How to inject SiteService in my custom class?
mbel
I would like to use some of the methods in Alfresco's SiteService and respectively its implementation.
For example - I want to list all currently created Sites in Alfresco system in a Java code.
What exactly should I inject in my code and what bean should I include.....Its not exactly clear for me.
Thank you in advance.
You also need to add the setter, ie.
public void setSiteService(SiteService siteService)
   this.siteService = siteService;
Regards,
Jan
22 REPLIES 22
mbel
well....as an other option. The SiteService is now working and I use the method findSites() to list all sites, however the returned object is different than this one in the /api/sites, so if I want to get the json object from /api/sites, I don't know other option....
If you know, I will be glad if you share it.
mbel
Douglas C. R. Paes​, yes but I dont want to hard code it as a property and change it when the host changes.
I think SysAdminParams service is what I was looking for.
kaynezhang
World-Class Innovator
Yes,you need to add setter method in your xxx.demoamp.CustomWebScript class as @Jan Vonka said
janv
Employee
Employee
Alternatively, you can also inject the ServiceRegistry into your custom bean XML extension file:
<property name="serviceRegistry" ref="ServiceRegistry"/>
and then get the SiteService locally (or other public services, as needed):
private ServiceRegistry serviceRegistry;
public void setServiceRegistry(ServiceRegistry serviceRegistry)
   this.serviceRegistry = serviceRegistry;
public void myMethod()
     SiteService siteService = serviceRegistry.getSiteService();
     // ... more here
Regards,
Jan
angelborroy
Community Manager
Jan Vonka​ is this a safe method as ServiceRegistry is providing lower case service beans?
Hyland Developer Evangelist
Angel Borroy Are you sure ? In general, ServiceRegistry returns upper-case public service beans.
angelborroy
Community Manager
Jan Vonka​ You are right: community-edition/ServiceRegistry.java at master · Alfresco/community-edition · GitHub
My mistake, thanks for the clarification!
kaynezhang
ServiceRegistry do return upper-case public service beans,but  but getting some service bean via the ServiceRegistry is not recommended any more.
I have the following code:
  String query = "SELECT * FROM cmis:document";
  OperationContext oc = session.createOperationContext();
   oc.setMaxItemsPerPage(1000000);
   resultado = session.query(query.toString(), false, oc);
But I have more than 5 thousand documents and the cmis returns me only a thousand. How do I increase the number of pages that it searches? I believe he is bringing a page with only his maximum (thousand documents).
