Is Deployment Engine running?
tagany
Following the instructions in Getting_Started_with_WCM_for_Alfresco_Community_Edition_3_2.pdf I've gotten to deployment, and when I try to deploy I get
\\localhost:44100
Deployment Failed
07130021 Could not connect to remote FSR, transportName:default, hostName:localhost, port: 44100
sudo ss -lnp shows nothing running on 44100.  So I'm wondering if the deployment server is running?  Might there be a mistake in a config file that it didn't get started?  Or … ?
Thanks, David
10 REPLIES 10
abbeydom
Had same issue with 3.4c community edition and resolved it. On the deployment servers configuration page state the ff:
Configure deployment servers
Transport Name:   default
Host:   localhost
Port:   50500
URL:   –
Type:   Live Server
Username:   admin
Source Path:   –
Excludes:   –
Target Name:   avm
Include In Auto Deploy:   No
Key input :
port: 50500
target : avm
( target must be specied).
Contrary to the getting started with WCM documentation that says 44100 for the server port  and nothing for the target. And no separation between the above configuration for a local vs a remote deployment server.
/D.
