Multi-tenancy problem
kpolitis
recently i tried to install/setup a dev multi-tenancy environment with Alfresco Community 3.2r in Linux Platform. See bellow my structure:
Linux: RedHat 5.3 x64
Mysql DB server 5.0.45
I run a typical installation with success. My alfresco setup loaded successfully without MT enabled. After that i tried to enable MT with success again. I created a test logical mt domain with success again (tested logins)…but when i tried to restart my alfresco service, i took the following errors…see bellow…
Can you help me?
Thanks in advance.
Jan 6, 2010 2:17:51 PM org.apache.catalina.core.StandardEngine start
Jan 6, 2010 2:17:52 PM org.apache.catalina.core.StandardContext addApplicationListener
14:17:57,178 INFO [alfresco.config.JndiPropertiesFactoryBean] Loading properties file from class path resource [alfresco/repository.properties]
14:17:57,179 INFO [alfresco.config.JndiPropertiesFactoryBean] Loading properties file from class path resource [alfresco/domain/transaction.properties]
14:17:57,179 INFO [alfresco.config.JndiPropertiesFactoryBean] Loading properties file from URL [file:/project/Alfresco/tomcat/shared/classes/alfresco-global.properties]
14:17:57,266 INFO [alfresco.config.JndiPropertyPlaceholderConfigurer] Loading properties file from class path resource [alfresco/alfresco-shared.properties]
14:18:13,467 INFO [domain.schema.SchemaBootstrap] Schema managed by database dialect org.hibernate.dialect.MySQLInnoDBDialect.
14:18:14,228 INFO [domain.schema.SchemaBootstrap] No changes were made to the schema.
14:18:14,570 INFO [management.subsystems.ChildApplicationContextFactory] Starting 'sysAdmin' subsystem, ID: [sysAdmin, default]
14:18:14,580 INFO [alfresco.config.JndiPropertyPlaceholderConfigurer] Loading properties file from class path resource [alfresco/alfresco-shared.properties]
14:18:14,584 INFO [management.subsystems.ChildApplicationContextFactory] Startup of 'sysAdmin' subsystem, ID: [sysAdmin, default] complete
14:18:16,561 ERROR [web.context.ContextLoader] Context initialization failed
org.alfresco.error.AlfrescoRuntimeException: 00060000 Failed to bootstrap tenants
at org.alfresco.repo.tenant.MultiTAdminServiceImpl.startTenants(MultiTAdminServiceImpl.java:326)
at org.alfresco.repo.tenant.MultiTenantBootstrap.onBootstrap(MultiTenantBootstrap.java:53)
at org.springframework.context.support.AbstractApplicationContext.finishRefresh(AbstractApplicationContext.java:617)
Caused by: java.lang.RuntimeException: Error during run as.
at org.alfresco.repo.security.authentication.AuthenticationUtil.runAs(AuthenticationUtil.java:526)
at org.alfresco.repo.dictionary.DictionaryDAOImpl.initDictionary(DictionaryDAOImpl.java:187)
at org.alfresco.repo.dictionary.DictionaryDAOImpl.init(DictionaryDAOImpl.java:135)
at org.alfresco.repo.dictionary.NamespaceDAOImpl.reset(NamespaceDAOImpl.java:125)
at org.alfresco.repo.dictionary.NamespaceDAOImpl.getNamespaceRegistry(NamespaceDAOImpl.java:424)
at org.alfresco.repo.dictionary.NamespaceDAOImpl.getPrefixesCtx(NamespaceDAOImpl.java:551)
at org.alfresco.repo.dictionary.NamespaceDAOImpl.getPrefixes(NamespaceDAOImpl.java:366)
at org.alfresco.repo.dictionary.DictionaryNamespaceComponent.getPrefixes(DictionaryNamespaceComponent.java:88)
at org.alfresco.service.namespace.QName.getPrefixedQName(QName.java:276)
at org.alfresco.repo.dictionary.DictionaryRepositoryBootstrap.onDictionaryInit(DictionaryRepositoryBootstrap.java:246)
at org.alfresco.repo.dictionary.DictionaryDAOImpl.initDictionaryRegistry(DictionaryDAOImpl.java:254)
at org.alfresco.repo.dictionary.DictionaryDAOImpl.access$100(DictionaryDAOImpl.java:66)
at org.alfresco.repo.dictionary.DictionaryDAOImpl$1.doWork(DictionaryDAOImpl.java:196)
at org.alfresco.repo.dictionary.DictionaryDAOImpl$1.doWork(DictionaryDAOImpl.java:189)
at org.alfresco.repo.security.authentication.AuthenticationUtil.runAs(AuthenticationUtil.java:514)
Caused by: java.lang.StackOverflowError
at java.util.LinkedHashMap.get(LinkedHashMap.java:280)
at net.sf.ehcache.store.MemoryStore.get(MemoryStore.java:130)
Jan 6, 2010 2:18:16 PM org.apache.catalina.core.StandardContext start
SEVERE: Error listenerStart
log4j:ERROR LogMananger.repositorySelector was null likely due to error in class reloading, using NOPLoggerRepository.
Jan 6, 2010 2:18:17 PM org.apache.catalina.startup.HostConfig deployWAR
INFO: Deploying web application archive mobile.war
14:18:18,461 INFO [alfresco.config.JBossEnabledWebApplicationContext] Refreshing org.alfresco.config.JBossEnabledWebApplicationContext@c936ce: display name [Root WebApplicationContext]; startup date [Wed Jan 06 14:18:18 EET 2010]; root of context hierarchy
14:18:18,698 INFO [alfresco.config.JBossEnabledWebApplicationContext] Bean factory for application context [org.alfresco.config.JBossEnabledWebApplicationContext@c936ce]: org.springframework.beans.factory.support.DefaultListableBeanFactory@11ee981
14:18:19,529 INFO [web.scripts.DeclarativeRegistry] Registered 22 Web Scripts (+0 failed), 24 URLs
14:18:19,542 INFO [web.scripts.AbstractRuntimeContainer] Initialised Presentation Web Script Container (in 161.708ms)
14:18:19,617 INFO [web.scripts.DeclarativeRegistry] Registered 40 Web Scripts (+0 failed), 42 URLs
14:18:19,628 INFO [web.scripts.AbstractRuntimeContainer] Initialised WebFramework Web Script Container (in 84.104ms)
14:18:19,664 INFO [web.site.FrameworkHelper] Successfully Initialized Web Framework
Jan 6, 2010 2:18:19 PM org.apache.catalina.startup.HostConfig deployWAR
INFO: Deploying web application archive share.war
14:18:21,643 INFO [web.site.FrameworkHelper] Successfully Initialized Web Framework
Jan 6, 2010 2:18:21 PM org.apache.coyote.http11.Http11Protocol start
Jan 6, 2010 2:18:21 PM org.apache.catalina.startup.Catalina start
INFO: Server startup in 30526 ms
sselvan
I see three issues in JIRA around this thread's issue -
http://issues.alfresco.com/jira/browse/ETHREEOH-530
https://issues.alfresco.com/jira/browse/ALF-589
http://issues.alfresco.com/jira/browse/ETHREEOH-4153
I am also facing this issue and all I did was added tenants and restarted the server later. I don't know how to fix this too.
Did anyone find solution to this?
—UPDATE: I disabled MT for now and proceeding with my development. This allows me at least start my server.
savic_prvoslav
Is there someone smart who knows how to fix this?
