Problem with Alfresco Web Editor
ajmillar
Have checked out the latest code from HEAD, but I'm having trouble deploying the alfresco web editor. I'm getting the following message after logging in …
A form could not be found, has an 'itemKind' and 'itemId' been provided?
Anyone had similar problems and found a solution?
16 REPLIES 16
winsenthil
Usually you need to change that node values to get the correct html files from any location from your repository..
I think you must have changed your alfresco account details i.e. maybe username and password…
check with the web.xml file of the sample customer application.  It will have a default  username and password like admin..
If you are having different account details, update them and check.
Hope this helps..
sowmya
Hi…
Its correct..Now I can able to view the application,
winsenthil
Hi yogesh,
Had you found the solution for the below issue:
The problem i am facing is i am not getting a node reference for the content that i create in a Web Project..
If you had found how to get the node ref for the forms inside a web project., kindly reply..
yogesh_prabhu
Hi Win,
Sorry Win, i have not got a solution for the issue: Viewing web content created in Web Projects in the editable format..using Web Editor!!
Please reply to this post if u find any..
Thanks..
gauri_joshi
Refering to post Re: Problem with Alfresco Web Editor
by yogesh_prabhu » 16 Jul 2010, 17:26
hi yogesh,
Can you pl. provide the details of the steps you took for getting it working?
Did you do any modifications to awe-config-custom.xml? If yes, what kind of configuration?
I am using Alfresco 3.3 community edition. I have deployed 'customer' web aplication. I am able to see the edit icons for the text that is marked with <awe:markContent…/> tag.
But, when I click on the edit icon, nothing happens. If I open the url of the edit icon in a new window, it shows Alfresco Web Editor login page and prompts for user name and pwd. Evenif I enter admin/admin, nothing works. The control comes back to the blank AWE login page.
Any suggestions on how this can be resolved? I have specific a custom form in <awe:markContent…/> tag. Are there any configurations required for custom forms?
reg,
gauri
I am able to run the sample now..
When i specify the noderefs of the nodes from my repository i get to see the content in the editable format in the browser..
Now, my issue is: how can i view the web content in the editable format created in web projects??
Has anyone tried this..??
Any kind of suggestions are welcome..
Thanks in advance..
Yogesh
sadasivaram
I am facing the same problem.
I am using Alfresco web editor 3.4.d. I cant get the sample application "customer" working.
I have modified the web.xml to point to my alfresco server which is running on a different machine. The username password configured is admin/admin.
AWE is running on tomcat 6 and my alfresco version is 3.3g.
when I fire http://localhost:8080/customer,  I am able to see the html content pulled from the repository. but the interface keeps asking me for the username password. I tried all different combinations of username password but it still wouldnt work.
Anyone has any thoughts on this?
ffazil2002
hi yogesh,
reg,
gauri
Thanks in advance..
Yogesh
The problem I am having (in my project) is that, it is showing content but not the toolbars and when I checked with firebug, I see the container is set to display:none, not sure what the problem is. The code is:
<span id="alf_1322746458695-1" class="alfresco-content-marker" style="display: none">
