Problem with alfwf.war surf example
langust
I've checked out the latest Alfresco sources and successfully build the alfwf.war surf example.
But after deploying it to the standalone Tomcat 6 and running it I've got the following exception:
  15:55:25,953 ERROR [org.springframework.web.context.ContextLoader] Context initialization failed
org.springframework.beans.factory.BeanDefinitionStoreException: IOException parsing XML document from class path resource [alfresco/web-extension/custom-web-framework-application-context.xml]; nested exception is java.io.FileNotFoundException: class path resource [alfresco/web-extension/custom-web-framework-application-context.xml] cannot be opened because it does not exist
Caused by: java.io.FileNotFoundException: class path resource [alfresco/web-extension/custom-web-framework-application-context.xml] cannot be opened because it does not exist
   at org.springframework.core.io.ClassPathResource.getInputStream(ClassPathResource.java:135)
   at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.loadBeanDefinitions(XmlBeanDefinitionReader.java:297)
   at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.loadBeanDefinitions(XmlBeanDefinitionReader.java:280)
   at org.springframework.beans.factory.support.AbstractBeanDefinitionReader.loadBeanDefinitions(AbstractBeanDefinitionReader.java:131)
   at org.springframework.beans.factory.support.AbstractBeanDefinitionReader.loadBeanDefinitions(AbstractBeanDefinitionReader.java:147)
   at org.springframework.web.context.support.XmlWebApplicationContext.loadBeanDefinitions(XmlWebApplicationContext.java:124)
   at org.springframework.web.context.support.XmlWebApplicationContext.loadBeanDefinitions(XmlWebApplicationContext.java:92)
   at org.springframework.context.support.AbstractRefreshableApplicationContext.refreshBeanFactory(AbstractRefreshableApplicationContext.java:101)
   at org.springframework.context.support.AbstractApplicationContext.obtainFreshBeanFactory(AbstractApplicationContext.java:389)
   at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:324)
   at org.springframework.web.context.ContextLoader.createWebApplicationContext(ContextLoader.java:244)
   at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:187)
   at org.apache.catalina.core.StandardContext.start(StandardContext.java:4350)
   at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:829)
   at org.apache.catalina.startup.HostConfig.deployWARs(HostConfig.java:718)
   at org.apache.catalina.startup.HostConfig.start(HostConfig.java:1147)
yusuf_aaji
ben
Your best bet is to go with the Surf Starter WAR.
ant incremental-surf-starter‍
This creates the starter WAR file which includes example components and configurations.  Alternatively you can download the WAR file here - http://www.benh.co.uk/wp-content/uploads/2009/02/surf.war.  Please be aware this was built on 09 Feb and may have changed since then, so building from source is reccomended.
Regards, Ben.
