartmodule_webassetAspect,wcmquickstartmodule_imageType,wcmquickstartmodule_tagscopeAspect,wcmquickstartmodule_taggableAspect,wcmquickstartmodule_visitorFeedback,wcmquickstartmodule_visitorFeedbackSummary,wcmquickstartmodule_article,wcmquickstartmodule_website,webscript.org.alfresco.module.wcmquickstart.assetcollection.get,webscript.org.alfresco.module.wcmquickstart.asset.get,webscript.org.alfresco.module.wcmquickstart.asset.post,webscript.org.alfresco.module.wcmquickstart.assetsearch.get,wqsmodule_assetSerializerFactory,webscript.org.alfresco.module.wcmquickstart.websiteinfo.get,webscript.org.alfresco.module.wcmquickstart.fixwebassets1.get,webscript.org.alfresco.module.wcmquickstart.fixwebassets2.get,webscript.org.alfresco.module.wcmquickstart.loadwebsitedata.get,wqsmodule_siteImportFileLocations,webscript.org.alfresco.module.wcmquickstart.updatewebsiterenditions.get,webscript.org.alfresco.module.wcmquickstart.webassetpreviewer.get,wcmquickstartmodule_renditionHelper,wqsmodule_renditionDefinitions,wcmquickstartmodule_renditionBootstrap,org_alfresco_module_wcmquickstart_processReceivedFeedbackTrigger,feedbackProcessor,feedbackProcessorHandler,commentFeedbackProcessorHandler,contactFeedbackProcessorHandler,org_alfresco_module_wcmquickstart_processAssetAvailabilityTrigger,org_alfresco_module_wcmquickstart_processPublishingQueues,org_alfresco_module_wcmquickstart_dynamicQueryRefreshProcess,org_alfresco_module_wcmquickstart_transferService,org_alfresco_module_wcmquickstart_transferTransmitter,org_alfresco_module_wcmquickstart_transferManifestNodeFactory,org_alfresco_module_wcmquickstart_nodeRefMapper,org_alfresco_module_wcmquickstart_publishingService,wqsmodule_publishingCrawlerConfigurer,org.alfresco.module.org_alfresco_module_wcmquickstart.publish.PublishBootstrap#0,workflowDeployer$child#0,webqs_publish,webqs_publishTree,org_alfresco_module_wcmquickstart_configBootstrap,org_alfresco_module_wcmquickstart_propertyBootstrap,org_alfresco_module_wcmquickstart_siteHelper,wqsmodule_defaultWebsiteLocales,org_alfresco_module_wcmquickstart_collectionHelper,web.configsource,web.config,webscripts.abdera,webscripts.formatregistry,webscripts.formatmap,webscripts.adaptorset,webscripts.adaptors,webscripts.formats,webscripts.formats.IE,webscripts.resources,webscripts.classpathstore,webscripts.remotestore,webscripts.store,webscripts.store.alfresco,webscripts.searchpath,webscripts.abstractcontainer,webscripts.web.templateregistry,webscripts.web.scriptregistry,webscripts.container,webscripts.templateprocessor.freemarker,webscripts.scriptprocessor.javascript,webscripts.script.remote,webscripts.connector.provider,webscripts.index,webscripts.registry,connector.service,credential.vault.provider,credential.vault.provider.xml,webscript,webscriptdesc,webscript.default,scriptDebugger,webscriptHandlerMappings,urlPathHelper,handlerMappings,endpointController,resourceController,webscriptViewResolver,webscript.org.springframework.extensions.webscripts.index.get,webscript.org.springframework.extensions.webscripts.indexall.get,webscript.org.springframework.extensions.webscripts.indexfamily.get,webscript.org.springframework.extensions.webscripts.indexlifecycle.get,webscript.org.springframework.extensions.webscripts.indexuri.get,webscript.org.springframework.extensions.webscripts.indexpackage.get,webscript.org.springframework.extensions.webscripts.indexpackagedoc.get,webscript.org.springframework.extensions.webscripts.index.post,webscript.org.springframework.extensions.webscripts.scriptdescription.get,webscript.org.springframework.extensions.webscripts.scriptdump.get,webscript.org.springframework.extensions.webscripts.scriptinstall.post,webscript.org.springframework.extensions.webscripts.jsdebugger.get,webscript.org.springframework.extensions.webscripts.jsdebugger.post,webClientConfigSource,repoUrlConfigSource,globalConfigSharedCache,globalConfigCache,webClientConfigService,webClientConfigAdminInterpreter,webClientConfigAdminInterpreterHelp,dataDictionary,FormsService,Schema2XFormsProperties,webscripts.authenticator.webclient,webscripts.authenticator.jsr168.webclient,RemoteUserMapper,AuthenticationFilter,defaultAuthenticationFilter,GlobalAuthenticationFilter,WebscriptAuthenticationFilter,WebDavAuthenticationFilter,SharepointAuthenticationHandler,extension.workflowBootstrap,patch.wcmFolders,wcm_deployment_receiver,patch.wcmDeployed,sqlMapClient,webscripts.configsource,webscripts.config,webscript.org.alfresco.repository.metadata.bulkmetadata.post,webscripts.repostore,webscripts.store.repo.extension,webscripts.store.repo,webscripts.store.client.extension,webscripts.store.client,webscripts.repo.imageresolver,webscripts.repo.registry.templateprocessor,webscripts.repo.registry.scriptprocessor,webscripts.repo.templateprocessor.factory,webscripts.repo.templateprocessor,webscripts.repo.scriptprocessor.factory,webscripts.repo.scriptprocessor,org.springframework.extensions.webscripts.TemplateProcessorRegistrar#0,org.springframework.extensions.webscripts.ScriptProcessorRegistrar#0,webscripts.index.prototype,webscripts.registry.prototype,webscripts.js.paging,webscripts.authenticator.basic,webscripts.authenticator.jsr168,webscripts.authenticator.facebook,facebook.service,webscripts.cmis.atom.extension,webscripts.cmis.adaptors,webscripts.cmis.formats,CMISReferenceFactory,webscripts.js.cmis,webscript.org.alfresco.cmis.test.post,webscript.org.alfresco.cmis.content.get,webscript.org.alfresco.cmis.content.put,webscript.org.alfresco.cmis.content.delete,webscript.org.alfresco.cmis.queries.post,webscript.org.alfresco.cmis.query.get,webscript.org.alfresco.jsdebugger.get,webscript.org.alfresco.jsdebugger.post,webscript.org.alfresco.repository.login.get,webscript.org.alfresco.repository.login.post,webscript.org.alfresco.repository.loginticket.get,webscript.org.alfresco.repository.loginticket.delete,webscript.org.alfresco.repository.search.searchengines.get,webscript.org.alfresco.repository.search.keywordsearch.get,webscript.org.alfresco.repository.search.personsearch.get,webscript.org.alfresco.repository.search.searchproxy.get,webscript.org.alfresco.repository.content.stream,webscript.org.alfresco.repository.store.content.put,webscript.org.alfresco.repository.store.remoteavm.get,webscript.org.alfresco.repository.store.remoteavm.post,webscript.org.alfresco.repository.store.remoteavm.delete,webscript.org.alfresco.webframework.avmstore.get,webscript.org.alfresco.webframework.avmstore.post,webscript.org.alfresco.webframework.avmstore.delete,webscript.org.alfresco.repository.touch.get,webscript.org.alfresco.repository.authentication.get,webscript.org.alfresco.repository.content.mimetypes.get,webscript.org.alfresco.repository.rendition.patchthumbnailsasrenditions.get,webscript.org.alfresco.repository.activities.feed.userfeed.get,webscript.org.alfresco.repository.activities.feed.userfeed-admin.get,webscript.org.alfresco.repository.activities.feed.sitefeed.get,webscript.org.alfresco.repository.activities.templates.get,webscript.org.alfresco.repository.activities.template.get,templates.classpathstore,activity.template.store.client.extension,activity.template.store.client,activity.template.searchpath,webscript.org.alfresco.repository.invite.invite.get,webscript.org.alfresco.repository.invite.inviteresponse.put,webscript.org.alfresco.repository.invite.invites.get,webscript.org.alfresco.repository.invite.invite-by-ticket.get,webscript.org.alfresco.repository.person.changepassword.post,rhinoScriptDebugger,webscript.org.alfresco.repository.admin.jmxdump.get,webscript.dictionary,webscript.org.alfresco.repository.dictionary.classes.get,webscript.org.alfresco.repository.dictionary.class.get,webscript.org.alfresco.repository.dictionary.subclasses.get,webscript.org.alfresco.repository.dictionary.property.get,webscript.org.alfresco.repository.dictionary.properties.get,webscript.org.alfresco.repository.dictionary.association.get,webscript.org.alfresco.repository.dictionary.associations.get,webscript.org.alfresco.repository.imap.imap-enabled.get,commentServiceScript,abstractRuleWebScript,webscript.org.alfresco.repository.rule.ruletypes.get,webscript.org.alfresco.repository.rule.actiondefinitions.get,webscript.org.alfresco.repository.rule.actionconditiondefinitions.get,webscript.org.alfresco.repository.rule.rule.delete,webscript.org.alfresco.repository.rule.rule.get,webscript.org.alfresco.repository.rule.rule.post,webscript.org.alfresco.repository.rule.rule.put,webscript.org.alfresco.repository.rule.rules.get,webscript.org.alfresco.repository.rule.inheritedrules.get,webscript.org.alfresco.repository.rule.ruleset.get,webscript.org.alfresco.repository.rule.actionConstraints.get,webscript.org.alfresco.repository.rule.actionConstraint.get,webscript.org.alfresco.repository.rule.actionQueue.post,webscript.org.alfresco.repository.transfer.transfer.post,abstractRatingWebScript,webscript.org.alfresco.repository.rating.ratings.get,webscript.org.alfresco.repository.rating.rating.post,webscript.org.alfresco.repository.rating.rating.delete,webscript.org.alfresco.repository.rating.ratingdefinitions.get,abstractWorkflowWebScript,webscript.org.alfresco.repository.workflow.task-instances.get,webscript.org.alfresco.repository.workflow.task-instance.get,webscript.org.alfresco.repository.workflow.task-instance.put,webscript.org.alfresco.repository.workflow.workflow-definitions.get,webscript.org.alfresco.repository.workflow.workflow-instance.get,webscript.org.alfresco.repository.workflow.workflow-instances.get,webscript.org.alfresco.repository.workflow.workflow-instances-for-node.get,webscript.org.alfresco.repository.workflow.workflow-instance.delete,abstractAuditWebScript,webscript.org.alfresco.repository.audit.control.get,webscript.org.alfresco.repository.audit.control.post,webscript.org.alfresco.repository.audit.clear.post,webscript.org.alfresco.repository.audit.query.get,abstractReplicationWebScript,webscript.org.alfresco.repository.replication.replication-definitions.get,webscript.org.alfresco.repository.replication.replication-definitions.post,webscript.org.alfresco.repository.replication.replication-definition.get,webscript.org.alfresco.repository.replication.replication-definition.put,webscript.org.alfresco.repository.replication.replication-definition.delete,abstractActionWebScript,abstractExecuteActionWebScript,webscript.org.alfresco.repository.action.running-action.get,webscript.org.alfresco.repository.action.running-action.delete,webscript.org.alfresco.repository.action.running-actions.get,webscript.org.alfresco.repository.action.running-replication-actions.get,webscript.org.alfresco.repository.action.running-actions.post,webscript.org.alfresco.repository.action.running-replication-actions.post,org.apache.cxf.jaxws.EndpointImpl—1994145354,org.apache.cxf.jaxws.EndpointImpl–436825742,org.apache.cxf.jaxws.EndpointImpl—139464023,org.apache.cxf.jaxws.EndpointImpl–945107716,org.apache.cxf.jaxws.EndpointImpl–1084369008,org.apache.cxf.jaxws.EndpointImpl–155696398,org.apache.cxf.jaxws.EndpointImpl—1547514348,org.apache.cxf.jaxws.EndpointImpl—1596623668,org.apache.cxf.jaxws.EndpointImpl—1360867549,dmServicesProxyCreator,dmTransactionWrappingInterceptor,exceptionPointcutAdvisor,propertiesUtils,dmRepositoryService,dmNavigationService,dmObjectService,dmMultiFilingService,dmVersioningService,dmDiscoveryService,dmRelationshipService,dmPolicyService,dmAclService,dmAbstractService,fileTypeIconRetriever,saajInInterceptor,saajOutInterceptor,wss4jInInterceptor,wss4jOutInterceptor,wss4jOutInterceptorWithMTOM,authenticationTokenCallback,authenticationInterceptor,authenticationClearInterceptor,ticketCallbackHandler,CMLUtil,authenticationWebService,repositoryWebService,dictionaryWebService,contentWebService,authoringWebService,classificationWebService,actionWebService,accessControlWebService,administrationWebService]; root of factory hierarchy
Brenda
mcook
Hmm… ok so it seems its properly getting the beanFactory… that null being passed in to the useBeanFactory function just tells it to use the default factory… and the log shows that it exists so thats not the problem…
 // The following implementation is derived from Spring Modules v0.4
        BeanFactoryLocator factoryLocator = new JbpmFactoryLocator();
        BeanFactoryReference factory = factoryLocator.useBeanFactory(null);
        initialiseHandler(factory.getFactory());
mcook
Does the transition work without the action?
bcoulson
Yes the transition does work without this action or if I replace the action with a JavaScript action, it works.
mcook
How are you packaging and deploying the class?  What directory do you place it in?  What api are you using to compile the class?
bcoulson
I am packaging and deploying class using an ant script. I create a jar file and then explode that jar file into the <alfresco_root>/tomcat/shared/classes directory structure. The build script is based off the one from the someCo samples. Right now AlfrescoHelper is the only one that we actually have written as we are still in prototype/proof of concept mode.
One thing I found interesting is that I had to put the following jar files in the  C:\Alfresco\tomcat\shared\lib directory, otherwise I received ClassNotFoundException error when I tried to access my class.
    alfresco-core-3.4.d.jar
    alfresco-repository-3.4.d.jar
    commons-logging-1.1.jar
    jbpm-jpdl.jar
    org.springframework.beans-3.0.0.jar
    springmodules-jbpm31.jar
I found this odd as they are in the <alfresco_root>/tomcat/webapps/alfresco/lib directory already. As I am writing this, I am wondering if this may be my problem - do I have the right jar files here? Am I missing some? Why do I need to include them here?
Here is my directory structure.
C:\Alfresco\tomcat\shared\classes\alfresco\extension:
someco-model-context.xml
scWorkflow.properties
C:\Alfresco\tomcat\shared\classes\alfresco\extension\model
scWorkflowModel.xml
C:\Alfresco\tomcat\shared\classes\alfresco\extension\workflow\PublishDocument
processdefinition.xml
In terms of what API I Use to compile the class, I do not understand. do you mean what version of the JDK am I using? If so, I am using JDK 1.6 to compile my class files.
Thank you for your persistence in trying to solve this issue.
Brenda
mcook
Im sorry, I should have been less ambiguous.  I was asking what alfresco api version you were compiling against.  I haven't had a chance yet to fully look over your last post, but I will get back with you.
