Hello Depf,
Thank you for your prompt reply and for your efforts trying to replicate the issue.
I uninstalled Alfresco and OWD/Tomcat and started from scratch. I installed Alfresco 3.4.e (ports 8080, 8005, 8009) and OWD 3.2.0.0 (ports 8090, 8006, 8010). Both on seperate instances of Tomcat 6.0 on different ports. I tested prior to make sure everything was working OK and that the Alfresco service was on.
I reran the script exactly as you prescribed but with the correct user and password. Still no luck. I am attaching a zip copy of the openair log and also of the bootstrap file. It should give a complete picture of the install behavior.
One more thing to note: I installed this time using the Administrator account, rather than using an account with Admin rights. Didn't seem to help.
Maybe I am doing something incorrect?
Ari
