Issue with custom RestAuthenticator Using Rest 5.13
‎08-12-2013 04:40 AM
I'm developing a custom rest application with custom rest services on top of activiti-rest 5.13. As we have integrated siteminder(SSO) in application, all the request will go through the siteminder authentication using cookie value being passed from client to rest application, So I have removed extra authentication for activiti-rest services by customizing the ActivitiRestServicesApplication and created custom restAuthenticator by overriding methods requestRequiresAuthentication and isRequestAuthorized. Returning always false in the overriding method requestRequiresAuthentication of restAuthenticator class by this I'm removing extra authentication. With this configuration able to remove authentication in verify method, but the problem is for each resource invocation again the authenticate method is invoked in SecuredResource class and trying to retrieve the loogedInUser name.
Here is the piece of code getting invoked in ActivitiRestApplication,
public String authenticate(Request request, Response response) {
if (!(request.getClientInfo().isAuthenticated())) {
this.authenticator.challenge(response, false);
return null;
return request.getClientInfo().getUser().getIdentifier();
So the issue I'm facing is request.getClientInfo().getUser() is returning as null always, because of this rest service is not called. I'm not sure why the request.getClientInfo().getUser() is returning null. For the new custom rest service I have used SecurityContext in resource class and able to retrieve the User Principal information. Could any one help me how to achieve the same for the existing rest services?
Archive
‎08-12-2013 10:00 AM
‎08-12-2013 10:51 AM
‎08-14-2013 05:30 AM
‎08-14-2013 10:56 AM
‎05-16-2014 01:09 AM
‎05-19-2014 11:58 AM
<code>
org.restlet.security.User RestletUser = new org.restlet.security.User();
RestletUser.setIdentifier(userName);
ClientInfo info = new ClientInfo();
info.setUser(RestletUser);
request.setClientInfo(info);
</code>
But now, I get the following error mesages:
<code>
Internal Server Error (500) - The server encountered an unexpected condition which prevented it from fulfilling the request
at org.restlet.resource.ServerResource.doHandle(ServerResource.java:517)
at org.restlet.resource.ServerResource.get(ServerResource.java:707)
at org.restlet.resource.ServerResource.doHandle(ServerResource.java:589)
at org.restlet.resource.ServerResource.doNegotiatedHandle(ServerResource.java:649)
at org.restlet.resource.ServerResource.doConditionalHandle(ServerResource.java:348)
at org.restlet.resource.ServerResource.handle(ServerResource.java:952)
at org.restlet.resource.Finder.handle(Finder.java:246)
at org.restlet.routing.Filter.doHandle(Filter.java:159)
at org.restlet.routing.Filter.handle(Filter.java:206)
at org.restlet.routing.Router.doHandle(Router.java:431)
at org.restlet.routing.Router.handle(Router.java:648)
at org.restlet.engine.application.StatusFilter.doHandle(StatusFilter.java:155)
at org.restlet.engine.CompositeHelper.handle(CompositeHelper.java:211)
at org.restlet.engine.application.ApplicationHelper.handle(ApplicationHelper.java:84)
at org.restlet.Application.handle(Application.java:381)
at org.restlet.Component.handle(Component.java:392)
at org.restlet.Server.handle(Server.java:516)
at org.restlet.engine.ServerHelper.handle(ServerHelper.java:72)
at org.restlet.engine.adapter.HttpServerHelper.handle(HttpServerHelper.java:152)
at org.restlet.ext.servlet.ServerServlet.service(ServerServlet.java:1089)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:728)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:51)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:502)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:171)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:100)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:953)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1041)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:603)
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:310)
Caused by: org.apache.ibatis.exceptions.PersistenceException:
### Error querying database. Cause: java.lang.NullPointerException
### Cause: java.lang.NullPointerException
at org.apache.ibatis.session.defaults.DefaultSqlSession.selectList(DefaultSqlSession.java:107)
at org.apache.ibatis.session.defaults.DefaultSqlSession.selectList(DefaultSqlSession.java:98)
at org.activiti.engine.impl.db.DbSqlSession.selectListWithRawParameter(DbSqlSession.java:331)
at org.activiti.engine.impl.db.DbSqlSession.selectList(DbSqlSession.java:322)
at org.activiti.engine.impl.db.DbSqlSession.selectList(DbSqlSession.java:312)
at org.activiti.engine.impl.persistence.entity.ProcessDefinitionEntityManager.findProcessDefinitionsByQueryCriteria(ProcessDefinitionEntityManager.java:57)
at org.activiti.engine.impl.ProcessDefinitionQueryImpl.executeList(ProcessDefinitionQueryImpl.java:288)
at org.activiti.engine.impl.AbstractQuery.execute(AbstractQuery.java:143)
at org.activiti.engine.impl.interceptor.CommandInvoker.execute(CommandInvoker.java:24)
at org.activiti.engine.impl.interceptor.CommandContextInterceptor.execute(CommandContextInterceptor.java:57)
at org.activiti.spring.SpringTransactionInterceptor$1.doInTransaction(SpringTransactionInterceptor.java:47)
at org.springframework.transaction.support.TransactionTemplate.execute(TransactionTemplate.java:131)
at org.activiti.spring.SpringTransactionInterceptor.execute(SpringTransactionInterceptor.java:45)
at org.activiti.engine.impl.AbstractQuery.listPage(AbstractQuery.java:124)
at org.activiti.rest.common.api.AbstractPaginateList.paginateList(AbstractPaginateList.java:104)
at org.activiti.rest.common.api.AbstractPaginateList.paginateList(AbstractPaginateList.java:129)
at org.activiti.rest.service.api.repository.ProcessDefinitionCollectionResource.getProcessDefinitions(ProcessDefinitionCollectionResource.java:107)
at org.restlet.resource.ServerResource.doHandle(ServerResource.java:506)
… 62 more
at javax.naming.ldap.Rdn.escapeStringValue(Unknown Source)
at javax.naming.ldap.Rdn.escapeValue(Unknown Source)
at org.activiti.ldap.LDAPQueryBuilder.buildQueryGroupsForUser(LDAPQueryBuilder.java:77)
at org.activiti.ldap.LDAPGroupManager$1.executeInContext(LDAPGroupManager.java:120)
at org.activiti.ldap.LDAPGroupManager$1.executeInContext(LDAPGroupManager.java:116)
at org.activiti.ldap.LDAPTemplate.execute(LDAPTemplate.java:44)
at org.activiti.ldap.LDAPGroupManager.findGroupsByUser(LDAPGroupManager.java:116)
at org.activiti.engine.impl.ProcessDefinitionQueryImpl.getAuthorizationGroups(ProcessDefinitionQueryImpl.java:234)
at org.apache.ibatis.reflection.invoker.MethodInvoker.invoke(MethodInvoker.java:37)
at org.apache.ibatis.reflection.wrapper.BeanWrapper.getBeanProperty(BeanWrapper.java:151)
at org.apache.ibatis.reflection.wrapper.BeanWrapper.get(BeanWrapper.java:45)
at org.apache.ibatis.reflection.MetaObject.getValue(MetaObject.java:113)
at org.apache.ibatis.scripting.xmltags.DynamicContext$ContextMap.get(DynamicContext.java:94)
at org.apache.ibatis.scripting.xmltags.DynamicContext$ContextAccessor.getProperty(DynamicContext.java:113)
at org.apache.ibatis.ognl.OgnlRuntime.getProperty(OgnlRuntime.java:1657)
at org.apache.ibatis.ognl.ASTProperty.getValueBody(ASTProperty.java:92)
at org.apache.ibatis.ognl.SimpleNode.evaluateGetValueBody(SimpleNode.java:170)
at org.apache.ibatis.ognl.SimpleNode.getValue(SimpleNode.java:210)
at org.apache.ibatis.ognl.ASTNotEq.getValueBody(ASTNotEq.java:49)
at org.apache.ibatis.ognl.ASTAnd.getValueBody(ASTAnd.java:56)
at org.apache.ibatis.ognl.Ognl.getValue(Ognl.java:333)
at org.apache.ibatis.ognl.Ognl.getValue(Ognl.java:413)
at org.apache.ibatis.ognl.Ognl.getValue(Ognl.java:395)
at org.apache.ibatis.scripting.xmltags.OgnlCache.getValue(OgnlCache.java:45)
at org.apache.ibatis.scripting.xmltags.ExpressionEvaluator.evaluateBoolean(ExpressionEvaluator.java:29)
at org.apache.ibatis.scripting.xmltags.IfSqlNode.apply(IfSqlNode.java:30)
at org.apache.ibatis.scripting.xmltags.MixedSqlNode.apply(MixedSqlNode.java:29)
at org.apache.ibatis.scripting.xmltags.IfSqlNode.apply(IfSqlNode.java:31)
at org.apache.ibatis.scripting.xmltags.TrimSqlNode.apply(TrimSqlNode.java:51)
at org.apache.ibatis.scripting.xmltags.DynamicSqlSource.getBoundSql(DynamicSqlSource.java:37)
at org.apache.ibatis.mapping.MappedStatement.getBoundSql(MappedStatement.java:275)
at org.apache.ibatis.executor.CachingExecutor.query(CachingExecutor.java:79)
at org.apache.ibatis.session.defaults.DefaultSqlSession.selectList(DefaultSqlSession.java:104)
… 86 more
</code>
And I have no idea, why. My identifier is the LDAP CN-Name, e.g. Mike Mayers.
Any help is highly appreciated. Therefore it would be great if someone could give a a hint.
Thank you very much
Ben
‎05-21-2014 04:49 AM
You would have to see what goes in in the following line
‎10-15-2014 12:36 PM
<java>
setRestAuthenticator(new RestAuthenticator() {
@Override
public boolean requestRequiresAuthentication(Request request) {
final org.restlet.security.User restletUser = new org.restlet.security.User();
restletUser.setIdentifier("XXX");
final ClientInfo info = new ClientInfo();
info.setUser(restletUser);
return false;
@Override
public boolean isRequestAuthorized(Request request) {
return true;
</java>
‎10-15-2014 12:37 PM
For Example this doesn't work:
<java>
public MyActivitiRestServicesApplication() {
super();
@Override
return false;
@Override
return true;
</java>
"It's possible to remove authentication from certain resources or adding additional authorisation on top of being an authenticated user (eg. being part of group X allows a user to execute request with URL Y). This can be achieved by using an implementation of org.activiti.rest.common.filter.RestAuthenticator which has 2 methods:
boolean requestRequiresAuthentication(Request request): Called before a request is checked for authentication (valid username and password is passed in header). If this method returns true, the method needs authentication. If false is returned, the request will be done regardless of the request being authenticated. If false is returned, isRequestAuthorized will not be called either for this request."
makes no mention of the need to set a user context. A simple example would be nice too
