My web site is loading too slowly Alfresco Problem?....
Options
08-02-2012 05:32 AM
This is Paramesh..We are running a website (with Jboss-portal-2.6.7GA and Alfresco tomcat)…the issue is my web site loading very slowly..if i Stop the alfresco service it loading Quickly but some content on web page not loading…so i have to run the alfresco service…if i do this my webpage loading very slowly…it seems to be problem with alfresco…Please help me if any one experienced it…
Thank you…
Thank you…
Labels:
Archive
4 REPLIES 4
Options
08-02-2012 05:46 AM
There's not enough detail in your posting. For example does your website use Alfresco or does it just happen to be on the same instance of JBOSS?
Lots more details please.
Options
08-04-2012 05:30 AM
Hello Sir,
Thank you for your involvement in this issue…i try to open the site in server it self even in server it is loading Slowly…i found some errors in logfiles please check below…
[AprLifecycleListener] The Apache Tomcat Native library which
allows optimal performance in production environments was not found on the java
.library.path: /usr/java/jdk1.6.0_15/jre/lib/i386/server:/usr/java/jdk1.6.0_15/j
re/lib/i386:/usr/java/jdk1.6.0_15/jre/../lib/i386:/usr/java/packages/lib/i386:/l
ib:/usr/lib
WARN [ServiceController] Problem starting service jboss:service=KeyGeneratorFactory,type=HiLo
at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:1055)
at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:956)
at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:3515)
at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:3447)
at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:911)
ERROR [org.hibernate.transaction.JDBCTransaction] JDBC rollback failed
ERROR [org.alfresco.util.exec.RuntimeExecBootstrapBean] Bootstrap command failed:
ERROR [org.alfresco.util.transaction.SpringAwareUserTransaction.trace] UserTransaction being garbage collected without a commit() or rollback(). NO
TE: Prior to transaction call stack logging
ERROR [org.alfresco.repo.shutdown.ShutdownBackstop] Alfresco terminating via Shutdown Backstop
ERROR [org.springframework.transaction.support.TransactionSynchronizationUtils] TransactionSynchronization.afterCompletion threw exception
13:17:34,759 ERROR [org.alfresco.repo.content.transform.magick.AbstractImageMagi
ckContentTransformer] ImageMagickContentTransformer not available: Failed to perform ImageMagick transformation:
13:17:41,486 ERROR [org.alfresco.repo.content.transform.RuntimeExecutableContent
Transformer] Failed to start a runtime executable content transformer:
13:17:50,208 ERROR [org.alfresco.util.exec.RuntimeExecBootstrapBean] Bootstrap command failed:
13:17:57,145 ERROR [org.alfresco.smb.protocol] Failed to get local domain/workgroup name, using default of WORKGROUP
13:17:57,146 ERROR [org.alfresco.smb.protocol] (This may be due to firewall settings or incorrect <broadcast> setting)
16:52:16,349 ERROR [org.alfresco.smb.protocol] Failed to get local domain/workgroup name, using default of WORKGROUP
16:52:16,349 ERROR [org.alfresco.smb.protocol] (This may be due to firewall settings or incorrect <broadcast> setting)
16:52:16,588 WARN [org.alfresco.util.OpenOfficeConnectionTester] An initial OpenOffice connection could not be established.
16:52:16,654 INFO [org.alfresco.service.descriptor.DescriptorService] Alfresco JVM - v1.6.0_15-b03; maximum heap size 493.063MB
16:52:16,654 WARN [org.alfresco.service.descriptor.DescriptorService] Alfresco JVM - WARNING - maximum heap size 493.063MB is less than recommended 512MB
16:52:16,655 INFO [org.alfresco.service.descriptor.DescriptorService] Alfresco started (Labs): Current version 3.0.0 (Stable 1526) schema 1002 - Installed version 3.0.0 (Stable 1526) schema 1002
16:52:28,923 INFO [org.alfresco.web.site.FrameworkHelper] Successfully Initialized Web Framework
Thank you….
ib:/usr/lib
Thank you….
Options
08-09-2012 02:22 AM
Yes my website using Alfresco….
Options
08-09-2012 05:13 AM
Given the above warning, I'll guess that you need to add more memory.
But its impossible to give any answer with the scant details you are posting.
