‎12-25-2016 06:34 PM
Im totaly noob in this. I try first with alfresco 4.0d, then i try with alfresco 5.2, latest.
I whant install custom datalist in alfresco but somewhere I mistake. I create custom model, model-context, change share-config-custom and I try everything, but I cant find step by step configuration for datalist. Every time I have error, that I can autorized on site and other errors. When i revert back to orginal configuration all work great.
I need some colums like this:
ID, Customer, Public IP, router IP, antenna IP, vlan, network, bandwith, pop, contact, comment
Any help please.
Bg,
Tomo
Archive
‎12-26-2016 06:30 AM
You are getting errors because you have missed </type> and </types> closing tags before </model> tag in IPDataListModel.xml file and
you have given the wrong path of IPDataListModel.properties file in your IPDataListModel-context.xml file
the path for your property file will be:<value>alfresco/messages/IPDataListModel</value>
It works fine with these changes.
Let me know if you have any further query.
Kalpesh
‎12-25-2016 11:24 PM
Hi !
To help you out, I need to know about exact error that you are facing while creating a datalist. If you can show the stack-trace from console, so that I can figure out the problem.
Or, you can refer this link Data Lists | Alfresco Documentation
Thank You,
Kalpesh
‎12-26-2016 04:17 AM
In att is files what I create. But I dont know what I need more?
Thx
Kalpesh
‎12-26-2016 10:36 AM
I change, how you tell me. But I have same problem.
When I remote two xml file from extensions and revert to orginal share-config-custom.xml, all work ok.
‎12-29-2016 06:20 AM
can you contact me throug the skype or email, and can I give you access to my server, that you try start alfresco services with my xmls.
Thx
Tomislav
‎12-29-2016 06:46 AM
Hi, Tomislav
Can you please share your skype Id on kalpesh@contcentric.com and rahul@contcentric.com. We will connect immediately.
Kalpesh
‎12-29-2016 03:43 PM
Thank you guys. All work perfect, I dont belive that you resolve me nightmare. Thank a lot. Now I create one more datalist, and work excellent. I dont know how I tell you how much im grateful!
Tomislav
‎09-20-2017 12:58 AM
How did you error was solved ?
i face the same issue?
‎09-20-2017 10:06 AM
we are using alfresco community 5.2 .
What ever the folder location you point it doesn't work with it or the folder path does't exists.
