Multi-tenancy problem
kpolitis
recently i tried to install/setup a multi-tenancy environment with Alfresco Community 3.2r in Linux Platform. See bellow my structure:
Linux: RedHat 5.3 x64
Mysql DB server 5.0.45
I run a typical installation with success. My alfresco setup loaded successfully without MT enabled. After that i tried to enable MT with success again. I created a test logical mt domain with success again (tested logins)…but when i tried to restart my alfresco service, i took the following errors…see bellow…
Can you help me?
Thanks in advance.
Jan 6, 2010 2:17:51 PM org.apache.catalina.core.StandardEngine start
Jan 6, 2010 2:17:52 PM org.apache.catalina.core.StandardContext addApplicationListener
14:17:57,178  INFO  [alfresco.config.JndiPropertiesFactoryBean] Loading properties file from class path resource [alfresco/repository.properties]
14:17:57,179  INFO  [alfresco.config.JndiPropertiesFactoryBean] Loading properties file from class path resource [alfresco/domain/transaction.properties]
14:17:57,179  INFO  [alfresco.config.JndiPropertiesFactoryBean] Loading properties file from URL [file:/project/Alfresco/tomcat/shared/classes/alfresco-global.properties]
14:17:57,266  INFO  [alfresco.config.JndiPropertyPlaceholderConfigurer] Loading properties file from class path resource [alfresco/alfresco-shared.properties]
14:18:13,467  INFO  [domain.schema.SchemaBootstrap] Schema managed by database dialect org.hibernate.dialect.MySQLInnoDBDialect.
14:18:14,228  INFO  [domain.schema.SchemaBootstrap] No changes were made to the schema.
14:18:14,570  INFO  [management.subsystems.ChildApplicationContextFactory] Starting 'sysAdmin' subsystem, ID: [sysAdmin, default]
14:18:14,580  INFO  [alfresco.config.JndiPropertyPlaceholderConfigurer] Loading properties file from class path resource [alfresco/alfresco-shared.properties]
14:18:14,584  INFO  [management.subsystems.ChildApplicationContextFactory] Startup of 'sysAdmin' subsystem, ID: [sysAdmin, default] complete
14:18:16,561  ERROR [web.context.ContextLoader] Context initialization failed
org.alfresco.error.AlfrescoRuntimeException: 00060000 Failed to bootstrap tenants
        at org.alfresco.repo.tenant.MultiTAdminServiceImpl.startTenants(MultiTAdminServiceImpl.java:326)
        at org.alfresco.repo.tenant.MultiTenantBootstrap.onBootstrap(MultiTenantBootstrap.java:53)
        at org.springframework.context.support.AbstractApplicationContext.finishRefresh(AbstractApplicationContext.java:617)
Caused by: java.lang.RuntimeException: Error during run as.
        at org.alfresco.repo.security.authentication.AuthenticationUtil.runAs(AuthenticationUtil.java:526)
        at org.alfresco.repo.dictionary.DictionaryDAOImpl.initDictionary(DictionaryDAOImpl.java:187)
        at org.alfresco.repo.dictionary.DictionaryDAOImpl.init(DictionaryDAOImpl.java:135)
        at org.alfresco.repo.dictionary.NamespaceDAOImpl.reset(NamespaceDAOImpl.java:125)
        at org.alfresco.repo.dictionary.NamespaceDAOImpl.getNamespaceRegistry(NamespaceDAOImpl.java:424)
        at org.alfresco.repo.dictionary.NamespaceDAOImpl.getPrefixesCtx(NamespaceDAOImpl.java:551)
        at org.alfresco.repo.dictionary.NamespaceDAOImpl.getPrefixes(NamespaceDAOImpl.java:366)
        at org.alfresco.repo.dictionary.DictionaryNamespaceComponent.getPrefixes(DictionaryNamespaceComponent.java:88)
        at org.alfresco.service.namespace.QName.getPrefixedQName(QName.java:276)
        at org.alfresco.repo.dictionary.DictionaryRepositoryBootstrap.onDictionaryInit(DictionaryRepositoryBootstrap.java:246)
        at org.alfresco.repo.dictionary.DictionaryDAOImpl.initDictionaryRegistry(DictionaryDAOImpl.java:254)
        at org.alfresco.repo.dictionary.DictionaryDAOImpl.access$100(DictionaryDAOImpl.java:66)
        at org.alfresco.repo.dictionary.DictionaryDAOImpl$1.doWork(DictionaryDAOImpl.java:196)
        at org.alfresco.repo.dictionary.DictionaryDAOImpl$1.doWork(DictionaryDAOImpl.java:189)
        at org.alfresco.repo.security.authentication.AuthenticationUtil.runAs(AuthenticationUtil.java:514)
Caused by: java.lang.StackOverflowError
        at java.util.LinkedHashMap.get(LinkedHashMap.java:280)
        at net.sf.ehcache.store.MemoryStore.get(MemoryStore.java:130)
Jan 6, 2010 2:18:16 PM org.apache.catalina.core.StandardContext start
SEVERE: Error listenerStart
log4j:ERROR LogMananger.repositorySelector was null likely due to error in class reloading, using NOPLoggerRepository.
Jan 6, 2010 2:18:17 PM org.apache.catalina.startup.HostConfig deployWAR
INFO: Deploying web application archive mobile.war
14:18:18,461  INFO  [alfresco.config.JBossEnabledWebApplicationContext] Refreshing org.alfresco.config.JBossEnabledWebApplicationContext@c936ce: display name [Root WebApplicationContext]; startup date [Wed Jan 06 14:18:18 EET 2010]; root of context hierarchy
14:18:18,698  INFO  [alfresco.config.JBossEnabledWebApplicationContext] Bean factory for application context [org.alfresco.config.JBossEnabledWebApplicationContext@c936ce]: org.springframework.beans.factory.support.DefaultListableBeanFactory@11ee981
14:18:19,529  INFO  [web.scripts.DeclarativeRegistry] Registered 22 Web Scripts (+0 failed), 24 URLs
14:18:19,542  INFO  [web.scripts.AbstractRuntimeContainer] Initialised Presentation Web Script Container (in 161.708ms)
14:18:19,617  INFO  [web.scripts.DeclarativeRegistry] Registered 40 Web Scripts (+0 failed), 42 URLs
14:18:19,628  INFO  [web.scripts.AbstractRuntimeContainer] Initialised WebFramework Web Script Container (in 84.104ms)
14:18:19,664  INFO  [web.site.FrameworkHelper] Successfully Initialized Web Framework
Jan 6, 2010 2:18:19 PM org.apache.catalina.startup.HostConfig deployWAR
INFO: Deploying web application archive share.war
14:18:21,643  INFO  [web.site.FrameworkHelper] Successfully Initialized Web Framework
Jan 6, 2010 2:18:21 PM org.apache.coyote.http11.Http11Protocol start
Jan 6, 2010 2:18:21 PM org.apache.catalina.startup.Catalina start
INFO: Server startup in 30526 ms
6 REPLIES 6
unknown-user
I have the exact same problem.
MT doesnt seem to be production ready yet.
togum
I have the same problem.
Anyone have idea for us?
Please!!!
Thanks advaced!
savic_prvoslav
is this fixed yet?
togum
I've left MT.
Until now I no solution for that.
Thanks!
janv
Employee
Employee
This should be resolved in the latest nightly dev builds (for up-coming Community 3.3).
http://dev.alfresco.com/downloads/nightly/dist/
If you still see this issue, then please raise a detailed JIRA (with release/build version, exact steps to repeat, server log etc).
Regards,
Jan
savic_prvoslav
great, but I will wait for normal 3.3. Smiley Happy
