Problem running post-install step. An IO error was encountered during deployment of the AMP into the WAR.
sigroup
Hello
I try to install alfresco-community-4.2.c-installer-win-x64.exe, simple installation (I don't know if this means Alfresco use solr or/and lucene, it can be important for later), I only change some ports because the defaults ports are already in use on the server where I try to install.
The installation looks to be running normally almost until the end. But a few before the end I get this error message:
[img]http://i46.tinypic.com/34j8yfr.jpg[/img]
Even with this message, Alfresco looks like more or less OK. I had to redeploy the WAR still. Then I could login, add document…
But the search on peoples was not working. I did this to make it work:
<blockcode>For a full solr re-index, you have to stop solr, and delete the solr index directory. That may be what have happened here, you haven't actually re-indexed solr. Back to how to remove solr Stop tomcat delete tomcat/conf/Catalina/localhost/solr.xml delete directory tomcat/webapps/solr restart</blockcode>
After that I saw that the documents search was not working. I tried this (to do a full re-index for lucene):
<blockcode>index.recovery.mode=FULL  </blockcode>
But it did not change anything.
I guess I better stop it now and try to do a CLEAN instalaltion with no error. Can you help me to do the installation with no error?
Thanks.
ginanjar
I got the same error but different code
09030000 or 09040000 instead of 03170000.
Still not having a clean install yet, have you found the solution?
Thank you,
Ginanjar
nurulayuni
Hi All.. i also hit a same error as yours. have anyone found a solution for this? If yes, mind to share here?
fyi, i'm really a newbie with this alfresco.
Thank you.
nurulayuni
Thank you.
