problem in Jboss
biswajit
I have followed http://wiki.alfresco.com/wiki/Alfresco_on_JBoss to deploy alfresco in jboss.but its not started and give 404 error.My alfresco log file is:
16:14:25,921 ERROR [org.alfresco.repo.content.transform.magick.AbstractImageMagickContentTransformer] ImageMagickContentTransformer not available: Failed to perform ImageMagick transformation:
Execution result:
   os:         Windows XP
   command:    imconvert "C:\DOCUME~1\Biswajit\LOCALS~1\Temp\Alfresco\ImageMagickContentTransformer_init_source_40377.gif"  "C:\DOCUME~1\Biswajit\LOCALS~1\Temp\Alfresco\ImageMagickContentTransformer_init_target_40378.png"
   succeeded:  false
   exit code:  1
   out:
   err:        CreateProcess: imconvert "C:\DOCUME~1\Biswajit\LOCALS~1\Temp\Alfresco\ImageMagickContentTransformer_init_source_40377.gif" "C:\DOCUME~1\Biswajit\LOCALS~1\Temp\Alfresco\ImageMagickContentTransformer_init_target_40378.png" error=2
16:14:29,593 WARN  [org.springframework.remoting.rmi.RmiRegistryFactoryBean] Could not detect RMI registry - creating new one
16:14:32,015 WARN  [org.alfresco.util.OpenOfficeConnectionTester] A connection to OpenOffice could not be established.
16:14:36,640 INFO  [org.alfresco.repo.domain.schema.SchemaBootstrap] Schema managed by database dialect org.hibernate.dialect.MySQLInnoDBDialect.
16:14:38,390 INFO  [org.alfresco.repo.domain.schema.SchemaBootstrap] No changes were made to the schema.
16:14:40,156 WARN  [org.alfresco.repo.admin.ConfigurationChecker] The Alfresco 'dir.root' property is set to a relative path '.jboss-4.2.2.GAbinalf_data'.  'dir.root' should be overridden to point to a specific folder.
16:14:40,156 INFO  [org.alfresco.repo.admin.ConfigurationChecker] The Alfresco root data directory ('dir.root') is: .jboss-4.2.2.GAbinalf_data
16:14:40,281 ERROR [org.alfresco.repo.admin.ConfigurationChecker] CONTENT INTEGRITY ERROR: Indexes not found for 5 stores.
16:14:40,281 INFO  [org.alfresco.repo.admin.ConfigurationChecker] You may set 'index.recovery.mode=FULL' if you need to rebuild the indexes.
16:14:40,281 ERROR [org.alfresco.repo.admin.ConfigurationChecker] CONTENT INTEGRITY ERROR: System content not found in content store.
16:14:40,281 ERROR [org.alfresco.repo.admin.ConfigurationChecker] Ensure that the 'dir.root' property is pointing to the correct data location.
16:14:40,296 ERROR [org.springframework.web.context.ContextLoader] Context initialization failed
org.alfresco.error.AlfrescoRuntimeException: Ensure that the 'dir.root' property is pointing to the correct data location.
   at org.alfresco.repo.admin.ConfigurationChecker.check(ConfigurationChecker.java:312)
   at org.alfresco.repo.admin.ConfigurationChecker.access$000(ConfigurationChecker.java:72)
   at org.alfresco.repo.admin.ConfigurationChecker$1.execute(ConfigurationChecker.java:178)
   at org.alfresco.repo.transaction.RetryingTransactionHelper.doInTransaction(RetryingTransactionHelper.java:225)
   at org.alfresco.repo.transaction.RetryingTransactionHelper.doInTransaction(RetryingTransactionHelper.java:155)
   at org.alfresco.repo.admin.ConfigurationChecker.onBootstrap(ConfigurationChecker.java:182)
   at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:3856)
   at org.apache.catalina.core.StandardContext.start(StandardContext.java:4361)
   at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:790)
   at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:770)
   at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:553)
   at org.apache.tomcat.util.modeler.BaseModelMBean.invoke(BaseModelMBean.java:296)
   at org.jboss.mx.server.RawDynamicInvoker.invoke(RawDynamicInvoker.java:164)
   at org.jboss.mx.server.MBeanServerImpl.invoke(MBeanServerImpl.java:659)
   at org.apache.catalina.core.StandardContext.init(StandardContext.java:5312)
   at org.jboss.web.tomcat.service.TomcatDeployer.performDeployInternal(TomcatDeployer.java:301)
   at org.jboss.web.tomcat.service.TomcatDeployer.performDeploy(TomcatDeployer.java:104)
   at org.jboss.web.AbstractWebDeployer.start(AbstractWebDeployer.java:375)
   at org.jboss.web.WebModule.startModule(WebModule.java:83)
   at org.jboss.web.WebModule.startService(WebModule.java:61)
   at org.jboss.system.ServiceMBeanSupport.jbossInternalStart(ServiceMBeanSupport.java:289)
   at org.jboss.system.ServiceMBeanSupport.jbossInternalLifecycle(ServiceMBeanSupport.java:245)
   at sun.reflect.GeneratedMethodAccessor3.invoke(Unknown Source)
   at org.jboss.mx.interceptor.ReflectedDispatcher.invoke(ReflectedDispatcher.java:155)
   at org.jboss.mx.server.Invocation.dispatch(Invocation.java:94)
   at org.jboss.mx.server.Invocation.invoke(Invocation.java:86)
   at org.jboss.mx.server.AbstractMBeanInvoker.invoke(AbstractMBeanInvoker.java:264)
   at org.jboss.system.ServiceController$ServiceProxy.invoke(ServiceController.java:978)
   at $Proxy0.start(Unknown Source)
   at org.jboss.system.ServiceController.start(ServiceController.java:417)
   at sun.reflect.GeneratedMethodAccessor9.invoke(Unknown Source)
   at org.jboss.mx.util.MBeanProxyExt.invoke(MBeanProxyExt.java:210)
   at $Proxy44.start(Unknown Source)
   at org.jboss.web.AbstractWebContainer.start(AbstractWebContainer.java:466)
   at org.jboss.mx.interceptor.AbstractInterceptor.invoke(AbstractInterceptor.java:133)
   at org.jboss.mx.server.Invocation.invoke(Invocation.java:88)
   at org.jboss.mx.interceptor.ModelMBeanOperationInterceptor.invoke(ModelMBeanOperationInterceptor.java:142)
   at org.jboss.mx.interceptor.DynamicInterceptor.invoke(DynamicInterceptor.java:97)
   at org.jboss.system.InterceptorServiceMBeanSupport.invokeNext(InterceptorServiceMBeanSupport.java:238)
   at org.jboss.wsf.container.jboss42.DeployerInterceptor.start(DeployerInterceptor.java:87)
   at org.jboss.deployment.SubDeployerInterceptorSupport$XMBeanInterceptor.start(SubDeployerInterceptorSupport.java:188)
   at org.jboss.deployment.SubDeployerInterceptor.invoke(SubDeployerInterceptor.java:95)
   at $Proxy45.start(Unknown Source)
   at org.jboss.deployment.MainDeployer.start(MainDeployer.java:1025)
   at org.jboss.deployment.MainDeployer.deploy(MainDeployer.java:819)
   at org.jboss.deployment.MainDeployer.deploy(MainDeployer.java:782)
   at sun.reflect.GeneratedMethodAccessor20.invoke(Unknown Source)
   at $Proxy9.deploy(Unknown Source)
   at org.jboss.deployment.scanner.URLDeploymentScanner.deploy(URLDeploymentScanner.java:421)
   at org.jboss.deployment.scanner.URLDeploymentScanner.scan(URLDeploymentScanner.java:634)
   at org.jboss.deployment.scanner.AbstractDeploymentScanner$ScannerThread.doScan(AbstractDeploymentScanner.java:263)
   at org.jboss.deployment.scanner.AbstractDeploymentScanner.startService(AbstractDeploymentScanner.java:336)
   at $Proxy4.start(Unknown Source)
   at org.jboss.deployment.SARDeployer.start(SARDeployer.java:302)
   at org.jboss.deployment.MainDeployer.deploy(MainDeployer.java:766)
   at $Proxy5.deploy(Unknown Source)
   at org.jboss.system.server.ServerImpl.doStart(ServerImpl.java:482)
   at org.jboss.system.server.ServerImpl.start(ServerImpl.java:362)
   at org.jboss.Main.boot(Main.java:200)
   at org.jboss.Main$1.run(Main.java:508)
I cant understand what it is.Please help me.
dward
It looks like you haven't escaped backslash characters when you set dir.root. In java .properties files the backslash character must be escaped with another backslash, or you can use a slash character '/' instead. E.g.
dir.root=C:\\jboss-4.2.2.GA\\bin\\alf_data
However, I don't think you you should put your Alfresco content in the JBoss bin directory!
biswajit
Thanks but i have done this .I have put dir.root=C:\\jboss-4.2.2.GA\\bin\\alf_data in repository.properties file which is in alfresco.war->WEb-INF->classes->alfresco->repository.properties.but the error remain same
dward
That's not where to put property overrides. You are modifying the source of the product itself and any changes you make will be wiped out the next time you deploy a .war file.
If you are using v3.2 your property overrides go in alfresco-global.properties, which should be at the root of your app server's global classpath. On JBoss, I think this is
jboss\server\default\conf
See http://wiki.alfresco.com/wiki/Repository_Configuration#alfresco-global.properties_.28V3.2.2B.29
Please start again with a fresh .war file and database and make all your configuration changes in alfresco-global.properties.
