I got installed setup alfresco, and installed it then when I start to run the server I got problem , can u help me out………..
the problem is..
CompilerOracle: exclude org/apache/lucene/index/IndexReader$1 doBody
CompilerOracle: exclude org/alfresco/repo/search/impl/lucene/index/IndexInfo$Mer
ger mergeIndexes
ger mergeDeletions
Jun 14, 2007 3:21:33 PM org.apache.catalina.core.AprLifecycleListener lifecycleE
vent
INFO: The Apache Tomcat Native library which allows optimal performance in produ
ction environments was not found on the java.library.path: C:\Alfresco\java\bin;
.;C:\WINDOWS\system32;C:\WINDOWS;C:\Alfresco\java\bin;C:\Alfresco\bin;E:\oracle\
jdk\jre\bin\classic;E:\oracle\jdk\jre\bin;E:\oracle\jdk\jre\bin\client;E:\oracle
\jlib;E:\oracle\bin;E:\oracle\jre\1.4.2\bin\client;E:\oracle\jre\1.4.2\bin;C:\WI
NDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program Files\Java\jdk1.5.
0_05\bin;D:\apache-tomcat-5.5.20\common\lib\servlet-api.jar;c:\Program Files\com
Jun 14, 2007 3:21:34 PM org.apache.coyote.http11.Http11BaseProtocol init
INFO: Initializing Coyote HTTP/1.1 on http-9999
Jun 14, 2007 3:21:34 PM org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 1922 ms
Jun 14, 2007 3:21:34 PM org.apache.catalina.core.StandardService start
Jun 14, 2007 3:21:34 PM org.apache.catalina.core.StandardEngine start
INFO: Starting Servlet Engine: Apache Tomcat/5.5.20
Jun 14, 2007 3:21:34 PM org.apache.catalina.core.StandardHost start
INFO: XML validation disabled
Jun 14, 2007 3:21:36 PM org.apache.catalina.startup.HostConfig deployWAR
FATAL - Unable to parse web.xml
java.lang.IllegalArgumentException: jaxp-null-input-source: The source specified
cannot be null.
at org.apache.xerces.jaxp.DocumentBuilderImpl.parse(Unknown Source)
at org.apache.myfaces.webapp.webxml.WebXmlParser.parse(WebXmlParser.java
:89)
at org.apache.myfaces.webapp.webxml.WebXml.init(WebXml.java:135)
at org.apache.myfaces.webapp.StartupServletContextListener.initFaces(Sta
rtupServletContextListener.java:66)
at org.apache.myfaces.webapp.StartupServletContextListener.contextInitia
lized(StartupServletContextListener.java:46)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContex
t.java:3763)
at org.apache.catalina.core.StandardContext.start(StandardContext.java:4
211)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase
.java:759)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:73
9)
at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:809)
at org.apache.catalina.startup.HostConfig.deployWARs(HostConfig.java:698
at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:472
at org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java
:310)
at org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(Lifecycl
eSupport.java:119)
at org.apache.catalina.core.StandardEngine.start(StandardEngine.java:442
at org.apache.catalina.core.StandardService.start(StandardService.java:4
50)
at org.apache.catalina.core.StandardServer.start(StandardServer.java:709
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.
java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAcces
sorImpl.java:25)
javax.faces.FacesException: java.lang.IllegalArgumentException: jaxp-null-input-
source: The source specified cannot be null.
:105)
t.java:3763)
211)
.java:759)
9)
:310)
eSupport.java:119)
50)
java:39)
sorImpl.java:25)
Caused by: java.lang.IllegalArgumentException: jaxp-null-input-source: The sourc
:89)
… 27 more
Jun 14, 2007 3:21:41 PM org.apache.coyote.http11.Http11BaseProtocol start
INFO: Starting Coyote HTTP/1.1 on http-9999
Jun 14, 2007 3:21:41 PM org.apache.jk.common.ChannelSocket init
INFO: JK: ajp13 listening on /0.0.0.0:8009
Jun 14, 2007 3:21:41 PM org.apache.jk.server.JkMain start
INFO: Jk running ID=0 time=0/32 config=null
Jun 14, 2007 3:21:42 PM org.apache.catalina.storeconfig.StoreLoader load
Jun 14, 2007 3:21:42 PM org.apache.catalina.startup.Catalina start
INFO: Server startup in 7984 ms
