problem running alfresco-wcm_examples-3.3 on virtual tomcat
Options
11-23-2010 11:47 PM
Hi
I installed Alfresco community 3.4; it works very nicely. Then I tried to run the alfresco-wcm-examples-3.3\..\getting-started-sample; when I tried to preview, I got: Firefox can't establish a connection to the server at alfrescosample.www–sandbox.127-0-0-1.ip.alfrescodemo.net:8180
if I ping alfrescosample.www–sandbox.127-0-0-1.ip.alfrescodemo.net from my server, it return the 127.0.0.1; it is ok.
I checked the virtual server and I have to confess that it is not obvious to see what is going on. I checked port 8180 with netstat -p|grep 8180; nothing! It looks to me that the virtual tomcat is not up.
Please tell me, do I have to run my standard alfresco (alfresco.sh start) and run in parallel /alfresco/alfresco-3.4.a/virtual-tomcat/bin/startup.sh? It looks to me that it does nothing. It doesn't output anything in the log directory. on Linux, I should run sh virtual_alf.sh start.. This file is not in the comunity 3.4 distribution.
Is it necessary to run the samples with the virtual tomcat?
I finally succeeded in having the VS working.
how ?
the default parameter for the VM are a little too small.. I inflated it a bit : -Xms512m -XX:MaxPermSize=200m That way i didn't have PermGen error in the catalina.log file. I did that for both VM (tomcat and virt-tomcat).
Then, I had to set environment variables prior to launch startup.sh, because by default, those variables point to the Alfresco based directory and virt-tomcat conflicts with the tomcatl already running. When an atempt is made to use virt-tomcat, environement variables for the JVM must be set to ….virt-tomcat/bin directory.
how ?
Labels:
Archive
Options
11-24-2010 03:55 AM
If you want to use the V.S. Then yes it has to be running.
Please note that there is a bug in the configuration applied with the Bitrock installer for the V.S for 3.4a and 3.4b. Either use an older installer or a newer installer.
