Thanks for your immediate reply mrogers….
I think you are correct… because when I typed netstat -a in cmd prompt, I cant see the port 44100 listening. But 50500 port is there. So it seems RMI port is not open..
For your question, there is no such "logs" folder inside deployment directory (sorry for repeating again). As said above I had installed
(1) Alfresco-Community-3.3g-Full-Setup.exe (C:\Alfresco)
(2) Alfresco-DeploymentCommunity-3.3g-Setup.exe (since Standalone Deployment Receiver was not installed after the complete setup, I had installed this in —> C:\Alfresco\Deployment)
When I searched for *.log files (in whole alfresco), I can see them only in tomcat and virtual tomcat folder.
And the logs folder exists only in tomcat and virtual tomcat.
In C:\Alfresco\Deployment, I can see only two files regarding logs. They are:
(1) log4j.property
(2) log4j-1.2.15 (jar file)
Do I need to create the logs folder manually or do I need to install any other .exe??
