Problem running a simple Junit (Junit 4 style)
monika_b
Hi, I have wrote a simple activiti junit as below. Trying to 'run as Junit' via eclipse. I am getting exception as below. Please can someone help me. I know I am missing something at very basic level.
Please note I have included all jars in my project from activiti-5.14\libs.
Exception Below:-
java.lang.NoClassDefFoundError: org/junit/rules/TestRule
   at java.lang.ClassLoader.defineClass1(Native Method)
   at java.lang.ClassLoader.defineClass(Unknown Source)
   at java.security.SecureClassLoader.defineClass(Unknown Source)
   at java.net.URLClassLoader.defineClass(Unknown Source)
   at java.net.URLClassLoader.access$100(Unknown Source)
   at java.net.URLClassLoader$1.run(Unknown Source)
   at java.net.URLClassLoader.findClass(Unknown Source)
   at java.lang.ClassLoader.loadClass(Unknown Source)
   at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
   at java.lang.Class.getDeclaredFields0(Native Method)
   at java.lang.Class.privateGetDeclaredFields(Unknown Source)
   at java.lang.Class.getDeclaredFields(Unknown Source)
   at org.junit.runners.model.TestClass.<init>(TestClass.java:40)
   at org.junit.runners.ParentRunner.<init>(ParentRunner.java:65)
   at org.junit.runners.BlockJUnit4ClassRunner.<init>(BlockJUnit4ClassRunner.java:59)
   at org.junit.internal.builders.JUnit4Builder.runnerForClass(JUnit4Builder.java:13)
   at org.junit.runners.model.RunnerBuilder.safeRunnerForClass(RunnerBuilder.java:57)
   at org.junit.internal.builders.AllDefaultPossibilitiesBuilder.runnerForClass(AllDefaultPossibilitiesBuilder.java:29)
   at org.junit.internal.requests.ClassRequest.getRunner(ClassRequest.java:24)
   at org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.<init>(JUnit4TestReference.java:33)
   at org.eclipse.jdt.internal.junit4.runner.JUnit4TestClassReference.<init>(JUnit4TestClassReference.java:25)
   at org.eclipse.jdt.internal.junit4.runner.JUnit4TestLoader.createTest(JUnit4TestLoader.java:48)
   at org.eclipse.jdt.internal.junit4.runner.JUnit4TestLoader.loadTests(JUnit4TestLoader.java:38)
   at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:452)
   at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:683)
   at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(RemoteTestRunner.java:390)
   at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main(RemoteTestRunner.java:197)
Caused by: java.lang.ClassNotFoundException: org.junit.rules.TestRule
   … 31 more
import org.activiti.engine.test.Deployment;
import org.junit.Rule;
import org.junit.Test;
public class TestMyProcess{
   @Rule
   @Test
   @Deployment
   public void testMyProcess()
       runtimeService.startProcessInstanceByKey("myProcess");
       System.out.println("Completed Test Activiti");
My Simple myProcess.bpmn20.xml is below:
<definitions xmlns="http://www.omg.org/spec/BPMN/20100524/MODEL" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:activiti="http://activiti.org/bpmn" xmlns:bpmndi="http://www.omg.org/spec/BPMN/20100524/DI" xmlns:omgdc="http://www.omg.org/spec/DD/20100524/DC" xmlns:omgdi="http://www.omg.org/spec/DD/20100524/DI" typeLanguage="http://www.w3.org/2001/XMLSchema" expressionLanguage="http://www.w3.org/1999/XPath" targetNamespace="http://www.activiti.org/test">
  <process id="myProcess" name="My process" isExecutable="true">
    <serviceTask id="servicetask1" name="Service Task" activiti:class="com.companyName.activiti.common.JavaActService1"></serviceTask>
    <sequenceFlow id="flow1" sourceRef="startevent1" targetRef="servicetask1"></sequenceFlow>
    <sequenceFlow id="flow2" sourceRef="servicetask1" targetRef="endevent1"></sequenceFlow>
  </process>
  <bpmndi:BPMNDiagram id="BPMNDiagram_myProcess">
    <bpmndi:BPMNPlane bpmnElement="myProcess" id="BPMNPlane_myProcess">
      <bpmndi:BPMNShape bpmnElement="startevent1" id="BPMNShape_startevent1">
        <omgdc:Bounds height="35.0" width="35.0" x="350.0" y="200.0"></omgdc:Bounds>
      </bpmndi:BPMNShape>
      <bpmndi:BPMNShape bpmnElement="servicetask1" id="BPMNShape_servicetask1">
        <omgdc:Bounds height="55.0" width="105.0" x="600.0" y="190.0"></omgdc:Bounds>
      </bpmndi:BPMNShape>
        <omgdc:Bounds height="35.0" width="35.0" x="930.0" y="200.0"></omgdc:Bounds>
      </bpmndi:BPMNShape>
        <omgdi:waypoint x="385.0" y="217.0"></omgdi:waypoint>
        <omgdi:waypoint x="600.0" y="217.0"></omgdi:waypoint>
      </bpmndi:BPMNEdge>
        <omgdi:waypoint x="705.0" y="217.0"></omgdi:waypoint>
        <omgdi:waypoint x="930.0" y="217.0"></omgdi:waypoint>
      </bpmndi:BPMNEdge>
    </bpmndi:BPMNPlane>
  </bpmndi:BPMNDiagram>
</definitions>
I am having proceeses.xml with above bpmn xml file as below:
<?xml version="1.0" encoding="utf-8" ?>
<processes>
        <process resource="diagrams/MyProcess.bpmn20.xml" />
</processes>
Some basic question. Please help.
Do I need to put some code somewhere in my junit class similar to:
<b>repositoryService.createDeployment().addClasspathResource("org/activiti/test/VacationRequest.bpmn20.xml").deploy();<b>
If not, How do the junit deploy the process otherwise. If yes, please help how to do so.
Thanks in advance for any help.
12 REPLIES 12
monika_b
I tried replacing public ActivitiRule activitiRule = new ActivitiRule(); with public ActivitiRule activitiRule = new ActivitiRule("activiti-context.xml"); also. Still same exception.
I am using Junit 4.8.1 jar. Seems this does not contain TestRule class. and Junit-4.9.jar contains this. I tried downloading and adding this jar to my project now getting exception as:
<code>
java.lang.Exception: Field activitiRule must implement MethodRule
at org.junit.runners.BlockJUnit4ClassRunner.validateRuleField(BlockJUnit4ClassRunner.java:181)
at org.junit.runners.BlockJUnit4ClassRunner.validateFields(BlockJUnit4ClassRunner.java:176)
at org.junit.runners.BlockJUnit4ClassRunner.collectInitializationErrors(BlockJUnit4ClassRunner.java:116)
at org.junit.runners.ParentRunner.validate(ParentRunner.java:269)
at org.junit.runners.ParentRunner.<init>(ParentRunner.java:66)
</code>
My activiti-context.xml is
<code>
xmlns:context="http://www.springframework.org/schema/context" xmlns:tx="http://www.springframework.org/schema/tx"
xsi:schemaLocation="http://www.springframework.org/schema/beans   http://www.springframework.org/schema/beans/spring-beans.xsd
                           http://www.springframework.org/schema/context http://www.springframework.org/schema/context/spring-context-2.5.xsd
                           http://www.springframework.org/schema/tx      http://www.springframework.org/schema/tx/spring-tx-3.0.xsd">
  <property name="dataSource" ref="myDataSource" />
</bean>
<bean id="processEngine" class="org.activiti.spring.ProcessEngineFactoryBean">
</bean>
<bean id="activitiRule" class="org.activiti.engine.test.ActivitiRule">
  <property name="processEngine" ref="processEngine" />
</bean>
<bean id="repositoryService" factory-bean="processEngine"
  factory-method="getRepositoryService" />
<bean id="runtimeService" factory-bean="processEngine"
  factory-method="getRuntimeService" />
<bean id="taskService" factory-bean="processEngine"
  factory-method="getTaskService" />
<bean id="historyService" factory-bean="processEngine"
  factory-method="getHistoryService" />
<bean id="managementService" factory-bean="processEngine"
  factory-method="getManagementService" />
</beans>
</code>
Please guide me running a simple junit class. Many thanks for any help.
frederikherema1
We have JUnit 4.11 as dependency listed in out pom.xml. Try using that one instead
monika_b
I have one more Question.
As suggested we need resource file of form testClassName.testMethod.bpmn20.xml for @Deployment to work within same package as junit class.
If we have service task inside this diagram should it be referring to some test java service task or original service task ?? In this case if we perform some java code will that be reverted back after the junit runs? or please help how it actually works?
Thanks in advance.
monika_b
Thanks fred. It worked like a charm.
But I am trying to integrate activiti with existing WebApplication. It has junit-4.8.1.jar already added. And I am able to run Junit successfully with it if I use JUnit versions 3 styles of unit testing(extending ActivitiTestCase and not using ActivitiRule). Will that be a problem later on for some complex activiti flow?
<b>UserGuide snippet "To get the same functionality when using the JUnit 4 style of writing unit tests, the org.activiti.engine.test.ActivitiRule Rule must be used".</b>
Please suggest either case. Can I use existing junit-4.8.1.jar with junit 3 style of unit testing or should upgrade my junit jars to junit 4.11?(Latter case needs to test entire existing application is a bit of extra work)
Thanks again for help and valuable guidance. *preved* *HELLO* *PREVED* *PRIVET* *HI*
monika_b
I tried using original JavaService class inside testClassName.testMethod.bpmn20.xml with execution.setVariable("JavaActService1", "true"); statement.
It is getting stored in DB though I am running a Junit with @Deployment is not something we expect. Ideally it should delete all process execution/variables/instances.
User Guide Snippet
"Before the test is run, a resource file of the form testClassName.testMethod.bpmn20.xml in the same package as the test class, will be deployed. At the end of the test, the deployment will be deleted, including all related process instances, tasks, etc. "
Please help what is wrong. *secret* :-X :-x X: x: :-# :# :secret:
monika_b
My Junit Test classs:
<code>
@Rule
@Deployment
@Test
     ProcessInstance processInstance = runtimeService.startProcessInstanceByKey("myProcess");
     assertNotNull("ProcessInstance should not be found null", processInstance);
     System.out.println("Completed Test MyProcess Activiti");
</code>
Java service class:
<code>
public class JavaActService1 implements JavaDelegate{
@Override
  System.out.println("Inside JavaActService1 class…");
</code>
My MyProcess.bpmn20.xml file is:
<code><?xml version="1.0" encoding="UTF-8"?>
<definitions xmlns="http://www.omg.org/spec/BPMN/20100524/MODEL" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:activiti="http://activiti.org/bpmn" xmlns:bpmndi="http://www.omg.org/spec/BPMN/20100524/DI" xmlnsSmiley Surprisedmgdc="http://www.omg.org/spec/DD/20100524/DC" xmlnsSmiley Surprisedmgdi="http://www.omg.org/spec/DD/20100524/DI" typeLanguage="http://www.w3.org/2001/XMLSchema" expressionLanguage="http://www.w3.org/1999/XPath" targetNamespace="http://www.activiti.org/test">
    <serviceTask id="servicetask1" name="Service Task" activiti:class="com.activiti.common.JavaActService1"></serviceTask>
  </process>
      </bpmndi:BPMNShape>
      </bpmndi:BPMNShape>
      </bpmndi:BPMNShape>
      </bpmndi:BPMNEdge>
      </bpmndi:BPMNEdge>
    </bpmndi:BPMNPlane>
</definitions>
</code>
Question: Do I need to manually create TestMyProcess.testMyProcess.bpmn20.xml  inside same package of junit or will autocreated by @Deployment. In either case, I dont expect Process Execution/instances/variables getting stored in ACT_* tables. But it is getting stored in both cases for me.
Please guide further what I m missing in this.
Thanks in advance,
Monika
trademak
You need to create TestMyProcess.testMyProcess.bpmn20.xml yourself in the same package. Or you can define the resource you want to deploy in the resources property of the @Deployment annotation. Why would you expect that nothing is store in the ACT_* tables? Running it in a unit test doesn't mean it will not get stored in the database.
If you want to rollback the transaction after your test run, you can use Spring transaction for example. We use that in our activiti-spring unit tests as well.
Best regards,
monika_b
Thanks for the help.
But Please would you elaborate how to rollback junit changes. I dont want to gets anything stored permanently on ACT_* DB on running junits.
My activiti.cfg.xml file is quite simple as below:
<code>
  class="org.activiti.engine.impl.cfg.StandaloneProcessEngineConfiguration">
  <property name="jdbcUrl"
   value="jdbcSmiley Surprisedracle:thin:@(DESCRIPTION =(ADDRESS_LIST=(ADDRESS = (PROTOCOL = TCP)(HOST = myIpAddress)(PORT = myPortNo)))(CONNECT_DATA =(SERVER = DEDICATED)(SID = mySID)))" />
  <property name="jdbcDriver" value="oracle.jdbc.driver.OracleDriver" />
  <property name="jdbcUsername" value="abc" />
  <property name="jdbcPassword" value="abc123" />
  <property name="history" value="activity" />
  <property name="customPostDeployers">
   <list>
    <bean class="org.activiti.engine.impl.rules.RulesDeployer" />
   </list>
  </property>
</bean>
</beans>
</code>
And I am creating the processEngine using stmt as: (note, this stmt is not kept inside JUnit and not related with junit at all)
processEngine = ProcessEngineConfiguration.createProcessEngineConfigurationFromResourceDefault().buildProcessEngine();
Please help how to use rollback my junit transactions in tihs case.
Thanks again for any help.
monika_b
Hey Thanks. I am able to get it inserted and rollbacked itself. I was missing few things like.
As suggested by Trade,
Name the process name as 'TestMyProcess' different from your real bpmn20.xml file.
Thanks a ton for helping a newbie in activiti.
