org.activiti.engine.impl.interceptor.CommandContext close
sonam
I am working on BookOrderTest.java with a connection to localhost database. The following is my code:
public class BookOrderTest {
   private Logger logger = LoggerFactory.getLogger(getClass());
   @Test
   public void startBookOrder() {
      logger.info("creating processEngine");
      ProcessEngine processEngine = ProcessEngineConfiguration
            .createStandaloneProcessEngineConfiguration().setJdbcDriver("org.h2.Driver").setDatabaseType("h2").
            setJdbcUrl("jdbc:h2:tcp://localhost/activiti")
            .setJdbcUsername("sa").setJdbcPassword("")
            .buildProcessEngine();
However, I keep getting the following error:
09 Oct 2014 09:59:54,589 [main] DEBUG org.apache.ibatis.logging.slf4j.Slf4jImpl:28 - PooledDataSource forcefully closed/removed all connections.
Oct 09, 2014 9:59:55 AM org.activiti.engine.impl.interceptor.CommandContext close
SEVERE: Error while closing command context
org.apache.ibatis.exceptions.PersistenceException:
### Error opening session.  Cause: org.h2.jdbc.JdbcSQLException: Database is already closed (to disable automatic closing at VM shutdown, add ";DB_CLOSE_ON_EXIT=FALSE" to the db URL) [90121-132]
### The error may exist in org/activiti/db/mapping/entity/EventSubscription.xml
### The error occurred while processing mapper_resultMap[compensateResultMap]
### Cause: org.h2.jdbc.JdbcSQLException: Database is already closed (to disable automatic closing at VM shutdown, add ";DB_CLOSE_ON_EXIT=FALSE" to the db URL) [90121-132]
   at org.apache.ibatis.exceptions.ExceptionFactory.wrapException(ExceptionFactory.java:8)
   at org.apache.ibatis.session.defaults.DefaultSqlSessionFactory.openSessionFromDataSource(DefaultSqlSessionFactory.java:83)
   at org.apache.ibatis.session.defaults.DefaultSqlSessionFactory.openSession(DefaultSqlSessionFactory.java:32)
   at org.activiti.engine.impl.db.DbSqlSession.<init>(DbSqlSession.java:86)
   at org.activiti.engine.impl.db.DbSqlSessionFactory.openSession(DbSqlSessionFactory.java:80)
   at org.activiti.engine.impl.interceptor.CommandContext.getSession(CommandContext.java:179)
   at org.activiti.engine.impl.SchemaOperationsProcessEngineBuild.execute(SchemaOperationsProcessEngineBuild.java:25)
   at org.activiti.engine.impl.interceptor.CommandExecutorImpl.execute(CommandExecutorImpl.java:24)
   at org.activiti.engine.impl.interceptor.CommandContextInterceptor.execute(CommandContextInterceptor.java:42)
   at org.activiti.engine.impl.ProcessEngineImpl.<init>(ProcessEngineImpl.java:77)
   at org.activiti.engine.impl.cfg.ProcessEngineConfigurationImpl.buildProcessEngine(ProcessEngineConfigurationImpl.java:283)
   at org.bpmnwithactiviti.chapter1.BookOrderTest.startBookOrder(BookOrderTest.java:35)
   at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:44)
   at org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCallable.java:15)
   at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:41)
   at org.junit.internal.runners.statements.InvokeMethod.evaluate(InvokeMethod.java:20)
   at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:76)
   at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:50)
   at org.junit.runners.ParentRunner$3.run(ParentRunner.java:193)
   at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:52)
   at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:191)
   at org.junit.runners.ParentRunner.access$000(ParentRunner.java:42)
   at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:184)
   at org.junit.runners.ParentRunner.run(ParentRunner.java:236)
   at org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.run(JUnit4TestReference.java:50)
   at org.eclipse.jdt.internal.junit.runner.TestExecution.run(TestExecution.java:38)
   at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:459)
   at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:675)
   at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(RemoteTestRunner.java:382)
   at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main(RemoteTestRunner.java:192)
Caused by: org.h2.jdbc.JdbcSQLException: Database is already closed (to disable automatic closing at VM shutdown, add ";DB_CLOSE_ON_EXIT=FALSE" to the db URL) [90121-132]
   at org.h2.message.DbException.getJdbcSQLException(DbException.java:316)
   at org.h2.message.DbException.get(DbException.java:167)
   at org.h2.message.DbException.get(DbException.java:144)
   at org.h2.message.DbException.get(DbException.java:133)
   at org.h2.jdbc.JdbcConnection.checkClosed(JdbcConnection.java:1347)
   at org.h2.jdbc.JdbcConnection.checkClosed(JdbcConnection.java:1322)
   at org.h2.jdbc.JdbcConnection.getAutoCommit(JdbcConnection.java:385)
   at org.apache.ibatis.datasource.unpooled.UnpooledDataSource.configureConnection(UnpooledDataSource.java:159)
   at org.apache.ibatis.datasource.unpooled.UnpooledDataSource.getConnection(UnpooledDataSource.java:66)
   at org.apache.ibatis.datasource.pooled.PooledDataSource.popConnection(PooledDataSource.java:349)
   at org.apache.ibatis.datasource.pooled.PooledDataSource.getConnection(PooledDataSource.java:55)
   at org.apache.ibatis.session.defaults.DefaultSqlSessionFactory.openSessionFromDataSource(DefaultSqlSessionFactory.java:73)
   … 33 more
Oct 09, 2014 9:59:55 AM org.activiti.engine.impl.cfg.standalone.StandaloneMybatisTransactionContext rollback
INFO: Exception during transaction:
### Error opening session.  Cause: org.h2.jdbc.JdbcSQLException: Connection is broken: "session closed" [90067-132]
### Cause: org.h2.jdbc.JdbcSQLException: Connection is broken: "session closed" [90067-132]
Oct 09, 2014 9:59:55 AM org.activiti.engine.impl.interceptor.CommandContext exception
SEVERE: masked exception in command context. for root cause, see below as it will be rethrown later.
   at org.activiti.engine.impl.cfg.standalone.StandaloneMybatisTransactionContext.getDbSqlSession(StandaloneMybatisTransactionContext.java:77)
   at org.activiti.engine.impl.cfg.standalone.StandaloneMybatisTransactionContext.rollback(StandaloneMybatisTransactionContext.java:91)
   at org.activiti.engine.impl.interceptor.CommandContext.close(CommandContext.java:122)
   at org.activiti.engine.impl.interceptor.CommandContextInterceptor.execute(CommandContextInterceptor.java:49)
Caused by: org.h2.jdbc.JdbcSQLException: Connection is broken: "session closed" [90067-132]
   at org.h2.engine.SessionRemote.checkClosed(SessionRemote.java:447)
   at org.h2.engine.SessionRemote.removeServer(SessionRemote.java:394)
   at org.h2.command.CommandRemote.prepare(CommandRemote.java:87)
   at org.h2.command.CommandRemote.<init>(CommandRemote.java:48)
   at org.h2.engine.SessionRemote.prepareCommand(SessionRemote.java:401)
   at org.h2.jdbc.JdbcConnection.prepareCommand(JdbcConnection.java:1074)
   at org.h2.jdbc.JdbcConnection.getInternalAutoCommit(JdbcConnection.java:394)
   at org.h2.jdbc.JdbcConnection.getAutoCommit(JdbcConnection.java:387)
   … 34 more
I checked to ensure my H2 database is running locally.
How can I manually create a ProcessEngineConfiguration that connects to a remote H2 database?
I am using activiti-engine 5.9 version of jar.
thanks
-Sonam
10 REPLIES 10
joanna
Hi, I had the same problem and indeed the version of H2 does matter. I installed the latest non-stable version initially and after unistalling it and installing the 1.3.176 the connection was finally established. Many thanks for help
