Problem running a simple Junit (Junit 4 style)
monika_b
Hi, I have wrote a simple activiti junit as below. Trying to 'run as Junit' via eclipse. I am getting exception as below. Please can someone help me. I know I am missing something at very basic level.
Please note I have included all jars in my project from activiti-5.14\libs.
Exception Below:-
java.lang.NoClassDefFoundError: org/junit/rules/TestRule
   at java.lang.ClassLoader.defineClass1(Native Method)
   at java.lang.ClassLoader.defineClass(Unknown Source)
   at java.security.SecureClassLoader.defineClass(Unknown Source)
   at java.net.URLClassLoader.defineClass(Unknown Source)
   at java.net.URLClassLoader.access$100(Unknown Source)
   at java.net.URLClassLoader$1.run(Unknown Source)
   at java.net.URLClassLoader.findClass(Unknown Source)
   at java.lang.ClassLoader.loadClass(Unknown Source)
   at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
   at java.lang.Class.getDeclaredFields0(Native Method)
   at java.lang.Class.privateGetDeclaredFields(Unknown Source)
   at java.lang.Class.getDeclaredFields(Unknown Source)
   at org.junit.runners.model.TestClass.<init>(TestClass.java:40)
   at org.junit.runners.ParentRunner.<init>(ParentRunner.java:65)
   at org.junit.runners.BlockJUnit4ClassRunner.<init>(BlockJUnit4ClassRunner.java:59)
   at org.junit.internal.builders.JUnit4Builder.runnerForClass(JUnit4Builder.java:13)
   at org.junit.runners.model.RunnerBuilder.safeRunnerForClass(RunnerBuilder.java:57)
   at org.junit.internal.builders.AllDefaultPossibilitiesBuilder.runnerForClass(AllDefaultPossibilitiesBuilder.java:29)
   at org.junit.internal.requests.ClassRequest.getRunner(ClassRequest.java:24)
   at org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.<init>(JUnit4TestReference.java:33)
   at org.eclipse.jdt.internal.junit4.runner.JUnit4TestClassReference.<init>(JUnit4TestClassReference.java:25)
   at org.eclipse.jdt.internal.junit4.runner.JUnit4TestLoader.createTest(JUnit4TestLoader.java:48)
   at org.eclipse.jdt.internal.junit4.runner.JUnit4TestLoader.loadTests(JUnit4TestLoader.java:38)
   at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:452)
   at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:683)
   at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(RemoteTestRunner.java:390)
   at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main(RemoteTestRunner.java:197)
Caused by: java.lang.ClassNotFoundException: org.junit.rules.TestRule
   … 31 more
import org.activiti.engine.test.Deployment;
import org.junit.Rule;
import org.junit.Test;
public class TestMyProcess{
   @Rule
   @Test
   @Deployment
   public void testMyProcess()
       runtimeService.startProcessInstanceByKey("myProcess");
       System.out.println("Completed Test Activiti");
My Simple myProcess.bpmn20.xml is below:
<definitions xmlns="http://www.omg.org/spec/BPMN/20100524/MODEL" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:activiti="http://activiti.org/bpmn" xmlns:bpmndi="http://www.omg.org/spec/BPMN/20100524/DI" xmlns:omgdc="http://www.omg.org/spec/DD/20100524/DC" xmlns:omgdi="http://www.omg.org/spec/DD/20100524/DI" typeLanguage="http://www.w3.org/2001/XMLSchema" expressionLanguage="http://www.w3.org/1999/XPath" targetNamespace="http://www.activiti.org/test">
  <process id="myProcess" name="My process" isExecutable="true">
    <serviceTask id="servicetask1" name="Service Task" activiti:class="com.companyName.activiti.common.JavaActService1"></serviceTask>
    <sequenceFlow id="flow1" sourceRef="startevent1" targetRef="servicetask1"></sequenceFlow>
    <sequenceFlow id="flow2" sourceRef="servicetask1" targetRef="endevent1"></sequenceFlow>
  </process>
  <bpmndi:BPMNDiagram id="BPMNDiagram_myProcess">
    <bpmndi:BPMNPlane bpmnElement="myProcess" id="BPMNPlane_myProcess">
      <bpmndi:BPMNShape bpmnElement="startevent1" id="BPMNShape_startevent1">
        <omgdc:Bounds height="35.0" width="35.0" x="350.0" y="200.0"></omgdc:Bounds>
      </bpmndi:BPMNShape>
      <bpmndi:BPMNShape bpmnElement="servicetask1" id="BPMNShape_servicetask1">
        <omgdc:Bounds height="55.0" width="105.0" x="600.0" y="190.0"></omgdc:Bounds>
      </bpmndi:BPMNShape>
        <omgdc:Bounds height="35.0" width="35.0" x="930.0" y="200.0"></omgdc:Bounds>
      </bpmndi:BPMNShape>
        <omgdi:waypoint x="385.0" y="217.0"></omgdi:waypoint>
        <omgdi:waypoint x="600.0" y="217.0"></omgdi:waypoint>
      </bpmndi:BPMNEdge>
        <omgdi:waypoint x="705.0" y="217.0"></omgdi:waypoint>
        <omgdi:waypoint x="930.0" y="217.0"></omgdi:waypoint>
      </bpmndi:BPMNEdge>
    </bpmndi:BPMNPlane>
  </bpmndi:BPMNDiagram>
</definitions>
I am having proceeses.xml with above bpmn xml file as below:
<?xml version="1.0" encoding="utf-8" ?>
<processes>
        <process resource="diagrams/MyProcess.bpmn20.xml" />
</processes>
Some basic question. Please help.
Do I need to put some code somewhere in my junit class similar to:
<b>repositoryService.createDeployment().addClasspathResource("org/activiti/test/VacationRequest.bpmn20.xml").deploy();<b>
If not, How do the junit deploy the process otherwise. If yes, please help how to do so.
Thanks in advance for any help.
12 REPLIES 12
vickysirwani
Upvoting of answers should be made possible.
smritishikha
please help me to write test cases in eclipse for activiti …. when i write as per the user guide method but its showing error.
vasile_dirla
you wrote: "its showing error". more exactly what's happening; what error did you get?
please provide some more details.
