Payload not being passed when using vertical/horizontal widget
anand_mohan
I am having issues in payload being passed from dialog box to the service subscribing it.
When I use a vertical widget and text box inside it, the payload does not have text box element value in service js but when I just use a text box (no vertical widget), the payload passes fine the value in text box. Below is the code for both. Could you please advise what am I missing?
With Vertical Widget:
var nodeRef = page.url.args.nodeRef;
model.jsonModel = {
services: [
"alfresco/services/CrudService",
"alfresco/services/DialogService",
"example/widgets/EditAssetService"
widgets: [{
config: {
title: "Edit Asset Input"
config: {
label: "Edit Asset Property",
publishTopic: "ALF_CREATE_FORM_DIALOG_REQUEST",
publishPayloadType: "PROCESS",
publishPayloadModifiers: ["processCurrentItemTokens"],
publishPayload: {
dialogTitle: "Edit Asset Property",
dialogConfirmationButtonTitle: "Save",
dialogCancellationButtonTitle: "Cancel",
fixedWidth: true,
formSubmissionTopic: "EDIT_ASSET_PROPERTY",
widgets: [
config: {
widgetMarginTop: "20",
widgetMarginBottom: "20",
widgets: [
config: {
fieldId: "Asset name",
label: "Name:",
requirementConfig: {
initialValue: true
style: {
marginLeft: "10px"
Without Vertical Widget:
model.jsonModel = {
services: [
widgets: [{
config: {
config: {
publishPayload: {
fixedWidth: true,
widgets: [
config: {
label: "Name:",
initialValue: true
style: {
marginLeft: "10px"
anand_mohan
I got the resolution. I have to use ControlRow widget to get the data pass to payload object. So I wrapped all elements in multiple control rows and it passes on the values to payload. Most probably horizontal and vertical widgets do not work with payload.
