I noticed in the wiki that there are some Index Validation and maintenance tools in the 3.1 release. Where can I locate these? We've run into some serious problems with Alfresco, and we think that part of the problem may lie in the indexes. I've checked with our Alfresco partner and he thinks there are no such tools!
Alfresco 3.1 Enterprise: Released March 2009 Enterprise release including 3d features detailed above plus:
Comprehensive System Monitoring via JMX and Optional Hyperic Plug-in Unicast clustering support for easy cluster configuration and management Index validation and maintenance tools Command line repository configuration allowing repository configuration via commandline flags
The Enterprise products have certain tools and extensions that are only relevant to an Enterprise deployment. For example, support for Oracle and MS SQL Server; JMX-based toolset, etc.
I mostly agree with you (JMX/workflow are typically enterprise focused, no discussion).
Maintenance tools, There is no reason to consider they should not be shared with community. Except if community instances have to die after a certain time/load.
This is not really a "community" choice - not sure I can find analogy in some other open source projects, Nevertheless, business is not democracy :?
