> Re: Problem in Web Project link.
> Sent at: Tue Sep 09, 2008 4:13 am
> From: jack786
> hi janv,
> I am Using Alfresco 2.0 version . There is no utility Web Project link in 2.0.
I'm not sure I understand your issue. Please add more details about your environment (and test steps) including an extract from your startup log showing Alfresco version/build etc. Have you already installed and enabled the Alfresco WCM package ? If not, then you should first consider upgrading to Alfresco 2.1 or higher.
Regards,
Jan
