Hi, I recently noticed that I have a problem with searching for special characters. The problem occurs only in Share, in Alfresco explorer everything is fine. Thanks to some guidance from Loftux on IRC, I enabled tomcat6 access log and found out that the initial passing of the search query is correct, but then some redirection takes place and the query gets messed up. This can be observed in the log file: http://pastebin.com/sMebqRqa - in the first line "ś" is correctly converted to C5 but then, in line, 18 it's changed to something else. I also setup similar alfresco instance on my laptop to test it, but everything was correct then.
Hi Andy, yes, I have this setup. It is the default config and I haven't change it. Also, I was thinking that maybe I messed some files in webapps/share or alfresco, so I deleted both directories and redeployed. The problem still exists
Hi Andy, so the thing is… I wanted to test it now and… it works correctly now. Don't know why and since when. I had no more ideas how to fix it myself so I ignored it for now and it started to work. The only thing I did, as far as I can tell, was to install JavaScript admin console from Share-extras package. And regarding your question, I simply tried to search for "ś" or any other polish character. The problem occured every time. I would still like to know the cause for this, even if now it works. I don't want it to come back unexpected
