01-28-2010 08:21 AM
cifs.enabled=true
#cifs.serverName=${localname}A
cifs.serverName=ALF
cifs.domain=
cifs.broadcast=255.255.255.255
# An empty value indicates bind to all available network adapters
cifs.bindto=
cifs.ipv6.enabled=false
cifs.hostannounce=true
# Enable the use of asynchronous sockets/NIO code
cifs.disableNIO=false
# Disable the use of JNI code. Only currently affects Windows
cifs.disableNativeCode=false
# Session timeout, in seconds. Defaults to 15 minutes, to match the default Windows client setting.
# If no I/O is received within that time the session is closed by the server
cifs.sessionTimeout=900
# Can be mapped to non-privileged ports, then use firewall rules to forward requests from the standard ports
cifs.tcpipSMB.port=445
cifs.netBIOSSMB.sessionPort=139
cifs.netBIOSSMB.namePort=137
cifs.netBIOSSMB.datagramPort=138
# Optional WINS server primary and secondary IP addresses. Ignored if autoDetectEnabled=true
cifs.WINS.autoDetectEnabled=true
cifs.WINS.primary=1.2.3.4
cifs.WINS.secondary=5.6.7.8
02-05-2010 11:13 AM
