Mule Integration Problem
khaled012
Hi All,
I'm trying to use Mule Task but when I upload the process definition I get an error message "Could not find org.activiti.mule.MuleSendActivitiBehavior"
My Mule task
<serviceTask id="servicetask1" name="Service Task" activiti:type="mule">
       <extensionElements>
        <activiti:field name="endpointUrl">
          <activiti:string>vm://in</activiti:string>
        </activiti:field>
        <activiti:field name="language">
          <activiti:string>juel</activiti:string>
        </activiti:field>
        <activiti:field name="payloadExpression">
          <activiti:string>"hi"</activiti:string>
        </activiti:field>
        <activiti:field name="resultVariable">
          <activiti:string>theVariable</activiti:string>
        </activiti:field>
      </extensionElements>
    </serviceTask>
Best Regards,
ronald_van_kuij
Are you using Activiti 1.0?
trademak
By default the Mule JAR is not installed on the Activiti Engine.
So that's why you receive the error message.
If you want to run Mule embedded you need actually quite a lot of JARs.
I've written a blog post about this on http://bpmn20inaction.blogspot.com/2011/05/supersize-activiti-with-mule-esb-and.html.
And I created a Google code repository, containing examples for both Mule as well as Camel:
https://code.google.com/p/activiti-esb-blog/
Take a look there and you'll see the additional dependencies needed to run the Mule example.
Best regards,
