Indexes on ACT_RU_VARIABLE will improve performance
mamue
during jMeter tests with many open processes I found two indexes
which will improve performance significantly if there are many rows (1m+) in table ACT_RU_VARIABLE:
CREATE INDEX ACT_RU_VARIABLE_IDX1 ON ACT_RU_VARIABLE (BYTEARRAY_ID_);
CREATE INDEX ACT_RU_VARIABLE_IDX2 ON ACT_RU_VARIABLE (EXECUTION_ID_);
The first index improves performance when deleting rows from table ACT_GE_BYTEARRAY:
Before a row can be deleted the database has to check the foreign key constraint on column ACT_RU_VARIABLE.BYTEARRAY_ID_.
Without index this results in a time-consuming full table scan of column ACT_RU_VARIABLE.BYTEARRAY_ID_ for the ID_ of the row to be deleted.
What about adding these two indexes to Activiti?
Kind regards,
Markus Mueller
