Indexing problem using CIFS interface
pixies
I am using the CIFS interface to import some Word 2002 documents.
After the import of a document I tried to make a fulltext search using some words contained in the document and the document is not retrieved.
If I make a check-out/check-in of the document previously imported (using the Alfresco web client), then the document is fully indexed and the search works well.
I made the same test using the FTP interface and the behaviour is the same.
As I need to import a lot of documents it is not an option in our case to import the documents using the Alfresco Web interface.
Is there any parameter to configure or any workaround in order to solve this issue?
Thank you very much
P.S: the OS we are currently using is Windows XP
kevinr
I've just tried this with the latest code (from HEAD) and it works fine for me (several docs imported via CIFS and all are found via full-text search).
Which version of Alfresco are you using?
Kevin
