Installation Problems
phlipmaster
i'm trying to install Activiti to test it. Everything works fine but when i start the installation via ant demo.start and the browser windows get opened, nothing than an 404 Page ist shown. [attachment=0]Bildschirmfoto 2011-03-30 um 22.36.15.png[/attachment]
Here some hardfacts:
System: Mac OS X 10.6.6
Apache Ant: 1.8.2
Activiti 5.3
Tomcat works fine, the system page is shown under http://localhost:8080/
Here ist the Terminal-Code:
demo.install:
cfg.create:
     [copy] Copying 1 file to /Users/philipppbaldermann/Downloads/activiti-5.3/setup/build/activiti-cfg
      [zip] Building zip: /Users/philipppbaldermann/Downloads/activiti-5.3/setup/build/activiti-cfg.jar
     [echo] copying configuration to ../workspace/activiti-engine-examples/src/main/config
    [unzip] Expanding: /Users/philipppbaldermann/Downloads/activiti-5.3/setup/build/activiti-cfg.jar into /Users/philipppbaldermann/Downloads/activiti-5.3/workspace/activiti-engine-examples/src/main/config
internal.classpath.libs:
internal.taskdef.launch:
h2.start:
   [launch] launching cmd '/Users/philipppbaldermann/Downloads/activiti-5.3/apps/h2/h2.start.sh ' in dir '/Users/philipppbaldermann/Downloads/activiti-5.3/apps/h2'
   [launch] waiting for launch completion msg 'TCP server running on'…
   [launch]   TCP server running on tcp://192.168.1.10:9092 (others can connect)
tomcat.start:
   [launch] launching cmd '/Users/philipppbaldermann/Downloads/activiti-5.3/apps/apache-tomcat-6.0.32/bin/startup.sh ' in dir '/Users/philipppbaldermann/Downloads/activiti-5.3/apps/apache-tomcat-6.0.32/bin'
   [launch] waiting for launch completion msg 'Using CLASSPATH:'…
   [launch] launched process completed
explorer.browser.open:
demo.start:
BUILD SUCCESSFUL
Total time: 10 seconds
Can somebody help me?
Thank you very much, Philipp
frederikherema1
And when you refresh the page? Sometimes it happens that the browser opens before apps are deployed on tomcat. Is there any stacktrace in your tomcat-log (logs/catalina.out)?
