Problem with alfreco labs installation
Options
01-12-2009 02:42 AM
I had alfresco enterprise 3.0 trial version (Alfresco-Enterprise-3.0.0-Full-Setup.exe) installed for some PoC purpose. Then I installed alfresco labs (Alfresco-Labs-3c-Full-Setup.exe) without un-installing the earlier enterprise version. Now when I tried to run alfresco server for the labs installation (enterprise version was not running at that time) I got the following exception:
13:01:00,662 ERROR [web.context.ContextLoader] Context initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'org.springframework.remoting.rmi
.RmiServiceExporter' defined in class path resource [alfresco/emailserver/email-service-context.xml]: Invocation of init
method failed; nested exception is java.rmi.server.ExportException: internal error: ObjID already in use
Caused by: java.rmi.server.ExportException: internal error: ObjID already in use
I tried changing the port number for the email server from 25 in file "D:\Alfresco\tomcat\webapps\alfresco\WEB-INF\classes\alfresco\emailserver\email-server.properties" but it is still not working. I did some googling and it seems that the problem is with the RMI registry, but I am stuck at that.
Can anybody please help me how to resolve this issue.
Btw, I have also tried uninstalling enterprise version and then uninstalling labs version and re-installing labs version. But same problem still persists.
– Bodh
– Bodh
Labels:
Archive
Options
01-13-2009 02:42 PM
I believe you are installing alfresco on windows os.
I think the problem may be because when you install alfresco, the alfresco server is installed as a windows service.
But when you uninstall it, it is not removed from the windows service.
You can try removing the alfresco service and then re-installing the labs version.
