Hello, having trouble migrating from alfresco1.4 to alfresco2.1.
The basic setup is FreeBSD 6.1 using the tomcat from alfresco-community-tomcat-2.1.0.tar.gz
I can get a clean install up and running without any problems. However migrating the data from alfresco14 caused the bellow error. Here is what I did:
- Unpacked alfresco-community-tomcat-2.1.0.tar.gz
- Set the database to a copy of the mysql14 database
- Set dir.root to /alf_data.
- Copied alfresco14's alf_data to /alf_data
- Deleted /alf_data/lucene-indexes
- Set index.recovery.mode=FULL in tomcat/webapps/alfresco/WEB-INF/classes/alfresco/repository.properties
- start alfresco with alfresco.sh start
Error:
14:52:38,795 WARN [org.springframework.remoting.rmi.RmiRegistryFactoryBean] Could not detect RMI registry - creating new one
14:52:40,835 WARN [org.alfresco.util.OpenOfficeConnectionTester] A connection to OpenOffice could not be established.
14:52:44,541 INFO [org.alfresco.repo.domain.schema.SchemaBootstrap] Schema managed by database dialect org.hibernate.dialect.MySQLInnoDBDialect.
14:52:46,268 INFO [org.alfresco.repo.domain.schema.SchemaBootstrap] No changes were made to the schema.
14:52:48,078 INFO [org.alfresco.repo.node.index.FullIndexRecoveryComponent] Index recovery started: 2,521 transactions.
14:52:53,944 INFO [org.alfresco.repo.node.index.FullIndexRecoveryComponent] 10 % complete.
14:52:56,136 INFO [org.alfresco.repo.node.index.FullIndexRecoveryComponent] 20 % complete.
14:52:58,592 INFO [org.alfresco.repo.node.index.FullIndexRecoveryComponent] 30 % complete.
14:53:03,515 INFO [org.alfresco.repo.node.index.FullIndexRecoveryComponent] 40 % complete.
14:53:08,381 INFO [org.alfresco.repo.node.index.FullIndexRecoveryComponent] 50 % complete.
14:53:11,247 INFO [org.alfresco.repo.node.index.FullIndexRecoveryComponent] 60 % complete.
14:53:14,834 INFO [org.alfresco.repo.node.index.FullIndexRecoveryComponent] 70 % complete.
14:53:20,178 INFO [org.alfresco.repo.node.index.FullIndexRecoveryComponent] 80 % complete.
14:53:23,752 INFO [org.alfresco.repo.node.index.FullIndexRecoveryComponent] 90 % complete.
14:53:26,737 INFO [org.alfresco.repo.node.index.FullIndexRecoveryComponent] 100 % complete.
14:53:26,746 INFO [org.alfresco.repo.node.index.FullIndexRecoveryComponent] Index recovery completed.
14:56:22,438 INFO [org.alfresco.repo.admin.ConfigurationChecker] The Alfresco root data directory ('dir.root') is: /alf_data
14:56:22,451 ERROR [org.alfresco.repo.admin.ConfigurationChecker] CONTENT INTEGRITY ERROR: System content not found in content store.
14:56:22,451 ERROR [org.alfresco.repo.admin.ConfigurationChecker] Ensure that the 'dir.root' property is pointing to the correct data location.
14:56:22,456 ERROR [org.springframework.web.context.ContextLoader] Context initialization failed
org.alfresco.error.AlfrescoRuntimeException: Ensure that the 'dir.root' property is pointing to the correct data location.
at org.alfresco.repo.admin.ConfigurationChecker.check(ConfigurationChecker.java:312)
at org.alfresco.repo.admin.ConfigurationChecker.access$000(ConfigurationChecker.java:72)
at org.alfresco.repo.admin.ConfigurationChecker$1.execute(ConfigurationChecker.java:178)
at org.alfresco.repo.transaction.RetryingTransactionHelper.doInTransaction(RetryingTransactionHelper.java:225)
at org.alfresco.repo.transaction.RetryingTransactionHelper.doInTransaction(RetryingTransactionHelper.java:155)
at org.alfresco.repo.admin.ConfigurationChecker.onBootstrap(ConfigurationChecker.java:182)
14:56:22,459 ERROR [org.apache.catalina.core.ContainerBase.[Catalina].[localhost].[/alfresco]] Exception sending context initialized event to listener instance of class org.springframework.web.context.ContextLoaderListener
14:56:22,462 ERROR [org.apache.catalina.core.ContainerBase.[Catalina].[localhost].[/alfresco]] Exception sending context initialized event to listener instance of class org.alfresco.web.app.ContextListener
Any ideas?
Andrew
