problem with installation: Bootstrap failed
mbayerl
Hi!
I am trying to install the trial version on my pc but it doesn't work.
I've got:
Windows XP Pro SP2
mySQL 5.0.22
I downloaded "alfresco-enterprise-tomcat-1.3.0.zip"
db_setup.bat works fine and creates the 'Alfreso' account.
When I try 'alf_start.bat' I get the following message:
15:20:20,767 ERROR [org.apache.catalina.core.ContainerBase.[Catalina].[localhost].[/alfresco]] Exception sending context initialized event to listener instance of class org.alfresco.web.app.ContextListener
org.alfresco.error.AlfrescoRuntimeException: Bootstrap failed
   at org.alfresco.repo.importer.ImporterBootstrap.bootstrap(ImporterBootstrap.java:427)
Any help will be appreciated.
Michael
14 REPLIES 14
kevinr
Can you post the full exception message?
Kevin
mbayerl
Sorry, here is the full trace:
15:20:20,707 ERROR [org.springframework.web.context.ContextLoader] Context initialization failed
   at org.alfresco.repo.importer.ImporterBootstrap.onApplicationEvent(ImporterBootstrap.java:654)
   at org.springframework.context.event.SimpleApplicationEventMulticaster.multicastEvent(SimpleApplicationEventMulticaster.java:45)
   at org.springframework.context.support.AbstractApplicationContext.publishEvent(AbstractApplicationContext.java:225)
   at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:323)
   at org.springframework.web.context.support.AbstractRefreshableWebApplicationContext.refresh(AbstractRefreshableWebApplicationContext.java:134)
   at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:3692)
   at org.apache.catalina.core.StandardContext.start(StandardContext.java:4127)
   at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:804)
   at org.apache.catalina.startup.HostConfig.deployWARs(HostConfig.java:693)
   at org.apache.catalina.startup.HostConfig.start(HostConfig.java:1118)
   at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1020)
   at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1012)
   at org.apache.catalina.core.StandardServer.start(StandardServer.java:680)
   at org.apache.catalina.startup.Catalina.start(Catalina.java:536)
   at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:275)
Caused by: org.alfresco.service.cmr.view.ImporterException: Failed to import package at line 19; column 17 due to error: Content URL classpath:alfresco/bootstrap/Alfresco Tutorial does not exist.
   at org.alfresco.repo.importer.view.ViewParser.parse(ViewParser.java:171)
   at org.alfresco.repo.importer.ImporterComponent.parserImport(ImporterComponent.java:344)
   at org.alfresco.repo.importer.ImporterComponent.importView(ImporterComponent.java:211)
   at org.alfresco.repo.importer.ImporterBootstrap.bootstrap(ImporterBootstrap.java:408)
   … 32 more
Caused by: org.alfresco.service.cmr.view.ImporterException: Content URL classpath:alfresco/bootstrap/Alfresco Tutorial does not exist.
   at org.alfresco.repo.importer.ImporterComponent$DefaultStreamHandler.importStream(ImporterComponent.java:1507)
   at org.alfresco.repo.importer.ImporterComponent$NodeImporter.importContent(ImporterComponent.java:651)
   at org.alfresco.repo.importer.ImporterComponent$NodeImporter.importNode(ImporterComponent.java:558)
   at org.alfresco.repo.importer.view.ViewParser.importNode(ViewParser.java:820)
   at org.alfresco.repo.importer.view.ViewParser.processEndType(ViewParser.java:784)
   at org.alfresco.repo.importer.view.ViewParser.processEndElement(ViewParser.java:764)
   at org.alfresco.repo.importer.view.ViewParser.parse(ViewParser.java:163)
   … 35 more
15:20:20,767 ERROR [org.apache.catalina.core.ContainerBase.[Catalina].[localhost].[/alfresco]] Exception sending context initialized event to listener instance of class org.springframework.web.context.ContextLoaderListener
   … 32 more
   … 35 more
   … 32 more
   … 35 more
davidc
This issue may be due to using a localised version of Alfresco as reported here http://www.alfresco.org/jira/browse/AR-577.
The work-around is to modify /alfresco/bootstrap/tutorial.xml by replacing
/${tutorial.document.name}
with
Alfresco-Tutorial.pdf
mbayerl
I changed this and now I get the following error:
btw: mySQL is running. Do I have to modify my mySQL database?
11:19:55,432 ERROR [org.hibernate.util.JDBCExceptionReporter] Connections could not be acquired from the underlying database!
11:20:14,729 ERROR [org.hibernate.util.JDBCExceptionReporter] Connections could not be acquired from the underlying database!
11:20:14,729 ERROR [org.hibernate.tool.hbm2ddl.SchemaUpdate] could not get database metadata
java.sql.SQLException: Connections could not be acquired from the underlying database!
   at com.mchange.v2.sql.SqlUtils.toSQLException(SqlUtils.java:106)
   at com.mchange.v2.c3p0.impl.C3P0PooledConnectionPool.checkoutPooledConnection(C3P0PooledConnectionPool.java:352)
   at com.mchange.v2.c3p0.PoolBackedDataSource.getConnection(PoolBackedDataSource.java:120)
   at com.mchange.v2.c3p0.ComboPooledDataSource.getConnection(ComboPooledDataSource.java:601)
   at org.springframework.orm.hibernate3.LocalDataSourceConnectionProvider.getConnection(LocalDataSourceConnectionProvider.java:80)
   at org.hibernate.tool.hbm2ddl.SuppliedConnectionProviderConnectionHelper.prepare(SuppliedConnectionProviderConnectionHelper.java:27)
   at org.hibernate.tool.hbm2ddl.SchemaUpdate.execute(SchemaUpdate.java:127)
   at org.hibernate.impl.SessionFactoryImpl.<init>(SessionFactoryImpl.java:296)
   at org.hibernate.cfg.Configuration.buildSessionFactory(Configuration.java:1176)
   at org.springframework.orm.hibernate3.LocalSessionFactoryBean.newSessionFactory(LocalSessionFactoryBean.java:800)
   at org.springframework.orm.hibernate3.LocalSessionFactoryBean.afterPropertiesSet(LocalSessionFactoryBean.java:726)
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1059)
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:363)
   at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:226)
   at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:147)
   at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:176)
   at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:105)
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1013)
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:824)
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:345)
   at org.springframework.beans.factory.support.DefaultListableBeanFactory.getBeansOfType(DefaultListableBeanFactory.java:203)
   at org.springframework.context.support.AbstractApplicationContext.getBeansOfType(AbstractApplicationContext.java:614)
   at org.springframework.context.support.AbstractApplicationContext.registerListeners(AbstractApplicationContext.java:496)
   at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:317)
Caused by: com.mchange.v2.resourcepool.CannotAcquireResourceException: A ResourcePool could not acquire a resource from its primary factory or source.
   at com.mchange.v2.resourcepool.BasicResourcePool.awaitAvailable(BasicResourcePool.java:1002)
   at com.mchange.v2.resourcepool.BasicResourcePool.checkoutResource(BasicResourcePool.java:293)
   at com.mchange.v2.c3p0.impl.C3P0PooledConnectionPool.checkoutPooledConnection(C3P0PooledConnectionPool.java:348)
   … 66 more
11:20:14,749 ERROR [org.hibernate.tool.hbm2ddl.SchemaUpdate] could not complete schema update
   … 66 more
11:21:23,929 ERROR [org.hibernate.util.JDBCExceptionReporter] Connections could not be acquired from the underlying database!
11:21:23,929 ERROR [org.alfresco.repo.transaction.TransactionUtil] Error rolling back transaction
java.lang.IllegalStateException: No user transaction is active
   at org.alfresco.util.transaction.SpringAwareUserTransaction.rollback(SpringAwareUserTransaction.java:450)
   at org.alfresco.repo.transaction.TransactionUtil.executeInTransaction(TransactionUtil.java:193)
   at org.alfresco.repo.transaction.TransactionUtil.executeInUserTransaction(TransactionUtil.java:74)
   at org.alfresco.repo.dictionary.DictionaryRepositoryBootstrap.bootstrap(DictionaryRepositoryBootstrap.java:126)
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeCustomInitMethod(AbstractAutowireCapableBeanFactory.java:1093)
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1063)
   at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:275)
   at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:320)
11:21:23,929 ERROR [org.springframework.web.context.ContextLoader] Context initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'dictionaryRepositoryBootstrap' defined in class path resource [alfresco/core-services-context.xml]: Initialization of bean failed; nested exception is org.springframework.transaction.CannotCreateTransactionException: Could not open Hibernate Session for transaction; nested exception is org.hibernate.exception.GenericJDBCException: Cannot open connection
   at org.hibernate.exception.SQLStateConverter.handledNonSpecificException(SQLStateConverter.java:103)
   at org.hibernate.exception.SQLStateConverter.convert(SQLStateConverter.java:91)
   at org.hibernate.exception.JDBCExceptionHelper.convert(JDBCExceptionHelper.java:43)
   at org.hibernate.exception.JDBCExceptionHelper.convert(JDBCExceptionHelper.java:29)
   at org.hibernate.jdbc.ConnectionManager.openConnection(ConnectionManager.java:420)
   at org.hibernate.jdbc.ConnectionManager.getConnection(ConnectionManager.java:144)
   at org.hibernate.jdbc.JDBCContext.connection(JDBCContext.java:129)
   at org.hibernate.transaction.JDBCTransaction.begin(JDBCTransaction.java:57)
   at org.hibernate.impl.SessionImpl.beginTransaction(SessionImpl.java:1290)
   at org.springframework.orm.hibernate3.HibernateTransactionManager.doBegin(HibernateTransactionManager.java:520)
   at org.springframework.transaction.support.AbstractPlatformTransactionManager.getTransaction(AbstractPlatformTransactionManager.java:282)
   at org.springframework.transaction.interceptor.TransactionAspectSupport.createTransactionIfNecessary(TransactionAspectSupport.java:225)
   at org.alfresco.util.transaction.SpringAwareUserTransaction.begin(SpringAwareUserTransaction.java:348)
   at org.alfresco.repo.transaction.TransactionUtil.executeInTransaction(TransactionUtil.java:167)
Caused by: java.sql.SQLException: Connections could not be acquired from the underlying database!
   at org.hibernate.jdbc.ConnectionManager.openConnection(ConnectionManager.java:417)
   … 50 more
   … 54 more
11:21:23,989 ERROR [org.apache.catalina.core.ContainerBase.[Catalina].[localhost].[/alfresco]] Exception sending context initialized event to listener instance of class org.springframework.web.context.ContextLoaderListener
   … 50 more
   … 54 more
11:21:24,009 ERROR [org.apache.catalina.core.ContainerBase.[Catalina].[localhost].[/alfresco]] Exception sending context initialized event to listener instance of class org.alfresco.web.app.ContextListener
   … 50 more
   … 54 more
davidc
Please ensure you have setup the mysql database as per the instructions in the readme.txt.
mbayerl
MySQL is running:
c:\>mysqladmin version
mysqladmin  Ver 8.41 Distrib 5.0.22, for Win32 on ia32
Copyright (C) 2000 MySQL AB & MySQL Finland AB & TCX DataKonsult AB
This software comes with ABSOLUTELY NO WARRANTY. This is free software,
and you are welcome to modify and redistribute it under the GPL license
Server version          5.0.22-community-nt
Protocol version        10
Connection              localhost via TCP/IP
TCP port                3306
Uptime:                 1 min 23 sec
Threads: 19  Questions: 6609  Slow queries: 0  Opens: 0  Flush tables: 1  Open t
ables: 20  Queries per second avg: 79.627
I get the error:
13:33:32,980 ERROR [org.apache.catalina.core.ContainerBase.[Catalina].[localhost].[/alfresco]] Exception sending context initialized event to listener instance of class org.springframework.web.context.ContextLoaderListener
   … 32 more
   … 35 more
13:33:32,980 ERROR [org.apache.catalina.core.ContainerBase.[Catalina].[localhost].[/alfresco]] Exception sending context initialized event to listener instance of class org.alfresco.web.app.ContextListener
   … 32 more
   … 35 more
davidc
Please ensure the appropriate mysql database user is created as per the instructions in the readme.txt.
It looks like you have the original stack trace again i.e. the bootstrap failed.
mbayerl
I am sorry, but I set up mysql as noted in readme.txt and I still get the following message:
14:42:31,231 ERROR [org.apache.catalina.core.ContainerBase.[Catalina].[localhost].[/alfresco]] Exception sending context initialized event to listener instance of class org.alfresco.web.app.ContextListener
   … 32 more
   … 35 more
kevinr
with
Have you made this change as David suggests?
Kevin
