Problem with initial startup
Options
03-27-2010 11:15 AM
before i raise a Jira Bug, i'd like to proof that i did no errors.
I'am looking for a Document Management System for my private use at home, so i step over Alfresco and it sounds promising.
Now to my problem. I downloaded the actual Tomcat Package 3.2r. I use a x86 Ubuntu 8.04 System. I want to use my existing PostgreSQL DB (8.3.9).
I walked through the steps in the installation manual. First i ran in the problem that Alfresco did't run with the OpenJDK, i changed the JAVA_HOME to the existing
SUN JRE. Now it seems that i am a litte further, but…
The catalina.out of the Tomcat lists the following Exception and the application did't start:
15:49:20,007 ERROR [web.context.ContextLoader] Context initialization failed
org.alfresco.error.AlfrescoRuntimeException: 02270001 Bootstrap failed
at org.alfresco.repo.importer.ImporterBootstrap.bootstrap(ImporterBootstrap.java:367)
at org.alfresco.repo.importer.ImporterBootstrap.onBootstrap(ImporterBootstrap.java:724)
at org.springframework.context.support.AbstractApplicationContext.finishRefresh(AbstractApplicationContext.java:617)
Caused by: org.alfresco.service.cmr.view.ImporterException: Failed to import package at line 24; column 19 due to error: 02270000 Failed to set content property on stream closure:
node: system://system/298d98fa-c285-48a9-b6a8-97376a9d8dc5
property: {http://www.alfresco.org/model/system/1.0}versionProperties
writer: ContentAccessor[ contentUrl=store://2010/3/27/15/49/3bf80dc5-1e17-4137-9664-b85a5d59c6c8.bin, mimetype=text/plain, size=261, encoding=UTF8, locale=de_DE]
com.ibatis.sqlmap.client.SqlMapException: There is no statement named alfresco.content.insert_ContentUrl in this SqlMap.
at org.alfresco.repo.importer.view.ViewParser.parse(ViewParser.java:196)
at org.alfresco.repo.importer.ImporterComponent.parserImport(ImporterComponent.java:359)
at org.alfresco.repo.importer.ImporterComponent.importView(ImporterComponent.java:223)
at org.alfresco.repo.importer.ImporterBootstrap.doImport(ImporterBootstrap.java:481)
at org.alfresco.repo.importer.ImporterBootstrap.access$000(ImporterBootstrap.java:76)
at org.alfresco.repo.importer.ImporterBootstrap$1$1.execute(ImporterBootstrap.java:356)
at org.alfresco.repo.transaction.RetryingTransactionHelper.doInTransaction(RetryingTransactionHelper.java:327)
at org.alfresco.repo.importer.ImporterBootstrap$1.doWork(ImporterBootstrap.java:360)
at org.alfresco.repo.security.authentication.AuthenticationUtil.runAs(AuthenticationUtil.java:514)
at org.alfresco.repo.importer.ImporterBootstrap.bootstrap(ImporterBootstrap.java:363)
… 36 more
Caused by: org.alfresco.service.cmr.repository.ContentIOException: 02270000 Failed to set content property on stream closure:
at org.alfresco.repo.content.ContentServiceImpl$WriteStreamListener.contentStreamClosed(ContentServiceImpl.java:656)
at org.alfresco.repo.content.AbstractContentAccessor$CallbackFileChannel$1.execute(AbstractContentAccessor.java:359)
at org.alfresco.repo.transaction.RetryingTransactionHelper.doInTransaction(RetryingTransactionHelper.java:253)
at org.alfresco.repo.content.AbstractContentAccessor$CallbackFileChannel.fireChannelClosed(AbstractContentAccessor.java:369)
at org.alfresco.repo.content.AbstractContentAccessor$CallbackFileChannel.implCloseChannel(AbstractContentAccessor.java:338)
at java.nio.channels.spi.AbstractInterruptibleChannel.close(AbstractInterruptibleChannel.java:97)
at java.nio.channels.Channels$1.close(Channels.java:138)
at java.io.FilterOutputStream.close(FilterOutputStream.java:143)
at org.springframework.util.FileCopyUtils.copy(FileCopyUtils.java:132)
at org.alfresco.repo.content.AbstractContentWriter.putContent(AbstractContentWriter.java:423)
at org.alfresco.repo.importer.ImporterComponent$NodeImporter.importContent(ImporterComponent.java:674)
at org.alfresco.repo.importer.ImporterComponent$NodeImporter.importNode(ImporterComponent.java:577)
at org.alfresco.repo.importer.view.ViewParser.importNode(ViewParser.java:914)
at org.alfresco.repo.importer.view.ViewParser.processEndType(ViewParser.java:878)
at org.alfresco.repo.importer.view.ViewParser.processEndElement(ViewParser.java:858)
at org.alfresco.repo.importer.view.ViewParser.parse(ViewParser.java:188)
… 45 more
Caused by: com.ibatis.sqlmap.client.SqlMapException: There is no statement named alfresco.content.insert_ContentUrl in this SqlMap.
at com.ibatis.sqlmap.engine.impl.SqlMapExecutorDelegate.getMappedStatement(SqlMapExecutorDelegate.java:231)
at com.ibatis.sqlmap.engine.impl.SqlMapExecutorDelegate.insert(SqlMapExecutorDelegate.java:367)
at com.ibatis.sqlmap.engine.impl.SqlMapSessionImpl.insert(SqlMapSessionImpl.java:82)
at org.springframework.orm.ibatis.SqlMapClientTemplate$9.doInSqlMapClient(SqlMapClientTemplate.java:370)
at org.springframework.orm.ibatis.SqlMapClientTemplate.execute(SqlMapClientTemplate.java:194)
at org.springframework.orm.ibatis.SqlMapClientTemplate.insert(SqlMapClientTemplate.java:368)
at org.alfresco.repo.domain.contentdata.ibatis.ContentDataDAOImpl.createContentUrlEntity(ContentDataDAOImpl.java:72)
at org.alfresco.repo.domain.contentdata.AbstractContentDataDAOImpl.getOrCreateContentUrlEntity(AbstractContentDataDAOImpl.java:276)
at org.alfresco.repo.domain.contentdata.AbstractContentDataDAOImpl.createContentDataEntity(AbstractContentDataDAOImpl.java:220)
at org.alfresco.repo.domain.contentdata.AbstractContentDataDAOImpl.createContentData(AbstractContentDataDAOImpl.java:136)
at org.alfresco.repo.node.db.hibernate.HibernateNodeDaoServiceImpl.addValueToPersistedProperties(HibernateNodeDaoServiceImpl.java:4955)
at org.alfresco.repo.node.db.hibernate.HibernateNodeDaoServiceImpl.addNodePropertyImpl(HibernateNodeDaoServiceImpl.java:1472)
at org.alfresco.repo.node.db.hibernate.HibernateNodeDaoServiceImpl.addNodeProperty(HibernateNodeDaoServiceImpl.java:1511)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:304)
at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:182)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:149)
at org.alfresco.repo.transaction.TransactionalDaoInterceptor.invoke(TransactionalDaoInterceptor.java:68)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171)
at org.alfresco.repo.domain.hibernate.DirtySessionMethodInterceptor.invoke(DirtySessionMethodInterceptor.java:419)
at org.alfresco.repo.transaction.SingleEntryTransactionResourceInterceptor.invokeInternal(SingleEntryTransactionResourceInterceptor.java:163)
at org.alfresco.repo.transaction.SingleEntryTransactionResourceInterceptor.invoke(SingleEntryTransactionResourceInterceptor.java:138)
at $Proxy9.addNodeProperty(Unknown Source)
at org.alfresco.repo.node.db.DbNodeServiceImpl.setPropertyImpl(DbNodeServiceImpl.java:1307)
at org.alfresco.repo.node.db.DbNodeServiceImpl.setProperty(DbNodeServiceImpl.java:1271)
at org.alfresco.repo.tenant.MultiTNodeServiceInterceptor.invoke(MultiTNodeServiceInterceptor.java:110)
at $Proxy11.setProperty(Unknown Source)
at org.alfresco.repo.service.StoreRedirectorProxyFactory$RedirectorInvocationHandler.invoke(StoreRedirectorProxyFactory.java:221)
at $Proxy12.setProperty(Unknown Source)
at org.alfresco.repo.node.MLPropertyInterceptor.invoke(MLPropertyInterceptor.java:252)
at org.alfresco.repo.node.NodeRefPropertyMethodInterceptor.invoke(NodeRefPropertyMethodInterceptor.java:265)
at org.alfresco.repo.content.ContentServiceImpl$WriteStreamListener.contentStreamClosed(ContentServiceImpl.java:636)
… 61 more
Now, the question is it a bug, or did i configure something wrong? As i said i followed the PostgreSQL Section in the installation manual.
A quick search in the Forum and Google brings nothing up from value?!
Thx in advance,
Daniel
… 36 more
… 45 more
… 61 more
Thx in advance,
Daniel
Labels:
Archive
Options
03-29-2010 07:08 AM
At least i found a Jira Bug where i think it is releated to my Problem:
ALF-1489
Now i have to wait for the next release or think about MySQL…
Daniel
ALF-1489
Daniel
