06-29-2010 11:51 AM
audit.enabled=false
audit.useNewConfig=false
29 juin 2010 16:45:00 org.apache.coyote.http11.Http11Protocol init
INFO: Initialisation de Coyote HTTP/1.1 sur http-8080
29 juin 2010 16:45:00 org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 423 ms
29 juin 2010 16:45:00 org.apache.catalina.core.StandardService start
INFO: D�marrage du service Catalina
29 juin 2010 16:45:00 org.apache.catalina.core.StandardEngine start
29 juin 2010 16:45:03 org.apache.catalina.core.StandardContext addApplicationListener
16:45:08,300 INFO [alfresco.config.JndiPropertiesFactoryBean] Loading properties file from class path resource [alfresco/repository.properties]
16:45:08,302 INFO [alfresco.config.JndiPropertiesFactoryBean] Loading properties file from class path resource [alfresco/domain/transaction.properties]
16:45:08,302 INFO [alfresco.config.JndiPropertiesFactoryBean] Loading properties file from URL [file:/home/christophe/alfresco32r2/tomcat/shared/classes/alfresco-global.properties]
16:45:08,402 INFO [alfresco.config.JndiPropertyPlaceholderConfigurer] Loading properties file from class path resource [alfresco/alfresco-shared.properties]
16:45:26,591 INFO [domain.schema.SchemaBootstrap] Schema managed by database dialect org.hibernate.dialect.MySQLInnoDBDialect.
16:45:27,255 INFO [domain.schema.SchemaBootstrap] No changes were made to the schema.
16:45:27,553 INFO [management.subsystems.ChildApplicationContextFactory] Starting 'sysAdmin' subsystem, ID: [sysAdmin, default]
16:45:27,563 INFO [alfresco.config.JndiPropertyPlaceholderConfigurer] Loading properties file from class path resource [alfresco/alfresco-shared.properties]
16:45:27,567 INFO [management.subsystems.ChildApplicationContextFactory] Startup of 'sysAdmin' subsystem, ID: [sysAdmin, default] complete
16:45:30,112 User:System INFO [management.subsystems.ChildApplicationContextFactory] Starting 'thirdparty' subsystem, ID: [thirdparty, default]
16:45:30,125 User:System INFO [alfresco.config.JndiPropertyPlaceholderConfigurer] Loading properties file from class path resource [alfresco/alfresco-shared.properties]
16:45:30,203 User:System ERROR [transform.magick.AbstractImageMagickContentTransformerWorker] ImageMagickContentTransformerWorker not available: 05290000 Failed to perform ImageMagick transformation:
Execution result:
os: Linux
command: [./ImageMagick/bin/convert, /home/christophe/alfresco32r2/tomcat/temp/Alfresco/ImageMagickContentTransformerWorker_init_source_2098889747991900200.gif[0], /home/christophe/alfresco32r2/tomcat/temp/Alfresco/ImageMagickContentTransformerWorker_init_target_5286656465253742657.png]
succeeded: false
exit code: 1
out:
err: Cannot run program "./ImageMagick/bin/convert": java.io.IOException: error=2, No such file or directory
16:45:30,254 User:System ERROR [content.transform.RuntimeExecutableContentTransformerWorker] Failed to start a runtime executable content transformer:
Execution result:
os: Linux
command: [./bin/pdf2swf, -V]
succeeded: false
exit code: 1
out:
err: Cannot run program "./bin/pdf2swf": java.io.IOException: error=2, No such file or directory
16:45:30,509 User:System WARN [alfresco.util.OpenOfficeConnectionTester] An initial OpenOffice connection could not be established.
16:45:30,510 User:System INFO [management.subsystems.ChildApplicationContextFactory] Startup of 'thirdparty' subsystem, ID: [thirdparty, default] complete
16:45:31,150 INFO [repo.admin.ConfigurationChecker] The Alfresco root data directory ('dir.root') is: /home/christophe/alfresco32r2/tomcat/alf_data
16:45:31,396 INFO [admin.patch.PatchExecuter] Checking for patches to apply …
16:45:31,690 INFO [admin.patch.PatchExecuter] No patches were required.
16:45:31,698 User:System INFO [repo.module.ModuleServiceImpl] Found 6 module(s).
16:45:31,819 User:System INFO [repo.module.ModuleServiceImpl] Starting module 'SIDE_alfresco_ifremer_imap' version 1.0.0.
16:45:31,878 User:System INFO [repo.module.ModuleServiceImpl] Starting module 'SIDE_WorkflowExtension_IfremerSimple_Process' version 1.0.
16:45:31,925 User:System INFO [repo.module.ModuleServiceImpl] Starting module 'SIDE_alfresco_site_group' version 1.0.0.
16:45:31,974 User:System INFO [repo.module.ModuleServiceImpl] Starting module 'SIDE_xforms' version 1.0.54.
16:45:32,024 User:System INFO [repo.module.ModuleServiceImpl] Starting module 'SIDE_WorkflowExtension_ifremer_Process' version 1.0.
16:45:32,074 User:System INFO [repo.module.ModuleServiceImpl] Starting module 'SIDE_pdfGenerator' version 1.0.32.
16:45:32,559 INFO [management.subsystems.ChildApplicationContextFactory] Starting 'fileServers' subsystem, ID: [fileServers, default]
16:45:32,582 INFO [alfresco.config.JndiPropertyPlaceholderConfigurer] Loading properties file from class path resource [alfresco/alfresco-shared.properties]
16:45:32,802 INFO [management.subsystems.ChildApplicationContextFactory] Starting 'Authentication' subsystem, ID: [Authentication, managed, alfrescoNtlm1]
16:45:32,815 INFO [alfresco.config.JndiPropertyPlaceholderConfigurer] Loading properties file from class path resource [alfresco/alfresco-shared.properties]
16:45:32,897 INFO [management.subsystems.ChildApplicationContextFactory] Startup of 'Authentication' subsystem, ID: [Authentication, managed, alfrescoNtlm1] complete
16:45:37,915 ERROR [org.alfresco.fileserver] Failed to get local domain/workgroup name, using default of WORKGROUP
16:45:37,915 ERROR [org.alfresco.fileserver] (This may be due to firewall settings or incorrect <broadcast> setting)
16:45:37,946 INFO [management.subsystems.ChildApplicationContextFactory] Startup of 'fileServers' subsystem, ID: [fileServers, default] complete
16:45:37,946 INFO [management.subsystems.ChildApplicationContextFactory] Starting 'imap' subsystem, ID: [imap, default]
16:45:37,946 ERROR [org.alfresco.fileserver] [SMB] Server error : org.alfresco.jlan.server.config.InvalidConfigurationException: Error initializing TCP-IP SMB session handler, Permission denied
16:45:37,948 ERROR [org.alfresco.fileserver] org.alfresco.jlan.server.config.InvalidConfigurationException: Error initializing TCP-IP SMB session handler, Permission denied
16:45:37,948 ERROR [org.alfresco.fileserver] at org.alfresco.jlan.smb.server.nio.NIOCifsConnectionsHandler.initializeHandler(NIOCifsConnectionsHandler.java:265)
16:45:37,948 ERROR [org.alfresco.fileserver] at org.alfresco.jlan.smb.server.SMBServer.run(SMBServer.java:478)
16:45:37,949 ERROR [org.alfresco.fileserver] at java.lang.Thread.run(Thread.java:619)
16:45:37,953 ERROR [org.alfresco.fileserver] [FTP] FTP Socket error : java.net.BindException: Permission denied
16:45:37,953 ERROR [org.alfresco.fileserver] java.net.BindException: Permission denied
16:45:37,953 ERROR [org.alfresco.fileserver] at java.net.PlainSocketImpl.socketBind(Native Method)
16:45:37,953 ERROR [org.alfresco.fileserver] at java.net.PlainSocketImpl.bind(PlainSocketImpl.java:365)
16:45:37,953 ERROR [org.alfresco.fileserver] at java.net.ServerSocket.bind(ServerSocket.java:319)
16:45:37,953 ERROR [org.alfresco.fileserver] at java.net.ServerSocket.<init>(ServerSocket.java:185)
16:45:37,953 ERROR [org.alfresco.fileserver] at java.net.ServerSocket.<init>(ServerSocket.java:141)
16:45:37,965 ERROR [org.alfresco.fileserver] at org.alfresco.jlan.ftp.FTPServer.run(FTPServer.java:561)
16:45:37,965 ERROR [org.alfresco.fileserver] at java.lang.Thread.run(Thread.java:619)
16:45:37,964 INFO [alfresco.config.JndiPropertyPlaceholderConfigurer] Loading properties file from class path resource [alfresco/alfresco-shared.properties]
16:45:38,056 INFO [management.subsystems.ChildApplicationContextFactory] Startup of 'imap' subsystem, ID: [imap, default] complete
16:45:38,062 INFO [repo.usage.UserUsageTrackingComponent] Enabled - calculate missing user usages …
16:45:38,084 INFO [repo.usage.UserUsageTrackingComponent] Found 0 users to recalculate
16:45:38,084 INFO [repo.usage.UserUsageTrackingComponent] … calculated missing usages for 0 users
16:45:38,084 INFO [management.subsystems.ChildApplicationContextFactory] Starting 'Synchronization' subsystem, ID: [Synchronization, default]
16:45:38,105 INFO [alfresco.config.JndiPropertyPlaceholderConfigurer] Loading properties file from class path resource [alfresco/alfresco-shared.properties]
16:45:38,236 INFO [management.subsystems.ChildApplicationContextFactory] Startup of 'Synchronization' subsystem, ID: [Synchronization, default] complete
16:45:38,366 ERROR [web.context.ContextLoader] Context initialization failed
org.alfresco.repo.audit.model.AuditModelException: 05290002 Failed to load audit model: file:/home/christophe/alfresco32r2/tomcat/webapps/alfresco/WEB-INF/classes/alfresco/audit/alfresco-audit-repository.xml
at org.alfresco.repo.audit.model.AuditModelRegistry$1.execute(AuditModelRegistry.java:258)
at org.alfresco.repo.audit.model.AuditModelRegistry$1.execute(AuditModelRegistry.java:238)
at org.alfresco.repo.transaction.RetryingTransactionHelper.doInTransaction(RetryingTransactionHelper.java:327)
at org.alfresco.repo.audit.model.AuditModelRegistry.loadAuditModels(AuditModelRegistry.java:276)
at org.alfresco.repo.audit.AuditBootstrap$1.execute(AuditBootstrap.java:64)
at org.alfresco.repo.audit.AuditBootstrap$1.execute(AuditBootstrap.java:62)
at org.alfresco.repo.transaction.RetryingTransactionHelper.doInTransaction(RetryingTransactionHelper.java:253)
at org.alfresco.repo.audit.AuditBootstrap.onBootstrap(AuditBootstrap.java:68)
at org.springframework.context.support.AbstractApplicationContext.finishRefresh(AbstractApplicationContext.java:617)
Caused by: org.alfresco.error.AlfrescoRuntimeException: 05290001 Failed to load Alfresco Audit Schema from classpath:alfresco/audit/alfresco-audit-3.2.xsd
at org.alfresco.repo.audit.model.AuditModelRegistry.unmarshallModel(AuditModelRegistry.java:385)
at org.alfresco.repo.audit.model.AuditModelRegistry.unmarshallModel(AuditModelRegistry.java:344)
at org.alfresco.repo.audit.model.AuditModelRegistry$1.execute(AuditModelRegistry.java:246)
… 43 more
Caused by: java.lang.NoSuchMethodError: org.apache.xerces.impl.xs.XMLSchemaLoader.loadGrammar([Lorg/apache/xerces/xni/parser/XMLInputSource;)V
at org.apache.xerces.jaxp.validation.XMLSchemaFactory.newSchema(Unknown Source)
at javax.xml.validation.SchemaFactory.newSchema(SchemaFactory.java:594)
at javax.xml.validation.SchemaFactory.newSchema(SchemaFactory.java:626)
at org.alfresco.repo.audit.model.AuditModelRegistry.unmarshallModel(AuditModelRegistry.java:363)
… 45 more
29 juin 2010 16:45:38 org.apache.catalina.core.StandardContext start
GRAVE: Error listenerStart
GRAVE: Erreur de d�marrage du contexte [/alfresco] suite aux erreurs pr�c�dentes
06-30-2010 08:26 AM
07-09-2010 12:04 AM
13:56:34,921 ERROR [org.springframework.web.context.ContextLoader] Context initialization failed
org.alfresco.repo.audit.model.AuditModelException: 06090001 Failed to load audit model: file:/D:/apps/Alfresco-Community-3.2/tomcat/webapps/alfresco/WEB-INF/classes/alfresco/audit/alfresco-audit-repository.xml
Caused by: org.alfresco.error.AlfrescoRuntimeException: 06090000 Failed to load Alfresco Audit Schema from classpath:alfresco/audit/alfresco-audit-3.2.xsd
… 43 more
… 45 more
13:56:39,609 INFO [org.alfresco.config.JBossEnabledWebApplicationContext] Refreshing org.alfresco.config.JBossEnabledWebApplicationContext@10ec6d0: display name [Root WebApplicationContext]; startup date [Fri Jul 09 13:56:39 EST 2010]; root of context hierarchy
13:56:40,000 INFO [org.alfresco.config.JBossEnabledWebApplicationContext] Bean factory for application context [org.alfresco.config.JBossEnabledWebApplicationContext@10ec6d0]: org.springframework.beans.factory.support.DefaultListableBeanFactory@4fbad6
13:56:41,390 INFO [org.alfresco.web.scripts.DeclarativeRegistry] Registered 22 Web Scripts (+0 failed), 24 URLs
13:56:41,421 INFO [org.alfresco.web.scripts.AbstractRuntimeContainer] Initialised Presentation Web Script Container (in 288.6437ms)
13:56:41,578 INFO [org.alfresco.web.scripts.DeclarativeRegistry] Registered 40 Web Scripts (+0 failed), 42 URLs
13:56:41,593 INFO [org.alfresco.web.scripts.AbstractRuntimeContainer] Initialised WebFramework Web Script Container (in 169.54623ms)
13:56:41,656 INFO [org.alfresco.web.site.FrameworkHelper] Successfully Initialized Web Framework
13:56:46,281 INFO [org.alfresco.web.site.FrameworkHelper] Successfully Initialized Web Framework
@ECHO OFF
REM Set Paths Utility - created by installer
:: SET JAVA_HOME=C:\Program Files\Java\jdk1.6.0_20
SET JAVA_HOME=C:\Program Files\Java\jdk1.5.0_22
SET PATH=%JAVA_HOME%\bin;%PATH%
