I need help in integrating AD with alfresco
dayanandj
Hi ALL,
I tried integrating AD with alfresco. taking help of Google or forums. It helped me to configure the AD but i am not able to sync the users and i get error saying LDAP authentication failed.
Steps that are followed:
1.  cd /Alfresco/tomcat/webapps/alfresco/WEB-INF/classes/
2. Changed the value to authentication.chain=ldap-ad1:ldap-ad,alfrescoNtlm1:alfrescoNtlm
3. cd /Alfresco/tomcat/webapps/alfresco/WEB-INF/classes/alfresco/subsystems/Authentication/ldap-ad
modified the file  ldap-ad-authentication.properties to.
#This flag enables use of this LDAP subsystem for authentication. It may be
# that this subsytem should only be used for synchronization, in which case
# this flag should be set to false.
# This properties file brings together the common options for LDAP authentication rather than editing the bean definitions
# How to map the user id entered by the user to taht passed through to LDAP
# In Active Directory, this can either be the user principal name (UPN) or DN.
# UPNs are in the form <sAMAccountName>@domain and are held in the userPrincipalName attribute of a user
ldap.authentication.userNameFormat=%[email protected]
#ldap.authentication.userNameFormat= CN=Administrator,CN=Users,DC=10.11.252.2
# The LDAP context factory to use
# The URL to connect to the LDAP server
##ldap.authentication.java.naming.provider.url=ldap://domaincontroller.company.com:389
ldap.authentication.java.naming.provider.url=ldap://10.11.252.2:389
# The authentication mechanism to use for password validation
# Escape commas entered by the user at bind time
# Useful when using simple authentication and the CN is part of the DN and contains commas
# Escape commas entered by the user when setting the authenticated user
# Useful when using simple authentication and the CN is part of the DN and contains commas, and the escaped \, is
# pulled in as part of an LDAP sync
# If this option is set to true it will break the default home folder provider as space names can not contain \
# Comma separated list of user names who should be considered administrators by default
ldap.authentication.defaultAdministratorUserNames=dayanand.j
# This flag enables use of this LDAP subsystem for user and group
# synchronization. It may be that this subsytem should only be used for
# authentication, in which case this flag should be set to false.
# The authentication mechanism to use for synchronization
ldap.synchronization.java.naming.security.authentication=simple
# The default principal to bind with (only used for LDAP sync). This should be a UPN or DN
##ldap.synchronization.java.naming.security.principal=alfresco@domain
ldap.synchronization.java.naming.security.principal=Administrator@10.11.252.2
# The password for the default principal (only used for LDAP sync)
ldap.synchronization.java.naming.security.credentials=xxxxxxxxxx
# If positive, this property indicates that RFC 2696 paged results should be
# used to split query results into batches of the specified size. This
# overcomes any size limits imposed by the LDAP server.
# If positive, this property indicates that range retrieval should be used to fetch
# multi-valued attributes (such as member) in batches of the specified size.
# Overcomes any size limits imposed by Active Directory.
ldap.synchronization.attributeBatchSize=0
# The query to select all objects that represent the groups to import.
ldap.synchronization.groupQuery=(&(objectclass\=group)(memberOf\=cn\=Users,dc\=10.11.252.2))
# The query to select objects that represent the groups to import that have changed since a certain time.
ldap.synchronization.groupDifferentialQuery=(&(objectclass\=group)(memberOf\=cn\=Users,dc\=10.11.252.2)(!(modifyTimestamp<\={0})))
# The query to select all objects that represent the users to import.
ldap.synchronization.personQuery=(&(objectclass\=user)(|(memberOf\=CN\=Users,DC\=10.11.252.2))(userAccountControl\:1.2.840.113556.1.4.803\:\=512))
# The query to select objects that represent the users to import that have changed since a certain time.
ldap.synchronization.personDifferentialQuery=(&(objectclass\=user)(|(memberOf\=CN\=Users,DC\=10.11.252.2))(userAccountControl\:1.2.840.113556.1.4.803\:\=512)(!(modifyTimestamp<\={0})))
# The group search base restricts the LDAP group query to a sub section of tree on the LDAP server.
#ldap.synchronization.groupSearchBase=ou\=Groups,dc\[email protected]
#ldap.synchronization.groupSearchBase=ou=Users,dc=10.11.252.2
ldap.synchronization.groupSearchBase=DC\=10.11.252.2
# The user search base restricts the LDAP user query to a sub section of tree on the LDAP server.
#ldap.synchronization.userSearchBase=ou=User,dc=10.11.252.2
ldap.synchronization.userSearchBase=CN\=Users, DC\=10.11.252.2
# The name of the operational attribute recording the last update time for a group or user.
# The timestamp format. Unfortunately, this varies between directory servers.
ldap.synchronization.timestampFormat=yyyyMMddHHmmss'.0Z'
# The attribute name on people objects found in LDAP to use as the uid in Alfresco
ldap.synchronization.userIdAttributeName=sAMAccountName
# The attribute on person objects in LDAP to map to the first name property in Alfresco
# The attribute on person objects in LDAP to map to the last name property in Alfresco
# The attribute on person objects in LDAP to map to the email property in Alfresco
# The attribute on person objects in LDAP to map to the organizational id  property in Alfresco
ldap.synchronization.userOrganizationalIdAttributeName=company
# The default home folder provider to use for people created via LDAP import
ldap.synchronization.defaultHomeFolderProvider=userHomesHomeFolderProvider
# The attribute on LDAP group objects to map to the authority name property in Alfresco
# The attribute on LDAP group objects to map to the authority display name property in Alfresco
ldap.synchronization.groupDisplayNameAttributeName=displayName
# The group type in LDAP
ldap.synchronization.groupType=group
# The person type in LDAP
ldap.synchronization.personType=user
# The attribute in LDAP on group objects that defines the DN for its members
# If true progress estimation is enabled. When enabled, the user query has to be run twice in order to count entries.
and i restarted alfresco but not able to sync the User.
The error i get is:
06:15:42,801  INFO  [management.subsystems.ChildApplicationContextFactory] Starting 'Authentication' subsystem, ID: [Authentication, managed, ldap-ad1]
06:15:42,819  INFO  [alfresco.config.FixedPropertyPlaceholderConfigurer] Loading properties file from class path resource [alfresco/version.properties]
06:15:42,819  INFO  [alfresco.config.JndiPropertyPlaceholderConfigurer] Loading properties file from class path resource [alfresco/alfresco-shared.properties]
06:15:42,820  INFO  [alfresco.config.FixedPropertyPlaceholderConfigurer] Loading properties file from class path resource [alfresco/domain/cache-strategies.properties]
06:15:42,820  INFO  [alfresco.config.FixedPropertyPlaceholderConfigurer] Loading properties file from class path resource [alfresco/module/org.alfresco.module.vti/context/vti.properties]
06:15:42,820  INFO  [alfresco.config.FixedPropertyPlaceholderConfigurer] Loading properties file from URL [file:/Alfresco/tomcat/shared/classes/alfresco/extension/custom-vti.properties]
06:15:43,024  INFO  [management.subsystems.ChildApplicationContextFactory] Startup of 'Authentication' subsystem, ID: [Authentication, managed, ldap-ad1] complete
06:15:43,024  INFO  [management.subsystems.ChildApplicationContextFactory] Starting 'Authentication' subsystem, ID: [Authentication, managed, alfrescoNtlm1]
06:15:43,040  INFO  [alfresco.config.FixedPropertyPlaceholderConfigurer] Loading properties file from class path resource [alfresco/version.properties]
06:15:43,041  INFO  [alfresco.config.JndiPropertyPlaceholderConfigurer] Loading properties file from class path resource [alfresco/alfresco-shared.properties]
06:15:43,041  INFO  [alfresco.config.FixedPropertyPlaceholderConfigurer] Loading properties file from class path resource [alfresco/domain/cache-strategies.properties]
06:15:43,041  INFO  [alfresco.config.FixedPropertyPlaceholderConfigurer] Loading properties file from class path resource [alfresco/module/org.alfresco.module.vti/context/vti.properties]
06:15:49,071 UserSmiley Frustratedystem INFO  [security.sync.ChainingUserRegistrySynchronizer] Synchronizing users and groups with user registry 'ldap-ad1'
06:15:49,075 UserSmiley Frustratedystem INFO  [security.sync.ChainingUserRegistrySynchronizer] Retrieving all groups from user registry 'ldap-ad1'
06:15:49,117 UserSmiley Frustratedystem ERROR [security.sync.ChainingUserRegistrySynchronizer] Synchronization aborted due to error
org.alfresco.repo.security.authentication.AuthenticationException: 01220000 LDAP authentication failed.
        at org.alfresco.repo.security.authentication.ldap.LDAPInitialDirContextFactoryImpl.buildInitialDirContext(LDAPInitialDirContextFactoryImpl.java:114)
        at org.alfresco.repo.security.authentication.ldap.LDAPInitialDirContextFactoryImpl.getDefaultIntialDirContext(LDAPInitialDirContextFactoryImpl.java:89)
        at org.alfresco.repo.security.authentication.ldap.LDAPInitialDirContextFactoryImpl.getDefaultIntialDirContext(LDAPInitialDirContextFactoryImpl.java:82)
        at org.alfresco.repo.security.sync.ldap.LDAPUserRegistry$3.<init>(LDAPUserRegistry.java:670)
        at org.alfresco.repo.security.sync.ldap.LDAPUserRegistry.getGroups(LDAPUserRegistry.java:667)
        at org.alfresco.repo.security.sync.ChainingUserRegistrySynchronizer.syncWithPlugin(ChainingUserRegistrySynchronizer.java:618)
        at org.alfresco.repo.security.sync.ChainingUserRegistrySynchronizer.synchronize(ChainingUserRegistrySynchronizer.java:434)
        at org.alfresco.repo.security.sync.ChainingUserRegistrySynchronizer$6.doWork(ChainingUserRegistrySynchronizer.java:1529)
        at org.alfresco.repo.security.authentication.AuthenticationUtil.runAs(AuthenticationUtil.java:508)
        at org.alfresco.repo.security.sync.ChainingUserRegistrySynchronizer.onBootstrap(ChainingUserRegistrySynchronizer.java:1523)
        at org.springframework.context.event.SimpleApplicationEventMulticaster.multicastEvent(SimpleApplicationEventMulticaster.java:97)
        at org.springframework.context.support.AbstractApplicationContext.publishEvent(AbstractApplicationContext.java:294)
        at org.springframework.context.support.AbstractApplicationContext.finishRefresh(AbstractApplicationContext.java:858)
        at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:419)
        at org.alfresco.repo.management.subsystems.ChildApplicationContextFactory$ApplicationContextState.start(ChildApplicationContextFactory.java:624)
        at org.alfresco.repo.management.subsystems.AbstractPropertyBackedBean.start(AbstractPropertyBackedBean.java:458)
        at org.alfresco.repo.management.subsystems.AbstractPropertyBackedBean.onApplicationEvent(AbstractPropertyBackedBean.java:386)
        at org.alfresco.repo.management.SafeApplicationEventMulticaster.multicastEvent(SafeApplicationEventMulticaster.java:78)
        at org.springframework.web.context.ContextLoader.createWebApplicationContext(ContextLoader.java:261)
        at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:192)
This is not working , Can u help me to resolve this issue.
waiting for your reply.it urgent. Plz reply ASAP.
Regards,
-DJ
10 REPLIES 10
mouradef
hello,
I see the same thing:
it ignores files under /Authentication/ldap-ad/ldap-ad1
but when i put ldap-ad-authentification file under /Authentication/ldap-ad/ it works
in alfresco-global.properties i juste added1:
authentification.chain=AlfrescoNtlm1:AlfrescoNtlm,external1:external,ldap-ad1:ldap-ad
synchronization.import.cron=0 1 * * * ?
synchronization.synchronizeChangeOnly=false
synchronization.syncOnStartup=false
it works for me, but if i have more than one subsystem ldap-ad i think it wouldn't work !
