memory leak problem
williamlai
Dear all,
I don't know why my Alfresco server always have memory leak happen. How can I solve the problem? Please kindly help.
Server Config: Hyper-V of 2CPU with 2 GB RAM allocate
Below is the error log message:
2011-9-1 11:02:35 org.apache.catalina.loader.WebappClassLoader clearThreadLocalMap 严重: A web application created a ThreadLocal with key of type [org.alfresco.repo.policy.BaseBehaviour.StackThreadLocal] (value [org.alfresco.repo.policy.BaseBehaviour$StackThreadLocal@10299f4]) and a value of type [java.util.Stack] (value [[]]) but failed to remove it when the web application was stopped. To prevent a memory leak, the ThreadLocal has been forcibly removed. 2011-9-1 11:02:35 org.apache.catalina.loader.WebappClassLoader clearThreadLocalMap 严重: A web application created a ThreadLocal with key of type [org.alfresco.repo.policy.BaseBehaviour.StackThreadLocal] (value [org.alfresco.repo.policy.BaseBehaviour$StackThreadLocal@1029790]) and a value of type [java.util.Stack] (value [[]]) but failed to remove it when the web application was stopped. To prevent a memory leak, the ThreadLocal has been forcibly removed. 2011-9-1 11:02:48 org.apache.catalina.loader.WebappClassLoader clearThreadLocalMap 严重: A web application created a ThreadLocal with key of type [null] (value [org.springframework.extensions.webscripts.processor.FTLTemplateProcessor$NonBlockingObjectWrapper$1@2715fdd]) and a value of type [freemarker.template.DefaultObjectWrapper] (value [freemarker.template.DefaultObjectWrapper@950e46]) but failed to remove it when the web application was stopped. To prevent a memory leak, the ThreadLocal has been forcibly removed. 2011-9-1 11:02:48 org.apache.catalina.loader.WebappClassLoader clearThreadLocalMap 严重: A web application created a ThreadLocal with key of type [null] (value [org.springframework.extensions.webscripts.processor.FTLTemplateProcessor$NonBlockingObjectWrapper$1@14b7938]) and a value of type [freemarker.template.DefaultObjectWrapper] (value [freemarker.template.DefaultObjectWrapper@10ec877]) but failed to remove it when the web application was stopped. To prevent a memory leak, the ThreadLocal has been forcibly removed. 2011-9-1 11:02:48 org.apache.catalina.loader.WebappClassLoader clearThreadLocalMap 严重: A web application created a ThreadLocal with key of type [null] (value [org.springframework.extensions.webscripts.processor.FTLTemplateProcessor$NonBlockingObjectWrapper$1@14b7e25]) and a value of type [freemarker.template.DefaultObjectWrapper] (value [freemarker.template.DefaultObjectWrapper@f9a72d]) but failed to remove it when the web application was stopped. To prevent a memory leak, the ThreadLocal has been forcibly removed.
mrogers
Its over zealous logging by Tomcat that you can ignore.
williamlai
Thanks your advise.  :lol:
