org.activiti.engine.ActivitiObjectNotFoundException: no processes deployed with key 'financialReport'
erzuomao
I am a Novice, I Encountered a problem when running the user guide's example.
1. Here is the test code
public static void main(String args[]){
// Create Activiti process engine
ProcessEngine processEngine = ProcessEngineConfiguration
.createProcessEngineConfigurationFromResource("activiti.cfg.xml")
.buildProcessEngine();
// Get Activiti services
RepositoryService repositoryService = processEngine.getRepositoryService();
RuntimeService runtimeService = processEngine.getRuntimeService();
// Deploy the process definition
repositoryService.createDeployment()
.addClasspathResource("test/NewFile.xml")
.deploy();
// Start a process instance
runtimeService.startProcessInstanceByKey("financialReport");
2.Here is the configure file
<definitions id="definitions" targetNamespace="http://activiti.org/bpmn20"
   xmlns:activiti="http://activiti.org/bpmn" xmlns:bpmndi="http://www.omg.org/spec/BPMN/20100524/DI"
   xmlnsSmiley Surprisedmgdc="http://www.omg.org/spec/DD/20100524/DC" xmlnsSmiley Surprisedmgdi="http://www.omg.org/spec/DD/20100524/DI"
   xmlns="http://www.omg.org/spec/BPMN/20100524/MODEL">
   <process id="financialReport" name="Monthly financial report process">
      <startEvent id="theStart" />
      <sequenceFlow id="flow1" sourceRef="theStart" targetRef="writeReportTask" />
      <userTask id="writeReportTask" name="Write monthly financial report">
         <documentation>Write monthly financial report for publication to
            shareholders.</documentation>
         <potentialOwner>
            <resourceAssignmentExpression>
               <formalExpression>accountancy</formalExpression>
            </resourceAssignmentExpression>
         </potentialOwner>
      </userTask>
      <sequenceFlow id="flow2" sourceRef="writeReportTask"
         targetRef="verifyReportTask" />
      <userTask id="verifyReportTask" name="Verify monthly financial report">
         <documentation>Verify monthly financial report composed by the
            accountancy department. This financial report is going to be sent to
            all the company shareholders.</documentation>
         <potentialOwner>
               <formalExpression>management</formalExpression>
         </potentialOwner>
      </userTask>
      <sequenceFlow id="flow3" sourceRef="verifyReportTask"
         targetRef="theEnd" />
      <endEvent id="theEnd" />
   </process>
   </definitions>
when I run the code , some errors occurred, who can help me? thanks.
Exception in thread "main" org.activiti.engine.ActivitiObjectNotFoundException: no processes deployed with key 'financialReport'
at org.activiti.engine.impl.persistence.deploy.DeploymentManager.findDeployedLatestProcessDefinitionByKey(DeploymentManager.java:67)
at org.activiti.engine.impl.cmd.StartProcessInstanceCmd.execute(StartProcessInstanceCmd.java:64)
at org.activiti.engine.impl.cmd.StartProcessInstanceCmd.execute(StartProcessInstanceCmd.java:36)
at org.activiti.engine.impl.interceptor.CommandExecutorImpl.execute(CommandExecutorImpl.java:24)
at org.activiti.engine.impl.interceptor.CommandContextInterceptor.execute(CommandContextInterceptor.java:61)
at org.activiti.engine.impl.interceptor.LogInterceptor.execute(LogInterceptor.java:37)
at org.activiti.engine.impl.RuntimeServiceImpl.startProcessInstanceByKey(RuntimeServiceImpl.java:54)
at test.Test.main(Test.java:26)
trademak
The process definition XML file needs to end with .bpmn20.xml or .bpmn otherwise it's not parsed and deployed to the Activiti Engine.
Best regards,
