How to inject SiteService in my custom class?
mbel
I would like to use some of the methods in Alfresco's SiteService and respectively its implementation.
For example - I want to list all currently created Sites in Alfresco system in a Java code.
What exactly should I inject in my code and what bean should I include.....Its not exactly clear for me.
Thank you in advance.
You also need to add the setter, ie.
public void setSiteService(SiteService siteService)
   this.siteService = siteService;
Regards,
Jan
22 REPLIES 22
Please ask this as a separate question (related to CMIS / OpenCMIS) - thanks.
By default the  maximum number of search results that alfresco  perform permission checks is 1000
If you want to search more than 1000 ,you should add following settings into your alfresco-global.properties file
system.acl.maxPermissionChecks=5000
But It will reduce performance.
douglascrp
World-Class Innovator
