Problem with Database Management on Oracle
junidb
When deploying on Oracle, the new Explorer throws this message when going to the Database tab of Management.
### Error querying database. Cause: java.sql.SQLException: ORA-00942: table or view does not exist
### The error may involve org.activiti.engine.impl.TablePageMap.selectTableCount-Inline
### Cause: java.sql.SQLException: ORA-00942: table or view does not exist
I tried debugging using the source code. When you try to search for tables which starts with ACT, the result is also giving back ACTION_TABLE, which is not a standard table. The oracle version I'm using is 11gR2.
Junid
10 REPLIES 10
marcthomas2012
Thank you for confirming.
Marc
