org.activiti.engine.ActivitiException: execution 2301 doesn't exist
sonalikate
If I get an exception during my Activiti process, it is catched and appropriate logging is done. But If I try to again run the same process I get org.activiti.engine.ActivitiException: execution 2301 doesn't exist.
Question: If we get an exception in between the Activiti process, does that mean the process will be killed even if we have try-catch?
Requirement: We want to log this exception and process should continue. Also if I trigger the same process which was waiting for some event the remaining process tasks should be executed smoothly. Can this be possible?
Thanks in advance.
frederikherema1
What do you mean "get an exception during my acitviti process". If you try-catch around an API-call (eg. runtimeService.startProcessByXXX) and an exception is returned, the transaction is rolled back, where the process was created. So the next time you try doing an API-call with that execution-id, it doesn't exist.
Or are you doing a try-catch inside a JavaDelegate?
