1) I am trying to deploy alfresco.war got from jbos bundled in liferay using ant build file. It deployed successfully. it created a folder by name 1alfresco in the deploy folder of liferay.
2) when i start liferay it is showing error as
10:54:24,827 INFO [[/alfresco]] Loading Spring root WebApplicationContext
10:54:28,749 ERROR [XMLHelper] Error parsing XML: XML InputStream(33) Attribute "lazy" with value "no-proxy" must have a value from the list "true false proxy ".
10:54:28,764 ERROR [XMLHelper] Error parsing XML: XML InputStream(89) Attribute "lazy" with value "no-proxy" must have a value from the list "true false proxy ".
10:54:28,780 ERROR [ContextLoader] Context initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'descriptorComponent' defined in class path resource [alfresco/application-context.xml]: Can't resolve reference to bean 'systemBootstrap' while sett
amework.beans.factory.BeanCreationException: Error creating bean with name 'nodeIndexer' defined in class path resource [alfresco/node-services-context.xml]: Can't resolve reference to bean 'indexerComponent' while setting property 'ind
nCreationException: Error creating bean with name 'org.alfresco.repo.search.IndexerComponent#1fd4a63' defined in class path resource [alfresco/application-context.xml]: Can't resolve reference to bean 'indexerAndSearcherFactory' while s
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'indexerAndSearcherFactory' defined in class path resource [alfresco/application-context.xml]: Can't resolve reference to bean 'luceneIndexerAndSear
eption is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'luceneIndexerAndSearcherFactory' defined in class path resource [alfresco/application-context.xml]: Can't resolve reference to bean 'nodeS
s org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'nodeService' defined in class path resource [alfresco/node-services-context.xml]: Can't resolve reference to bean 'dbNodeService' while setting pr
.beans.factory.BeanCreationException: Error creating bean with name 'org.alfresco.repo.node.db.DbNodeServiceImpl#f229cd' defined in class path resource [alfresco/node-services-context.xml]: Can't resolve reference to bean 'nodeDaoServic
on is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'nodeDaoService' defined in class path resource [alfresco/node-services-context.xml]: Can't resolve reference to bean 'nodeDaoServiceImpl' whil
work.beans.factory.BeanCreationException: Error creating bean with name 'nodeDaoServiceImpl' defined in class path resource [alfresco/node-services-context.xml]: Can't resolve reference to bean 'sessionFactory' while setting property 's
ctory.BeanCreationException: Error creating bean with name 'sessionFactory' defined in class path resource [alfresco/hibernate-context.xml]: Initialization of bean failed; nested exception is org.hibernate.MappingException: invalid mapp
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'nodeIndexer' defined in class path resource [alfresco/node-services-context.xml]: Can't resolve reference to bean 'indexerComponent' while setting p
.factory.BeanCreationException: Error creating bean with name 'org.alfresco.repo.search.IndexerComponent#1fd4a63' defined in class path resource [alfresco/application-context.xml]: Can't resolve reference to bean 'indexerAndSearcherFact
exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'indexerAndSearcherFactory' defined in class path resource [alfresco/application-context.xml]: Can't resolve reference to bean 'luceneIn
; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'luceneIndexerAndSearcherFactory' defined in class path resource [alfresco/application-context.xml]: Can't resolve reference to
exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'nodeService' defined in class path resource [alfresco/node-services-context.xml]: Can't resolve reference to bean 'dbNodeService' whil
ingframework.beans.factory.BeanCreationException: Error creating bean with name 'org.alfresco.repo.node.db.DbNodeServiceImpl#f229cd' defined in class path resource [alfresco/node-services-context.xml]: Can't resolve reference to bean 'n
sted exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'nodeDaoService' defined in class path resource [alfresco/node-services-context.xml]: Can't resolve reference to bean 'nodeDaoServi
.springframework.beans.factory.BeanCreationException: Error creating bean with name 'nodeDaoServiceImpl' defined in class path resource [alfresco/node-services-context.xml]: Can't resolve reference to bean 'sessionFactory' while setting
ork.beans.factory.BeanCreationException: Error creating bean with name 'sessionFactory' defined in class path resource [alfresco/hibernate-context.xml]: Initialization of bean failed; nested exception is org.hibernate.MappingException:
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'org.alfresco.repo.search.IndexerComponent#1fd4a63' defined in class path resource [alfresco/application-context.xml]: Can't resolve reference to bea
SearcherFactory'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'indexerAndSearcherFactory' defined in class path resource [alfresco/application-context.xml]: Can't resolve re
property 'defaultBinding'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'luceneIndexerAndSearcherFactory' defined in class path resource [alfresco/application-context.xml]: C
rty 'nodeService'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'nodeService' defined in class path resource [alfresco/node-services-context.xml]: Can't resolve reference to
sted exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'org.alfresco.repo.node.db.DbNodeServiceImpl#f229cd' defined in class path resource [alfresco/node-services-context.xml]: Can't res
constructor argument'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'nodeDaoService' defined in class path resource [alfresco/node-services-context.xml]: Can't resolve refere
; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'nodeDaoServiceImpl' defined in class path resource [alfresco/node-services-context.xml]: Can't resolve reference to bean 'sess
ption is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'sessionFactory' defined in class path resource [alfresco/hibernate-context.xml]: Initialization of bean failed; nested exception is org.hib
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'indexerAndSearcherFactory' defined in class path resource [alfresco/application-context.xml]: Can't resolve reference to bean 'luceneIndexerAndSearc
ption is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'luceneIndexerAndSearcherFactory' defined in class path resource [alfresco/application-context.xml]: Can't resolve reference to bean 'nodeSe
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'nodeService' defined in class path resource [alfresco/node-services-context.xml]: Can't resolve reference to bean 'dbNodeService' while setting pro
beans.factory.BeanCreationException: Error creating bean with name 'org.alfresco.repo.node.db.DbNodeServiceImpl#f229cd' defined in class path resource [alfresco/node-services-context.xml]: Can't resolve reference to bean 'nodeDaoService
n is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'nodeDaoService' defined in class path resource [alfresco/node-services-context.xml]: Can't resolve reference to bean 'nodeDaoServiceImpl' while
ork.beans.factory.BeanCreationException: Error creating bean with name 'nodeDaoServiceImpl' defined in class path resource [alfresco/node-services-context.xml]: Can't resolve reference to bean 'sessionFactory' while setting property 'se
tory.BeanCreationException: Error creating bean with name 'sessionFactory' defined in class path resource [alfresco/hibernate-context.xml]: Initialization of bean failed; nested exception is org.hibernate.MappingException: invalid mappi
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'luceneIndexerAndSearcherFactory' defined in class path resource [alfresco/application-context.xml]: Can't resolve reference to bean 'nodeService' wh
ngframework.beans.factory.BeanCreationException: Error creating bean with name 'nodeService' defined in class path resource [alfresco/node-services-context.xml]: Can't resolve reference to bean 'dbNodeService' while setting property 'de
tory.BeanCreationException: Error creating bean with name 'org.alfresco.repo.node.db.DbNodeServiceImpl#f229cd' defined in class path resource [alfresco/node-services-context.xml]: Can't resolve reference to bean 'nodeDaoService' while s
springframework.beans.factory.BeanCreationException: Error creating bean with name 'nodeDaoService' defined in class path resource [alfresco/node-services-context.xml]: Can't resolve reference to bean 'nodeDaoServiceImpl' while setting
.factory.BeanCreationException: Error creating bean with name 'nodeDaoServiceImpl' defined in class path resource [alfresco/node-services-context.xml]: Can't resolve reference to bean 'sessionFactory' while setting property 'sessionFact
CreationException: Error creating bean with name 'sessionFactory' defined in class path resource [alfresco/hibernate-context.xml]: Initialization of bean failed; nested exception is org.hibernate.MappingException: invalid mapping
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'nodeService' defined in class path resource [alfresco/node-services-context.xml]: Can't resolve reference to bean 'dbNodeService' while setting prop
eans.factory.BeanCreationException: Error creating bean with name 'org.alfresco.repo.node.db.DbNodeServiceImpl#f229cd' defined in class path resource [alfresco/node-services-context.xml]: Can't resolve reference to bean 'nodeDaoService'
rk.beans.factory.BeanCreationException: Error creating bean with name 'nodeDaoServiceImpl' defined in class path resource [alfresco/node-services-context.xml]: Can't resolve reference to bean 'sessionFactory' while setting property 'ses
ory.BeanCreationException: Error creating bean with name 'sessionFactory' defined in class path resource [alfresco/hibernate-context.xml]: Initialization of bean failed; nested exception is org.hibernate.MappingException: invalid mappin
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'org.alfresco.repo.node.db.DbNodeServiceImpl#f229cd' defined in class path resource [alfresco/node-services-context.xml]: Can't resolve reference to
nt'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'nodeDaoService' defined in class path resource [alfresco/node-services-context.xml]: Can't resolve reference to bean 'nodeD
is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'nodeDaoServiceImpl' defined in class path resource [alfresco/node-services-context.xml]: Can't resolve reference to bean 'sessionFactory' while
gframework.beans.factory.BeanCreationException: Error creating bean with name 'sessionFactory' defined in class path resource [alfresco/hibernate-context.xml]: Initialization of bean failed; nested exception is org.hibernate.MappingExce
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'nodeDaoService' defined in class path resource [alfresco/node-services-context.xml]: Can't resolve reference to bean 'nodeDaoServiceImpl' while sett
eans.factory.BeanCreationException: Error creating bean with name 'nodeDaoServiceImpl' defined in class path resource [alfresco/node-services-context.xml]: Can't resolve reference to bean 'sessionFactory' while setting property 'session
BeanCreationException: Error creating bean with name 'sessionFactory' defined in class path resource [alfresco/hibernate-context.xml]: Initialization of bean failed; nested exception is org.hibernate.MappingException: invalid mapping
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'nodeDaoServiceImpl' defined in class path resource [alfresco/node-services-context.xml]: Can't resolve reference to bean 'sessionFactory' while sett
mework.beans.factory.BeanCreationException: Error creating bean with name 'sessionFactory' defined in class path resource [alfresco/hibernate-context.xml]: Initialization of bean failed; nested exception is org.hibernate.MappingExceptio
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'sessionFactory' defined in class path resource [alfresco/hibernate-context.xml]: Initialization of bean failed; nested exception is org.hibernate.Ma
at org.hibernate.cfg.Configuration.addInputStream(Configuration.java:399)
at org.springframework.orm.hibernate3.LocalSessionFactoryBean.afterPropertiesSet(LocalSessionFactoryBean.java:621)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1003)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:348)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:226)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:147)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:176)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:105)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:957)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:768)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:330)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.resolveConstructorArguments(AbstractAutowireCapableBeanFactory.java:658)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:556)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:312)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveInnerBeanDefinition(BeanDefinitionValueResolver.java:147)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:96)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:295)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.getBeansOfType(DefaultListableBeanFactory.java:203)
at org.springframework.context.support.AbstractApplicationContext.getBeansOfType(AbstractApplicationContext.java:607)
at org.springframework.context.support.AbstractApplicationContext.registerListeners(AbstractApplicationContext.java:489)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:314)
at org.springframework.web.context.support.AbstractRefreshableWebApplicationContext.refresh(AbstractRefreshableWebApplicationContext.java:134)
at org.springframework.web.context.ContextLoader.createWebApplicationContext(ContextLoader.java:230)
at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:156)
at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:48)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:3669)
at org.apache.catalina.core.StandardContext.start(StandardContext.java:4104)
at org.apache.commons.modeler.BaseModelMBean.invoke(BaseModelMBean.java:503)
at org.jboss.mx.server.RawDynamicInvoker.invoke(RawDynamicInvoker.java:150)
at org.jboss.mx.server.MBeanServerImpl.invoke(MBeanServerImpl.java:644)
at org.apache.catalina.core.StandardContext.init(StandardContext.java:5005)
at org.jboss.web.tomcat.tc5.TomcatDeployer.performDeployInternal(TomcatDeployer.java:274)
at org.jboss.web.tomcat.tc5.TomcatDeployer.performDeploy(TomcatDeployer.java:91)
at org.jboss.web.AbstractWebDeployer.start(AbstractWebDeployer.java:357)
at org.jboss.web.WebModule.startModule(WebModule.java:68)
at org.jboss.web.WebModule.startService(WebModule.java:46)
at org.jboss.system.ServiceMBeanSupport.jbossInternalStart(ServiceMBeanSupport.java:272)
at org.jboss.system.ServiceMBeanSupport.jbossInternalLifecycle(ServiceMBeanSupport.java:222)
at org.jboss.mx.interceptor.ReflectedDispatcher.invoke(ReflectedDispatcher.java:141)
at org.jboss.mx.server.Invocation.dispatch(Invocation.java:80)
at org.jboss.mx.server.Invocation.invoke(Invocation.java:72)
at org.jboss.mx.server.AbstractMBeanInvoker.invoke(AbstractMBeanInvoker.java:249)
at org.jboss.system.ServiceController$ServiceProxy.invoke(ServiceController.java:897)
at $Proxy0.start(Unknown Source)
at org.jboss.system.ServiceController.start(ServiceController.java:418)
at sun.reflect.GeneratedMethodAccessor8.invoke(Unknown Source)
at org.jboss.mx.util.MBeanProxyExt.invoke(MBeanProxyExt.java:177)
at $Proxy28.start(Unknown Source)
at org.jboss.web.AbstractWebContainer.start(AbstractWebContainer.java:394)
at org.jboss.deployment.MainDeployer.start(MainDeployer.java:964)
at org.jboss.deployment.MainDeployer.deploy(MainDeployer.java:775)
at org.jboss.deployment.MainDeployer.deploy(MainDeployer.java:738)
at sun.reflect.GeneratedMethodAccessor45.invoke(Unknown Source)
at org.jboss.mx.interceptor.AbstractInterceptor.invoke(AbstractInterceptor.java:121)
at org.jboss.mx.server.Invocation.invoke(Invocation.java:74)
at org.jboss.mx.interceptor.ModelMBeanOperationInterceptor.invoke(ModelMBeanOperationInterceptor.java:127)
at $Proxy8.deploy(Unknown Source)
at org.jboss.deployment.scanner.URLDeploymentScanner.deploy(URLDeploymentScanner.java:325)
at org.jboss.deployment.scanner.URLDeploymentScanner.scan(URLDeploymentScanner.java:501)
at org.jboss.deployment.scanner.AbstractDeploymentScanner$ScannerThread.doScan(AbstractDeploymentScanner.java:204)
at org.jboss.deployment.scanner.AbstractDeploymentScanner.startService(AbstractDeploymentScanner.java:277)
at sun.reflect.GeneratedMethodAccessor7.invoke(Unknown Source)
can any one of you help me regarding this.
please reply asap.
Thanks in Advance
vijay
