Problem with JAAS configuration not working
stk137
How is JAAS supposed to be configured for a plain old JAAS login module (not Kerberos)?
I can't get it to work with my JAAS login module.  For simplicity's sake, I am also trying to get it working with the Sample login module from Sun's, but also with no success.  These modules are installed and configured in my JRE and I have successfully tested them with a simple console app.
I am starting with the sample jaas-authentication-context.xml
I edit the first bean to use my config name.
    <bean id="authenticationComponentImpl"            class="org.alfresco.repo.security.authentication.jaas.JAASAuthenticationComponent">
        <property name="realm">
            <value>DEFAULT.REALM</value>
        </property>
        <property name="jaasConfigEntryName">
            <value>Sample</value>
        </property>
    </bean>‍‍‍‍‍‍‍‍
If I don't comment out the second bean I get an error, but I am guessing from seeing "ntlm" in the class name that I shouldn't use that second bean.
With both the Sample login module and my login module, Alfresco just says "Unable to login - unknown username/password."  Before I tried the Sample login module, I thought it was swallowing errors (and stdout), as nothing is logged, and the error message aren't mine.  Now I am not even sure if it's trying JAAS at all.
So how do you get Alfresco to use a JAAS login module?
9 REPLIES 9
stk137
just to add some info
if I do use the second bean in the sample I get
org.springframework.beans.factory.BeanIsNotAFactoryException: Bean named 'authenticationDao' must be of type [org.springframework.beans.factory.FactoryBean], but was actually of type [org.alfresco.repo.security.authentication.RepositoryAuthenticationDao]
Is the any example for settting up JAAS that works?
andy
Hi
Which repo version are you using?
For 2.0 and after the bean to override is authenticationComponent and not authenticationComponentImpl.
Make sure your app server is picking up the security configuration via the java command line or the java installation and that it is using the jre you expect.
If you take the standard install you can get at all the JRE info to check it from the admin console.
You should only have one authenticationComponent bean.
Hope this helps
Andy
peltuinum
did you solve your problem?
I'm getting the same error:
2007-07-02 11:12:37,430 ERROR [org.springframework.web.context.ContextLoader] Context initialization failed
I installed v. 2.0 under JBoss, and  this is my  jaas-authentication-context.xml :
<beans>
    <!– The authentication component.                                      –>
    <!– Jass authentication - most of the config goes somewhere else       –>
    <bean id="authenticationComponent"
            <value>INSIEL.IT</value>
        </property>
            <value>Alfresco</value>
        </property>
    </bean>
                <bean id="alfDaoImpl" class="org.springframework.transaction.interceptor.TransactionProxyFactoryBean">
                        <property name="proxyInterfaces">
                                        <value>
                                                org.alfresco.repo.security.authentication.MutableAuthenticationDao
                                        </value>
                        </property>
                        <property name="transactionManager">
                                        <ref bean="transactionManager" />
                        </property>
                        <property name="target">
                                        <bean class="org.alfresco.repo.security.authentication.ntlm.NullMutableAuthenticationDao" />
                        </property>
                        <property name="transactionAttributes">
                                <props>
                                        <prop key="*">${server.transaction.mode.default}</prop>
                                </props>
                        </property>
                </bean>
</beans>
stk137
Hi
Andy
This error was with 2.0.
I got it working with a 2.1 nightly.  Now that I see your reply, I can try 2.0 again.  The sample that comes with 2.0 has the wrong bean.
thanks
Steve
stk137
<beans>
        </property>
        </property>
    </bean>
                                        <value>
                                        </value>
                        </property>
                        </property>
                        </property>
                                <props>
                                </props>
                        </property>
                </bean>
</beans>
I got it working with a 2.1 nightly build starting with the sample that comes with it.
I haven't gone back and tried 2.0 again, but now that I see you are using authenticationComponent and not authenticationComponentImpl and still getting an error, I may not bother.
andy
Hi
The config example is wrong.
See http://issues.alfresco.com/browse/AR-1564
<bean name="authenticationDao" class="org.alfresco.repo.security.authentication.DefaultMutableAuthenticationDao" >
        <property name="allowDeleteUser">
            <value>true</value>
        </property>
    </bean>
Should sort this out.
Andy
peltuinum
I installed 2.1 Community Ed. and the error disappeared.
Many thanks
coffman
Hello
Hi
            <value>true</value>
        </property>
    </bean>
Andy
I have the same error, i am using the community 2.0, but i have a question:
What must we do with this code to fix on version 2.0 ??
I try to add the code to jaas-authentication-context.xml without success.
If i comment out the lines with alfDaoImpl, the error dissapear, but when i try to acces alfresco from CIFS or web I can display this one:
15:00:11,732 ERROR [alfresco.smb.protocol] Closing session due to exception
org.alfresco.error.AlfrescoRuntimeException: Not implemented
        at org.alfresco.repo.security.authentication.DefaultMutableAuthenticationDao.getMD4HashedPassword(DefaultMutableAuthenticationDao.java:394)
        at org.alfresco.repo.security.authentication.AuthenticationComponentImpl.getMD4HashedPassword(AuthenticationComponentImpl.java:107)
        at org.alfresco.filesys.server.auth.EnterpriseCifsAuthenticator.doNTLMv1Logon(EnterpriseCifsAuthenticator.java:1267)
        at org.alfresco.filesys.server.auth.EnterpriseCifsAuthenticator.doNtlmsspSessionSetup(EnterpriseCifsAuthenticator.java:942)
        at org.alfresco.filesys.server.auth.EnterpriseCifsAuthenticator.processSessionSetup(EnterpriseCifsAuthenticator.java:637)
        at org.alfresco.filesys.smb.server.NTProtocolHandler.procSessionSetup(NTProtocolHandler.java:407)
        at org.alfresco.filesys.smb.server.NTProtocolHandler.runProtocol(NTProtocolHandler.java:221)
        at org.alfresco.filesys.smb.server.SMBSrvSession.runHandler(SMBSrvSession.java:1450)
        at org.alfresco.filesys.smb.server.SMBSrvSession.run(SMBSrvSession.java:1351)
andy
Hi
You need to configure CIFS to use Kerberos or passthrough authentication. See the wiki.
Andy
