Problem running WebServiceExample1 in RemoteAPI project
drbaz
When I run the org.alfresco.example.webservce.sample.WebServiceExample1, I get the following error:
Exception in thread "main" AxisFault
faultCode: {http://schemas.xmlsoap.org/soap/envelope/}Server.userException
faultSubcode:
faultString: org.xml.sax.SAXParseException: Premature end of file.
faultActor:
faultNode:
faultDetail:
   {http://xml.apache.org/axis/}stackTraceSmiley Surprisedrg.xml.sax.SAXParseException: Premature end of file.
   etc etc etc
Any suggestions ?
Other examples run OK
10 REPLIES 10
drbaz
Roy, as per your e-mail - the 'systen' value is in the types/xsd file
Here's my console trace:
faultSubcode:
faultActor:
faultNode:
faultDetail:
   at com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.createSAXParseException(ErrorHandlerWrapper.java:236)
   at com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.fatalError(ErrorHandlerWrapper.java:215)
   at com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.reportError(XMLErrorReporter.java:386)
   at com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.reportError(XMLErrorReporter.java:316)
   at com.sun.org.apache.xerces.internal.impl.XMLVersionDetector.determineDocVersion(XMLVersionDetector.java:230)
   at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:798)
   at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:764)
   at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.java:148)
   at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(AbstractSAXParser.java:1242)
   at javax.xml.parsers.SAXParser.parse(SAXParser.java:375)
   at org.apache.axis.encoding.DeserializationContext.parse(DeserializationContext.java:227)
   at org.apache.axis.SOAPPart.getAsSOAPEnvelope(SOAPPart.java:696)
   at org.apache.axis.Message.getSOAPEnvelope(Message.java:424)
   at org.apache.axis.handlers.soap.MustUnderstandChecker.invoke(MustUnderstandChecker.java:62)
   at org.apache.axis.client.AxisClient.invoke(AxisClient.java:206)
   at org.apache.axis.client.Call.invokeEngine(Call.java:2765)
   at org.apache.axis.client.Call.invoke(Call.java:2748)
   at org.apache.axis.client.Call.invoke(Call.java:2424)
   at org.apache.axis.client.Call.invoke(Call.java:2347)
   at org.apache.axis.client.Call.invoke(Call.java:1804)
   at org.alfresco.example.webservice.repository.RepositoryServiceSoapBindingStub.getStores(RepositoryServiceSoapBindingStub.java:666)
   at org.alfresco.example.webservice.sample.WebServiceSample1.main(WebServiceSample1.java:87)
   {http://xml.apache.org/axis/}hostname:linuxserver
   at org.apache.axis.AxisFault.makeFault(AxisFault.java:101)
   at org.apache.axis.SOAPPart.getAsSOAPEnvelope(SOAPPart.java:701)
Caused by: org.xml.sax.SAXParseException: Premature end of file.
   … 10 more
