Problem with events
swsw1
I have got a Vaadin application with a Button which throws events of type ClickEvent. Although I imported all activity-jars, there is always a NullPointerException - I cannot create the ProcessEngine.
The exception reads as follows:
Servlet.service() for servlet [Vaadin Application] in context with path [/Vaadin] threw exception [java.lang.NullPointerException] with root cause
   at com.example.vaadin.VaadinApplication.init(VaadinApplication.java:42)
   at com.vaadin.Application.start(Application.java:551)
   at com.vaadin.terminal.gwt.server.AbstractApplicationServlet.startApplication(AbstractApplicationServlet.java:1219)
   at com.vaadin.terminal.gwt.server.AbstractApplicationServlet.service(AbstractApplicationServlet.java:484)
   at javax.servlet.http.HttpServlet.service(HttpServlet.java:728)
   at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:51)
   at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:502)
   at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:171)
   at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:100)
   at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:953)
   at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1041)
   at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:603)
   at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:310)
Moreover, my original plan has been to controll trigger the process by the ClickEvents thrown by my button. I defined an intermediate catch event in my bpmn.xml, I added an event listener to my runtimeService-object, my idea was to give the signal event as id the String "ClickEvent", because the event thrown by my button is of type ClickEvent, and the method buttonClick ought to be responsible of throwing the intermediateCatchEvent, which is also there in the .xml-file, but I do not know how tho achieve this.
Here is my xml-file:
<?xml version="1.0" encoding="UTF-8" ?>
<definitions id="definitions"
  targetNamespace="http://activiti.org/bpmn20"
  xmlns:activiti="http://activiti.org/bpmn"
  xmlns="http://www.omg.org/spec/BPMN/20100524/MODEL">
<process id="catchSignal">
<signal id="ClickEvent" name="event" />
         <intermediateCatchEvent id="catchSignalEvent" name="OnAlert">
                      <!– signal event definition –>
                        <signalEventDefinition signalRef="alertSignal" />
         </intermediateCatchEvent>
        </process>
</definitions>
…and this is my Vaadin code:
package com.example.vaadin;
import java.util.HashMap;
import java.util.List;
import java.util.Map;
import org.activiti.engine.task.Task;
import org.activiti.engine.HistoryService;
import org.activiti.engine.ProcessEngine;
import org.activiti.engine.ProcessEngines;
import org.activiti.engine.RepositoryService;
import org.activiti.engine.TaskService;
import org.activiti.engine.delegate.event.ActivitiEvent;
import org.activiti.engine.delegate.event.ActivitiEventListener;
import org.activiti.engine.history.HistoricProcessInstance;
import org.activiti.engine.repository.Deployment;
import org.activiti.engine.runtime.Execution;
import org.activiti.engine.runtime.ProcessInstance;
import org.apache.commons.logging.Log;
import com.vaadin.Application;
import com.vaadin.ui.*;
import com.vaadin.ui.Button.ClickEvent;
import com.vaadin.ui.Button.ClickListener;
* Main application class.
public class VaadinApplication extends Application implements ActivitiEventListener{
   RuntimeService runtimeService = null;
   @Override
   public void init(){
      //Meine ProcessEngine.
      ProcessEngine processEngine = ProcessEngines.getDefaultProcessEngine();
      //The workflow will have to be concretised in the *.bpmn20.xml - file.
      RepositoryService repositoryService = processEngine.getRepositoryService();
      RuntimeService runtimeService = processEngine.getRuntimeService();
          runtimeService.addEventListener(this);
      repositoryService.createDeployment()
        .addClasspathResource("bpmn/EventTest.bpmn20.xml")
        .deploy();
      Window mainWindow = new Window("Vaadin Application");
      Button but = new Button("Event");
      but.addListener(new ClickListener(){
         @Override
         public void buttonClick(ClickEvent event) {
      mainWindow.addComponent(but);
      setMainWindow(mainWindow);
   @Override
   public boolean isFailOnException() {
      return false;
   @Override
   public void onEvent(ActivitiEvent ae) {
5 REPLIES 5
jbarrez
So you mean that ProcessEngine processEngine = ProcessEngines.getDefaultProcessEngine(); gives a NPE?
By default, Activiti will look for an activiti.cfg.xml file on the classpath. Do you have that?
swsw1
Thank You! Being a noob, I forgot adding the cfg.xml to the classpath. Now, there is still a classloader problem, but the creation of the engine is working now.
swsw1
http://forums.activiti.org/
swsw 666sdf76
I have started programming a new application where I also want to create my process engine based on a activiti.cfg.xml-file (and once again I take the one that is there in the documentation), and again, I am running into a nullpointer exception, and everything I tried in order to add the cfg.xml-file to the classpath did not succeed.
On running my code on Tomcat, I have a NullPointerException for my "processEngine" remains null.
<code>ProcessEngine processEngine = ProcessEngines.getDefaultProcessEngine();
  RuntimeService runtimeService = processEngine.getRuntimeService();</code>
So what do I have to do to add the activiti.cfg.xml to my classpath?
Here is my activiti.cfg.xml:
<code>
       xsi:schemaLocation="http://www.springframework.org/schema/beans   http://www.springframework.org/schema/beans/spring-beans.xsd">
  <bean id="processEngineConfiguration" class="org.activiti.engine.impl.cfg.StandaloneProcessEngineConfiguration">
    <property name="jdbcUrl" value="jdbc:h2:mem:activiti;DB_CLOSE_DELAY=1000" />
    <property name="jdbcDriver" value="org.h2.Driver" />
    <property name="jdbcUsername" value="sa" />
    <property name="jdbcPassword" value="" />
    <property name="mailServerHost" value="mail.my-corp.com" />
    <property name="mailServerPort" value="5025" />
  </bean>
</beans>
</code>
jbarrez
Just put it on the tomcat classpath: /lib or (better) WEB-INF/lib of the war
swsw1
Thank You, now it is working, after all 🙂
